Question about Parmak Solar Fence Charger
If charger is working what number should so up on digital fence tester
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,001 Answers
Solar Charger with 2-Port USB High Efficiency: Constructed of the 14 watts High efficiency Sunpower panel, the power conversion rate increases up to 21%-24%, providing enough power to * Fast charging Technology: seeks to maximize its charging speed (up to 2.0A max per port or 2.0 A max overall) Chornic 14W Foldable Solar Charger with 2 Port USB Charger Build with High...
Posted on Dec 19, 2016
  • 378 Answers
It should be 120% of your batt. voltage rating
Posted on Jun 15, 2009
How long does it take to charge battery in solar fence charger?
    1. A solar powered electric fence energizer usually contains a battery for energy storage. The solar panel collects the energy from the sun and charges the battery. Lead acid batteries, which are used in solar fence chargers, typically last around 3 years, or around 1,000 days of charging.
      About Fence Chargers - Zareba Systems
      www.zarebasystems.com/learning-center/all-about/fence-chargers
    Feedback
  1. About Fence Chargers - Zareba Systems
    A solar powered electric fence energizer usually contains a battery for energy storage. The solar panel collects the energy from the sun and charges the battery. Lead acid batteries, which are used in solar fence chargers, typically last around 3 years, or around 1,000 days of charging.‎What can I do to prevent ... - ‎What factors should I consider ...
    [PDF]Fence Controller Installation - Zareba Systems
Jan 01, 2016 | Cars & Trucks
I have a paramark solar charged fence model number df-sp-li it dosen't click anymore how come? Is the click important
The click is the transformer carrying current. If the unit doesn't click, unhook the fence from it and turn it on. If it starts clicking it is a short on the fence. If it doesn't then the unit is not working. contact parmak and they can service it or sell you a replacement circuit board which is the most common failure.
Sep 24, 2012 | Parmak Solar Fence Charger
I have a Parmak Model DF-SP-LI. With a volt meter it reads 2.3 on the fence, but the performance meter is always reading beyond the green.
It depends on the type of fence tester. the common light-o-meters are a resistor ladder, calculated not only for voltage but current. the DF-SP-LI uses half the lowest current most are designed for. no if that is a digital or analog meter, then it would be time to check the out put from the charger with out the fencer connected. if you get the same reading it maybe defective unit. if you get a better reading then you will probable need to upgrade your ground system. insuffencient ground will show its self as a low out put on the fence but not on the charger.
May 20, 2012 | Parmak Solar Fence Charger
12v solar charger is not clicking when turned on.
disconnect the unit from the fence and turn it on. if the fencer work(ticks, meter moves) then it is a fence issue(short, broken wire). if it doesn't then it is an issue with the unit its self and it will probley need a PCB or service.
Oct 22, 2011 | Parmak Solar Fence Charger
Installed the new solar charger in July. ZThe hot wires and ground wires are properly connected, snd the fence is properly grounded. It worked great until approximately two week s ago (end of Sept). The...
I have see this happen before and its usually do to most moisture/rain getting in. ie use multi meter to varify solar charger putting out current/voltage. Odds are its not anymore. Rechargable batteries are notorius for not lasting but not in 2 months.
Oct 07, 2010 | Parmak Solar Fence Charger
We have 2.2 miles of fence,the charger is good for 30 miles.We have a 8 ft ground rod by the charger. the fence is a continues loop. positive wire to fence, negative to ground. meter on the charger says it...
You have got to make sure there are no weeds or brush at all touching the hot wire. Nothing can touch it or it pulls the voltage level way down. Do a full inspection of line.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Oct 02, 2009 | Parmak Solar Fence Charger
No shock from charger
did you make sure the fence isn't grounded or an insulator hasn't melted
Apr 12, 2009 | Parmak Solar Fence Charger
Parmak Solar Fence Charger  Logo
319 people viewed this question
Top Parmak Electrical Supplies Experts
Craig Butler
Craig Butler
Steve Pack
Steve Pack
Are you a Parmak Electrical Supply Expert? Answer questions, earn points and help others
