Question about Kenmore KSM100 Stand Mixer
Loud while mixing
Motor Loud while mixing
Why does my Hobart 30 quart mixer cut off after 15-30 seconds of mixing?
The small button that pops out is your over load protection for the electrical motor
There might be a phase missing from your power supply.
The motor might have a problem.
Or the gearbox is faulty and couses the motor to struggle to turn and thst is the reasons for a over load protection to trip
Jul 26, 2015 | Food Mixers
My Kitchenaid mdl: KSM 155gbca is making a loud bumping noise with or without an attachment.
It is more than likely in the planetary or the fuse gear inside the gear box. Try it once you have the planetary off before you go looking inside the gear box. Easiest is planetary problem but far far more likely is the fuse gear.
Aug 08, 2014 | KitchenAid Artisan Series Tilt-Head Stand...
Will not mix
if the motor isnt making a noise then it could be the brushes in the motor that are worn.. or it could be the fuze in the plug have you tried a new one in there
Apr 06, 2014 | Sunbeam 2347 MixMaster Heritage Series...
My KitchenAid mixer will not turn it makes a loud noise.
thebsjunk - I don't know if you've canned the old mixer. If you've bought a new KA, congratulations to Kitchenaid. If you haven't, there's still a possiblilty that you might be able to fix it yourself. (For the price of KA mixers you'd think they's last a 'lifetime', but alas, KA quality is sorely lacking from their current products...but I editorialize.)
It's quite possilbe that you've had a gear tooth break in the transmission, which would lock up and prevent the planetary gear (agitator) from rotating in mixing bowl. This is what happend to my wife's 6 Quart Pro KA mixer. Since it was out of warranty, I decided to troubleshoot myself. First I downloaded the Parts List manual from the KA website so I knew what to expect. Then I easily disassemble the mixer to find that a bevel gear tooth had broken. After ordering the correct parts, and reassembling, it works better than when we first upacked it. The loud whining is absent...
If the motors gone bad, you can still replace that, too. Fixing your mixer yourself is much easier than shipping it off to a repair center, and you have the gratification of doing it yourself.
I hope this helps! Howard, Burke, VA
Oct 14, 2009 | KitchenAid KSM90 Ultra Power Series Stand...
Motor stalls out when mixing you unplug and plug back in and it will run had the motor checked out and was fine
You are overloading the bowl or you bought this used and when they wore the motor out, you ended up with it. Batters & icings 75% bowl capacity, doughs 65% bowl capacity. If you live by this, you will buy 1 mixer & never have to replace it, especially if it's a Hobart.
May 01, 2009 | Food Mixers
Loud and throws flour all over
Do you find the motor running too fast at the lowest setting? Then you need to bring it to someone to adjust the low speed setting. If you are preparing double batches you are over loading the mixer and/or using too fast a speed setting to mix. Don't try to double recipes just because the bowl can handle the volume, the motor cannot and will not last very long if stressed mixing dough frequently.
Nov 13, 2008 | Betty Crocker 340 Watts BCF1250 Stand...
Speed of mixer
does the motor still run or does it slowly start to get less loud? or is the beater assembly that dosnt work? two different issues. if the motor runs but dosnt beat then its the planitary gears that are ground out and need replacing. if the motor slowly dies out then you need to replace the motor.
Dec 24, 2007 | KitchenAid KSM90 Ultra Power Series Stand...
Kenmore KSM100 Stand Mixer Logo
Top Kenmore Food Mixers Experts
Jim Thurston
Darial Jr Lasaria
Darial Jr Lasaria
john h
Are you a Kenmore Food Mixer Expert? Answer questions, earn points and help others
