Question about Bosch Dishwashers
Bosh she45m06uc/50 error code c6
Error c6
My Bosch she45mo6uc/50 dishwasher will not advance to the wash cycle. It makes a series of clicks, but nothing happens. It just stops. Any ideas?
The most common problem that causes this with this particular unit is the water heater unit failing. It will clod rinse but then when it fills and tries to heat the water, it senses that the heater unit isn't functioning and errors out
Sep 21, 2015 | Bosch Evolution 500 SHE45M06UC Built-in...
Error code C6
On a later model, 6800, C6 indicates hardware error. Not user fixable. http://www.manualowl.com/m/Konica%20Minolta/Fujitsu-fi-6800/Manual/284852?page=149
Jun 07, 2014 | Fujitsu fi-6130 Flatbed Scanner
The led panel on the indoor unit shows a C6 error code the air con is a split system plasma inverter
C6 - compressor run current high
- check [resistance of] compressor windings all equal 1 to 4 ohms
- check [resistance] to earth 50 Mohm minimum
- check run current
I'd also check the motor capacitor(s) , In maximum, it is due to weak capacitor. Replace and try.
Dec 16, 2010 | Heating & Cooling
Replace cover on Bosch Dish washer> Now a C6 code is displayed in the window
I had the same problem after replacing the white panel on my Bosch SHE45M02UC with a stainless panel. I got the C6 error code. I called Bosch customer service twice and neither rep was helpful. One guy told me he didn't know what the C6 code meant. He suggested that I call a local appliance repair guy and he would know what the code meant. I replied, you mean to tell me you work for the manufacturer of the dishwasher and don't know what the error code stands for but a local repair guy that doesn't work for Bosch does?
After all this frustration, I took the panels off and tested the dishwasher with no buttons. It worked fine! Turns out, each identical button isn't identical. Each one is labeled A-G. After putting it back together, no more C6 code! On a side note, try reseting the dishwasher. With the dishwasher on and door closed, hold down the cancel/reset buttons for 5 seconds and release. The disher should drain and reset.
Mar 27, 2010 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosch SHE45M06UC/50 not draining
drain pump is clogged. probably with a piece off glass or something,you must remove the plastic panel piece at the bottom of unit. must use a torc screwdriver
Feb 22, 2010 | Bosch SHE45M06UC Built-in Dishwasher
Are there replacement racks for the bosh SHE43M that are NOT "platinum" which are silicone coated (slippery) and the rack slants downward toward the sides so glasses and cups slide and bump into each othe...
i dont have an answer... i simpkly have a similar problem. just bought and installed Bosch SHE45M06UC dishwasher - and nothing seems to fit in the racks. Can one get other bottom racks of a different design?
Jul 25, 2009 | Bosch Dishwashers
Hello have a inverter LG Airconditioner and it keeps turning itself off and showing the letters C6? Any ideas
Error Code: C6 Problem: Inverter compressor run current high
SOLUTIONS:
- check run current
Probably best to explain/print out and give to authorised serviceman
Mat
Jul 14, 2009 | LG Heating & Cooling
Dishwashers Logo
145 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
