Question about Carrier 38CKC036 Air Conditioner
My ac blower stays on and no cold air - Carrier 38CKC036 Air Conditioner
    Sergeant:
  • 340 Answers
Problem w/condensing unit check the breaker.
Posted on Jun 20, 2009
In AC mode the cooler fan doesn't turn on and after a little while the warm air starts to blow instead of cold air. Any ideas
Sounds like a bad or stuck reversing valve. Typically r.vs. are energized in cooling, verify 24 volts to valve, if yes , bad valve
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Sep 30, 2016 | Whynter ARC-14SH ECO-FRIENDLY 14000 BTU...
My AC some times blows cool air with good pressure but most of the time blows air with low pressure. I have checked the AC pipe also. Its cool.
I'm wondering if it's NOT the AC but the blower fan, how does the heat side blow? if it's good on all blower settings then, it's more than likely your blender door is not opening and closing all the way. When the blender door stays open a little bit it'll let warmer outside air mix with the cold AC air causing it not to be as cold as it should.
Sep 19, 2015 | 2005 Toyota Corolla LE
Blow motor stays on
Does it blow cold air when the AC is on? If not it's likely low on refrigerant.
Td
Jun 26, 2014 | 2003 Ford Expedition
Why does my heater work "sometimes" but mostly blows cold air?
There is a flap on your fire wall or inside at the bottom of your dash that opens when your AC is on and stays closed when the heat is on the flap might be sticking its simple to find and fix try to locate it you can open and close manualy
Feb 01, 2013 | Cars & Trucks
AC not blowing cold air
have ac checked and refilled
Jul 04, 2010 | 1997 Mercury Mountaineer
Intermitent AC, 04 Passat, blower works but no cold air
possibly gas pressure to low or pressure switch on aircon condensor faulty.
May 17, 2010 | 1999 Volkswagen Passat
Front Blower
ok, missed the part about the rear ac working, the part that causes this is called the air temperature control blend door actuator motor, it is an electric motor driven gear drive that moves the plastic door inside the air ducking to mix or shut off the hot or cold air from the ac evaporator core or the heater core, you will need to replace it.
Sep 03, 2009 | 2002 Dodge Durango
Coleman evcon blower not working properly
My Coleman Evcon ac unit,heater and blower does not work.not even the outside condenser comes on.Any ideas on what is the problem?
Jun 22, 2009 | Coleman Heating & Cooling
Blower will not turn on when a/c compressor comes on - tstat ok fuses ok
You should have a fan relay on your furnace that would control your fan in air conditioning and that sounds like you are needing
May 24, 2009 | Honeywell L4064B2236 Fan/Limit Control...
Cold AC but weak Airflow---Also Driver side not as cold as passenger
The air doors are controlled by actuators that on of them or so may need replacing.
May 09, 2009 | Cadillac Seville Cars & Trucks
Carrier 38CKC036 Air Conditioner Logo
160 people viewed this question
Top Carrier Heating & Cooling Experts
Bill Long
Tim Whalen
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
