Question about Vetta RT55 10 Function Bike Computer
Reset rt55 odometer
Reset odometer
2008 pontiac g6 security light stays on t/c flashes then while driving the dash lights flicker and odometer says error.
Odometer
The instrument panel cluster (IPC) displays a season odometer and a trip odometer. Momentarily press the trip/reset switch in order to toggle between the season odometer and the trip odometer. Press the trip/reset switch for greater than 2 seconds, while the trip odometer is displayed, in order to reset the trip odometer. The odometer is calculated and stored electronically in the body control module (BCM). The BCM uses the vehicle speed information from the engine control module (ECM) to calculate the odometer. The odometer displays 'error' if an internal IPC memory failure is detected. The IPC stores a backup copy of the odometer value incase the IPC stops receiving a valid odometer value from the BCM. The odometer will display 'error' if an internal IPC memory failure is detected.
Your best bet , take it to a qualified repair shop .
Jan 21, 2018 | Pontiac Cars & Trucks
HOW TO PULL CODE ON 2012 HARLE
1- Turn motorcycle ignition switch to OFF & Run/Stop switch to RUN.
Push odometer reset button in & hold.
Turn ignition switch to Ignition and release odometer reset button. Background lighting will illuminate, speedometer needle should sweep its full range and indicator lamps (battery, security, low fuel, check engine and cruise) should illuminate. The word "diag" should then appear.
Push the odometer reset button once and you will see the selection menu "PSSPt" with the first P flashing.
2- Push odometer reset button in & hold.
3- Turn ignition switch to Ignition and release odometer reset button. Background lighting will illuminate, speedometer needle should sweep its full range and indicator lamps (battery, security, low fuel, check engine and cruise) should illuminate. The word "diag" should then appear.
4 - Push the odometer reset button once and you will see the selection menu "PSSPt" with the first P flashing.
5 - Each letter represents an area of the diagnostics module. The module that is flashing is the one you are going to check. To move from one letter (module) to the next, you push the odometer reset button one time. (from P to S to SP to t and back to P, etc.)
P = ECM/ICM (Electronic Control Module [EFI] / Ignition Control Module [Carburetor])
S = TSM/TSSM (Turn Signal/ Turn Signal Security Module)
SP = speedometer
T = tachometer
6 - To get the DTC in an area of diagnostics, push and hold the odometer reset button in for 5 seconds and release. If there are any DTC's the code will be displayed or the word "none" will appear if there are no DTC's. Push the odometer reset button again to view additional codes if they exist.
7 - Record the codes.
8 - If DTC's are not to be cleared, Press and release the odometer reset button. Part number of module will be displayed. NOTE: To determine if a code is current or historic, clear the displayed code by pushing in and holding the odometer reset button ( longer than 5 seconds) until 'clear' comes up. Release the odometer reset button. Turn OFF the ignition switch. Run your bike and shut it down then recheck the DTC's again by repeating steps 1 to 9. If the code is current it will reappear.
9 - Press and release the odometer reset button to continue to the next module.
10 - Turn Ignition switch to OFF.
On models not equipped with a tachometer "No Rsp" will appear when the tachometer identifier is selected.
"No Rsp" will also appear if the run/off switch is in the off position when doing this procedure.
The actual error codes will appear (format) as "P0374", for example.
Sep 30, 2014 | Harley Davidson FLHTCUI Electra Glide...
How to get fault coedes of a harley 2013 sportster custom
To enter diagnostic mode press and hold the trip odometer
reset switch while turning the IGN ON.
2. Release the trip odometer reset switch. "diag" will appear
on the odometer display.
3. Press and release the trip odometer reset switch. "PSSPtb"
will appear on the odometer display.
4. PSSPtb indicates the different modules that could display
codes if equipped.
Table 2-1. Modules That Set DTCs
DESIGNATOR MODULE
P ECM codes
S TSM, TSSM or HFSM codes
SP Speedometer codes
t Tachometer codes
b ABS codes
5. Quickly press and release the trip odometer reset switch
to cycle through the letters. The letters will flash as they
are selected.
6. Once the corresponding letter is flashing to the desired
module press and hold the trip odometer reset switch.
7. If no DTCs are present, "none" will appear on display.
8. If any DTCs are stored in the module, either current or
historic, they will appear on the odometer. Quickly pressing
and releasing the trip odometer reset switch will cycle
through the stored DTCs.
NOTE
The ECM will show "no rsp" if the engine stop switch is not in
the RUN position. Verify the engine stop switch is in the RUN
position.
9. If odometer displays "no rsp" then the motorcycle may not
be equipped with the module. If the motorcycle is equipped
with the selected module then go to other modules and
look for applicable communication codes.
10. When all the DTCs have been cycled the odometer will
display "end".
11. To clear all the DTCs in that module press and hold the
trip odometer reset switch. If DTCs are not to be cleared
quickly press and release the trip odometer reset switch.
The part number of the module will be displayed.
12. Press and release the trip odometer reset switch again to
13. Turn the IGN OFF to exit diagnostic mode.
Jun 24, 2014 | 2003 Harley Davidson FXSTD Softail Deuce
Emergency reset button on aveo 2007
Press the reset button, located on the instrument panel cluster next to the trip odometer display, to toggle between the trip odometer and the regular odometer. Holding the reset button for approximately one second while the trip odometer is displayed will reset it.
miles traveled diagnostic
Nov 13, 2012 | Cars & Trucks
I WANT TO SHUT OFF THE LIGHT MAINT REQ IN THE DASH
Make sure the odometer is set to odometer and not tripmeter.
Stick the key in the ignition. Hold down the odometer reset button, turn the key to the on position(don't start the truck) and hold it until the lines are gone..
You will automatically see a few lines in the odometer that will start to go away. Once all the lines are gone, the counter has been reset.
Jan 05, 2011 | 2008 Toyota Tacoma
When i am riding the bike it is not telling me the speed
Some possible solutions:
computer unit is not "clicked in" to the handlebar mount. Remove it and re-seat it all the way in.
the spoke magnet and the pickup sensor on the fork are not close enough for a reading. Make sure that they are properly aligned vertically, and only about 1-3mm apart.
the battery in the unit is old and should be replaced. If you have a tester, you can check this. It will mean resetting the unit one way or the other. Replacement batteries are sometimes available at the "dollar" store.
sometimes the wire leads (if the Vetta RT55 is not wireless) into the handlebar mount become loose. They can be pushed back in, but this generally means the mount has to be replaced, if possible and economical, or the unit scrapped.
I hope this helps; good luck!
Nov 21, 2010 | Vetta RT55 10 Function Bike Computer
I want to reset the 'regular service alarm light' on dashboardm of my 2006 Volvo S40
The service indicator can be reset as follows: Place the key in position 1, push and hold the trip odometer reset, the trip odometer will zero, turn the key to position 2 while continuing to hold the trip odometer reset. The odometer number will return to the previous value and the service indicator will be reset.
Oct 21, 2010 | Volvo S40 Cars & Trucks
Lexus IS250 2009 - Oil light
While pressing and holding the odometer reset button press the IGN button twice without your foot on the brake. The display will show some dashes and finally 00000.
The service reminder should be reset.
Hope it will help
Dan
Jan 05, 2010 | 2009 Lexus IS 250
Vetta RT55 10 Function Bike Computer Logo
111 people viewed this question
Top Vetta Cycling Experts
Michial Gueffroy
Andrew Taylor
Andrew Taylor
Are you a Vetta Cycling Expert? Answer questions, earn points and help others
