Question about Magnum Energy MS2012 12V Pure Sine Wave Inverter 100ADC
High voltage fault on Magnum MS2012 running Generator
It shut down the generator, fine on shore power
Generator runs,no power at breakers or output plug,has been started and shutdown under load. 5.7 volts on wires coming from stator. All three wires.this is on a motor home.
have the unit checked by an authorized generator repair shop
if it was operating when shore power came back on there is every possibility that the generator or inverter has been damaged from the lack of synchronization of the sine wave
Oct 07, 2015 | Generac 5975 GP5500 GP Series 5500 Watt...
What can I troubleshoot to determine why my RV Rooftop Heatpump does not work on generator, only shore power?
There are a couple of possible causes:
1. There is a Front/Rear Switch somewhere in the unit, usually in the main salon or near the breaker box. This is most common if your generator is not large enough to run 2 units at the same time. It is not always labeled as such, sometimes it's just 1 or 2 and in others it's a set of breakers.
2. You have dropped a leg from the generator output. Normally the generator has 2 outputs, each feeding a separate circuit. This could be in the generator, the transfer switch or the breaker box. If you have issues with other 110v circuits, this would be a place to start.
3.
Mar 18, 2015 | Dometic Rooftop RV Air Conditioner
My generator just stopped working!! What most likely would it be??
1-high temp shut-down
2-low oil pressure shut-down
3-low coolant level shut-down
4-high current/over-voltage shut-down
Mar 10, 2014 | Electrical Supplies
When I run my generator - a Yamaha EF2400S to my Zantrex Model MS2000, it will not accept the power to charge my batteries. The generator's voltage and frequency, when checked, are within acceptable...
the power coming from your generator is probably "dirty", full of spikes and surges from the generator. If it accepts shore power and not gen power, then the generator is the most likely cause. If the generator in unregulated, you are stuck, but it could have a failing voltage regulator board, or Yamaha may have a solution.
Jan 09, 2010 | Xantrex Technology Heart Freedom 25...
When my batteries run low on power the generator starts up. Most of the time the system works perfectly, but lately the inverter will click and keep clicking and the batteries will not charge, then the...
please check the voltage your generator is supplying to the to the inverter because a high voltage and frequency can make the relays in the inverter to make clicking sounds,and also do not allow your inverter batteries to run completely low before you charge it
Jan 06, 2010 | Xantrex Technology Trace Series Inverter /...
My tram 2512 is stuck in waiting for AC mode, ac is clearly reaching the unit, both by shore power and genset. What could the problem be?
If you are referring to a Trace 2412 inverter, which series is it? An SW or a DR series? In either case, if it won't accept generator power, but the AC input indicator is flashing, the problem is most likely the generator output power is off frequency or voltage. Trace inverters will only connect when the AC input is within certain limits. I'd suggest checking the frequency and voltage output of the generator. If it won't connect to shore power, check the voltage from that source. Make the voltage checks at the inverter input terminals.
May 11, 2009 | Xantrex Technology Trace Series Inverter /...
Magic Chef Microwave Shutting Down Problem in RV
your micrwave may run fine at 110 but it draws more power than the generator is putting out when the magnetron kicks on which is the part that creates the microwave causing the food to heat up. In other words the amperage is too low for the microwave. Amperage is what matters not voltage.
Apr 12, 2009 | Hotpoint RVM1435 Microwave Oven
Magnum Energy MS2012 12V Pure Sine Wave Inverter 100ADC Logo
Top Magnum Energy Electronics - Others Experts
Are you a Magnum Energy Electronics - Other Expert? Answer questions, earn points and help others
