Question about Safety First Safety 1st Disney Music and Lights Walker - Branchin Out
Can't take seat off to wash it
Taking seat off
Got the wrong instructions on how to fit a BabyStart Sprint Group 0-1 Car Seat. Need instructions on how to fit it.
We have babystart seat it looks like a sprint but isn't. I need instructions to adjust the belts. And to to take off belts so we can take off padding and wash.
Dec 28, 2013 | Baby Gear
How to take the cloth off the seat to wash it
Although I must ada that it's very complicated... If you unscrap the cloth from the top bar, and push the fabric back, there is a prong that you must push in to seperate the bar, from there you can take the fabric off (you will need a small screw driver). AS far as the seat, turn the jumper up-side down and ppush the seat out.... It takes less than 5 minutes to take fabric off but almost 45 minutes to replace after washing, (but it's a must to keep germs away)... :)
Aug 02, 2011 | Kids II Baby Einstein Musical Motion...
How do i take off the seat cover to wash it???
These are very complicated and if reinstalled wrong could lead to serious injury or death.
Most car seats can be washed but great care must be taken with the belts. hand wash in warm water, no soap. The directions from the manufacturer may help you.
Call Cosco/Dorel (they are one in the same) at:
Dorel Juvenile Group
Consumer Relations Department
P.O. Box 2609
Columbus, IN 47202-2609
Phone : (800) 544-1108
Mar 02, 2011 | Cosco Alpha Omega Elite - Hammer Print
I really need to take the straps off our maxicosi cabriofix car seat, taking the cover off has never been a problem but i cant work out how to remove the shoulderstraps
Hi Emily - You should never remove the harness from the carseat due to the safety implications of the harness being incorrectly refitted. To wash the harness straps please remove the fabric only and wash the harness in situ using a warm water solution with lemon juice and bicarbonate of soda to clean it up .
Feb 12, 2011 | Maxi-Cosi CabrioFix (Black Reflection)...
How do i take the main seat cover off my phil and ted sport
you have to undo the 2screws each side to remove handle, and there are 2 screws on each side near footrest to undo. then it should slide upp the frame and off where the handle bar connects. sounds more complicated than it is should take about 10-15min. then the whole seat can go in the wash.
May 29, 2009 | Phil & Teds E3 Twin Seat Jogger
Need help rethreading safety strap
My son has special needs so I must wash his seat often. I can not remember how to put the straps locks back so...
First, whenever I wash the car seat cover, I rethread the straps immediately. I only unhook one at a time and look at the one that is still threaded to see how to re hook the one I am working on.
Since you can't do that at this point, I suggest going to a store that sells car seats, look at how the straps are hooked and if you have a picture phone - take a photo!
May 14, 2009 | Baby Gear
I cant take the seat belt off to wash it!
Start from the back take them of the little metal things then slot them trough front and take the chest buckle off,the croch buckle should come of easy,look under the seat pad.
Apr 29, 2009 | Eddie Bauer 31447 Booster Car Seat - Sage
Removing the seat cover to wash
What I did is cut the hole about .5cm bigger (to fit buckel thru) and then resowed it by hand with a strong thread. I would not recomend washing it in a top load machine (it damaged our seat) best would prob. be dry clean.
Aug 02, 2008 | Zooper Jazz Jogger
Remove Seat to Wash
I still had my manual and it said to unscrew the back; and you do have to take out the top of the straps to get the pad off. I just did this last weekend and then re-install everything. It worked great! The only problem I found was that when the pad is washed, the pad backing gets caught in the velcro and needs to be removed.
Hope that helps!
Apr 07, 2008 | Evenflo Triumph 5
Safety First Safety 1st Disney Music and Lights Walker - Branchin Out Logo
82 people viewed this question
Top Safety First Baby Gear Experts
Dorel UK
Dorel UK
Jennifer Rock
Jennifer Rock
Are you a Safety First Baby Gear Expert? Answer questions, earn points and help others
