Question about HP LaserJet P3005n Printer
How do I replace a formatter board on an HP 3005N. It is out of warranty and I don't want to take it to a retailer to fix. Thanks
  • kmmoore Jun 15, 2009
    Thanks so much! I appreciate your help. I will give it a try.
  • 105 Answers
Hi there Fairly simple process romve the right hand side cover (slide to the back of the printer and lift off) open the formatter board protection cover hindged at the back then disconnect all cables and remove the formatter board Regards AL "alstech"
Posted on Jun 15, 2009
  • Alan Rothery Jun 15, 2009
    if you need a manaual mail me on alstech@blueyonder.co.uk i will send you a copy
How to change the DIMM 1 in a HP 3005N
The DIMM chip is located in the formatter board, that cage where the network cable is attached.
Mar 26, 2013 | HP LaserJet P3005n Printer
How to replace a formatter board on hp p3005 printer and is there a way you could print the printer configuration first without replacing the formatter board first?
i don't know if can be any shortcuts to print the configuration if the formatter doesn't work properly. the configuration is stored on formatter memory. if the formatter is in good condition you may follow the menu. to change the formatter is pretty easy. you can search a manual on internet.
Jul 07, 2011 | HP LaserJet P3005n Printer
Keeps dispalying mem test faliure 1/6 replace dim 0?
Somewhat common failure code on the P3005 machines. Unfortunately this means that your formatter board has failed. Your machine MAY be repaired under warranty depending on it's warranty date with HP. Just contact HP and give them your printer model and serial number and have them check the warranty status. Trust me in what I am telling you, HP has had a large number of P3005 formatter board failures. If you want more info just do a google search on "HP P3005 formatter" or "HP P3005 dimm 0" and you will see this is a problem.
Good Luck and Thank You using Fixya.
WheatlandServices
Nov 26, 2010 | HP LaserJet P3005n Printer
My printer says paper jam, when there is no paper in the printer. Is it th rollers, I have not used it to much, so I don't think it's because they are worn out.
Hi There,
There is a known issue with this model of HP Printer, If the formatter of this printer is gone bad, then this kind or error do occurs. All you gotta do is to call up the technical help desk of HP and tell them that your formatter is gone bad and you need to replace it. They just need your warranty status and if the printer is under warranty, then they'll replace the formatter free of cost to you.
Hope this solution helps fix this issue. Thanks Enjoy and Cheers !!!!!
Please vote for me if this solution fixes your issue....
Oct 29, 2010 | HP PhotoSmart C4280 Laser Printer
My hp laserjet 3005n keeps going to sleep and won't wake up to print.
Hello, In this situation you really have 2 -3 choices. The first being just to live with it, power cycle the printer when required. The other choices are to make sure the printers software of Firmware is up to date. The last choice would be to replace the formatter board. The firmware file is easily uploaded to the printer, the file can be downloaded from the following location http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareIndex.jsp?lang=en&cc=ca&prodNameId=1846102&prodTypeId=18972&prodSeriesId=1846088&swLang=8&taskId=135&swEnvOID=54
Download the file and unzip to a known location on your compter, be sure to read the "README" file as it contains the instruction to upgrade the firmware. If after upgrading the firmware and the problem remains, you could purchase a new formatter from www.partsnow.com or any Hewlett Packard parts distributor. I wish you luck and I hope this has been benificial to you!!!
Aug 24, 2010 | HP LaserJet P3005n Printer
Getting error code 49.5507 on a HP3005n What does this error mean. Thank you
Firmware error. Turn off and on. The formatter is probably bad. If the printer was manufactured after March of 08, it has an extended warranty for 1 year on formatter board only. CALL HP and demand warranty service on formatter board. KNOWN PROBLEM.
Jan 11, 2010 | HP LaserJet P3005n Printer
I have an HP 3005x and for the third time i've gotten a dimm error and had to replace the dimm.... what is going on?
Formatter board, known problem, even if you don't have dimm installed. Part number q7847-60001. If it was manufactured after 3-2008, and is out of 1 year warranty, it is covered under extended 1 year warranty for formatter board only.
HP LaserJet P2014 keeps showing paper jam when there is no paper jam. How to clear?
If paper jam light is solid than checked paper path sensors and toner sensors and if they are aligned correctly than perform cold reset(Keep pressing and holding the green button) if still the issue persists and orange light remains solid than i m sure formatter board is faulty and we need to get formatter board replaced.
Thanks and Regards
Neeraj Sharma
Jul 01, 2009 | HP Office Equipment & Supplies
Stopped printing
Sounds like you need a new formatter board, you could verify this by swapping it with the good printer
May 15, 2008 | HP LaserJet P2015 Printer
HP LaserJet P3005n Printer Logo
3,366 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
