Question about Wurlitzer Audio Players & Recorders
Model 2910 Won't play when record first comes up there is a delay
My Denon dvd-2910 does not play 5.1. It is connected to Denon AVR-3805. It plays just stereo. The center, back channels and subwoofer don't give any sound
Your Denon DVD-2910 produces left and right audio output. Your Denon AVR-3805 generates 5.1 channel output; therefore, 5.1 channel output may not have been selected or the AVR-3805 may be defective.
Jan 29, 2017 | Denon DVD-2910 DVD Player
When i play a video on my phone that's not recorded, it won't play and the video's format is 3gp but it still won't work
Though 3gp works on mostly all mobile but their size also matters, if file is big or its a movie that you have converted then its unlikely as file size id big and unrecognizable in some models
Oct 10, 2012 | Nokia 6300 Cellular Phone
When I arm a track to record in tracktion 3 I get a delay when monitoring playback.
If you monitor the recording there are two delays... one as audio is converted and stored... the next is when it is retrieved and converted back to audio. Usually the recording interfaces have a monitor function that loops the audio back out before the conversion. playing back previously recorded audio of course will have the delay to retrieve and convert back to audio.
Jul 03, 2011 | Mackie Onyx Blackjack 2x2 Recording...
I've been sent a recently recorded 80 minute Sony Minidisc - but when I attempt to play it, a 'TOC Error' message is displayed. I suspect the disc was ejected from the machine immediately after...
Your diagnosis is likely correct and yes, you can save the data by a process known as TOC cloning.
Depending upon the make and model of your MD recorder(s) you may have to obtain a TOC-cloning friendly model, but every single piece of MD equipment I own has come for free via FreeCycle or Gumtree so you shouldn't have any problems in that respect. If you need one in a hurry then they're usually dirt-cheap on ebay.
I don't wish to plagiarise, nor is there any point in re-inventing the wheel, so if you click here you'll see detailed instructions.
Good luck. Sorry for the long delay in posting an answer,I have only returned to FixYa last week after a long absence and this section isn't often monitored by others as questions are rare now that it's obsolete technology.
May 13, 2011 | Audio Players & Recorders
How to thread a bobbin for the Riccar 2950 model
Here's a manual for the Riccar 2910, it should be similar to your machine.
http://www.riccar.com/ftp/whitepapers/2910-Owners-Manual.pdf
Threading is on page 13 and 14 of the manual, I think, Have a browse through it. Hope this helps!
Aug 29, 2010 | Riccar R650
There is a 1 second delay from the time i play to
adjust your audio buffers, if your recording software allows it. however, there will always be some latency in usb recording devices. i recommend firewire or pci internal cards for recording.
Nov 30, 2009 | M-Audio Fast Track USB (FASTTRACK) Audio...
Delay problem
Not sure how you are defining delay. Are you recording to the hard drive using the sound card as inputs? Are you listening to the speakers while you are recording or are you playing a recording back and there is delay or echo in that? PLease let me know
Sep 18, 2009 | Computers & Internet
Sound delay when recording video
check ur previous software install remove it, and check,
if still reinstall back
Apr 16, 2009 | Acer Aspire One Netbook 8.9" Notebook
Unlock Deno 2910
Initially, pls try:
  • Verify that the tray is empty/no disc in the player;
  • Shut down/off with the front panel On/Off button and not the standby;
  • Press and hold the Open/Close, Play and Skip Reverse (I<<) buttons;
  • Maintain pressing on the above buttons and Power-ON the player with the On/Off button, (again while still holding the above buttons till the "Denon 2910" disappears from the display);
  • pls wait till LOADING completes and the front panel would display 0:00:00;
  • Using the remote control, enter 7, 3, 1, 9, 4, 6, 2, & 8;
  • The Denon 2910 will go into standby mode. Soon as it is on standby, pls press the Standby button on the front panel;
  • Pls verify region free update by pressing the Stop and Skip Forward (>>I) buttons on the front panel. The display would show “Region_Ax” The x would be the former region number that the Denon 2910 is locked into;
  • Should it not work ouot as expected, pls redo all the above steps.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information. Good luck and kind regards. Thank you for using FixYa.
Nov 10, 2008 | Denon DVD-2910 DVD Player
Denon dvd 2910 locked up
You will have 2 choices here, replace it or have it repaied
Jul 06, 2017 | Denon DVD-2910 DVD Player
35 people viewed this question
Top Wurlitzer Audio Players & Recorders Experts
John Robertson
John Robertson
Level 1 Expert
jasbo
jasbo
Donald Chadwick
Donald Chadwick
Level 1 Expert
Are you a Wurlitzer Audio Player and Recorder Expert? Answer questions, earn points and help others
