Question about Samsung Dryers
Dv50f9a8e rattle rattles al the time
smilemaker
  • 790 Answers
SOURCE: rattle from timing chain/cam advance when starting and under load
Hello sir,
There are three possible reasons why your timing chain is making the rattling noise.
1. Oil pressure is low: The tensioners that keep the timing chain tight are operated by oil pressure so if your oil pressure is low then the tensioner will not be working properly hence your chain will flap around and hit the guides.
2. Tensioner is stuck: If you have alot of oil gunk on your tensioner then the tensioner will be stuck and not extend out all the way to keep the timing chain tight.
3. Tensioner is broken: If your tensioner is mechanically broken then you need to replace it.
Having said that, before you follow this write-up it is a good idea to check your oil pressure. Also, in this write up I will not go over how to replace the tensioner but rather tell you how to clean it while it's still installed.
Posted on Jun 11, 2008
  • 127 Answers
SOURCE: glove box rattles hood rattles over bumps
there should be adjustment posts on the hood, you could raise those or lower the latching mechanism.
you might also be able to adjust the glove box latch to close tighter
Posted on Jan 05, 2010
caroldon
  • 17130 Answers
SOURCE: my refrigerator vibrates and rattles from time to
It is normal that when the comprssor runs the vibration of the motor can produce a change reaction resulting in sympathetic vibration of the sub systems. See if the compressor mountings are soft or if the bolts are loose. Tighten them and check. If not you can use good high temperature rating tefflon to be put in between the vibrating coils. You can use any rubbers too provided they are not too soft. These coils may be vibraing and touuching the body or the adjacent coils to produce the noise. I dont think it will be difficult for you so try this out. Good day
Posted on Jul 26, 2010
emissionwiz
  • 78267 Answers
SOURCE: 2003 jeep liberty sport 4x4, rattling noise while driving
Possibly a broken ceramic brick inside the catalytic converter.
Posted on Nov 07, 2012
ajauto57
  • 308 Answers
SOURCE: 2006 kia sorento tensioner rattling after changing timing belt
??? v-6?? need more info.
Posted on Dec 12, 2012
What causes a rattling noise in my engine when i hit the accelerator?
"Rattling" is normally due to one of two things:
  1. On heavy acceleration, rattling is usually due to low octane fuel.
  2. If at all times, it can be due to low oil pressure.
    Rattling can also occur if the engine timing is way out specs. This will normally be accompanied by a substantial loss of power on acceleration.
Aug 04, 2014 | 2002 Toyota Camry
What best position timing mark fly wheel plate land criuser 3fe engine to re install distributor
If it rattles,timing is too far advanced.Loosen the distributor bolt,Back timing to fastest idle,and advance it just a little to where the idle is changing slower.Not much tho.Lock the distributor bolt and drive it.If still rattles,do it again till it doesn't rattle.The rattle you speak of is called engine nock,because it's firing ahead of time too much.
Apr 24, 2014 | 1990 Toyota Land Cruiser
My 1998 sebring 6cyl makes a metal on metal noise on the side of my engine by the belts i tried greaseing all the pullys and i used belt noise sparay but it becomes lower and then it becomes higher ???...
sounds to me from the brief description like you have either a water pump rattling, or a timing chain coming slack. Is the noise coming from the alternator? Never grease pulleys, ever. also the stop squeak spray is bad for your belts. Don't know why they even sell it. If you listen carefully you may be able to pin point the rattle. Is this a tick tick tick, or a rattle rattle rattle? Does sound like a water pump rattle or timing chain slap though. Hope this helps
Jan 14, 2013 | Cars & Trucks
Something is rattling up under the bottom of the car. everytime i hit a bump in the road something is rattling
most commen thing is a rubber brakes and exhaust rattles . .. a bit harder one to find is the link pins start to make a rattle when they are worn out and no one ever checks them .. some times they even seem good but when replaced rattle go's most commen is the exhaust
Apr 11, 2011 | 2000 Ford Windstar
I have mucuni flat top sliders smooth bore they rattle when idling is that normal
If you can hear your Mikuni carbs "rattling" evidently you have changed the air box on your bike. The stock air box does two things, filter the air going into your engine and quieten intake noise. If you've changed or modified your air box in order to get better performance, you'll have to learn to live with more intake noise. The "rattle" you hear is really not a rattle. It is the "intake pulse" of each piston sucking air into the cylinder. Even at idle speeds, it does this so fast at to make it sound like a rattle. At higher speeds, it's so fast that you can't hear it most of the time. If the bike is idling at 1000 RPM, envision the piston moving up and down in the cylinder 1000 times a minute or 16 times a second. Every other time is an intake stroke, 8 times a second.
Oct 09, 2009 | kawasaki Z 750 Motorcycles
Same rattle and noise
this is easy one if you put the a/c on do you hear the rattle if yes then shut off the a/c if the noise go away then it is the compressor
Jul 21, 2009 | 1995 Nissan Altima
Rattling coming from timing belt case
It looks like it is time to replace your timing belt; the rattle is an indicator of the belt being stretched, and when it is stretched, it makes a rattle noise.
Jul 16, 2009 | 1998 Toyota Camry
Chain rattling sound right front
no it would not be the timing belt making a rattling noise it couldn possible be you heat shield around your break rotor it could be someting having to do with ur suspenion like a spring maybe what kind of rattling noise? or a regular heat shield but loose in that particular area
Mar 31, 2009 | 2005 Subaru Forester
98 Corolla Rattling
timing chain tensioners are commen on the 1zzfe. the tensioner is about $50 and the labour another .5 hours.
Jul 31, 2008 | 1998 Toyota Corolla
Dryers Logo
16 people viewed this question
Top Samsung Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Samsung Dryer Expert? Answer questions, earn points and help others
