Question about Dynex DX-L19-10A LCD TV
Blank screen the screen went blank after a high buzzing sound went on for about an hour
When turned on the screen is blank and makes a high pitch buzz
Samsung LCD TV with no video and high pitched sound - Digital TV ...
www.tomsguide.com/forum/54120-4-samsung-video-high-pitched-sound
Nov 8, 2015 - 25 posts - ‎12 authors
Our is the same model and has started making a very high pitched ... to acutally turn on and then when it does, the screen is still black and we ...
Is your LCD making a buzzing or high pitch noise ...
https://www.devside.net/blog/lcd-making-a-buzzing-noise
Dec 30, 2008 - In my case, the monitor was fine for the first two months. But then started making a buzzing noise... 1) when on, 2) worse when .... my Samsung TV ismaking high pitched noises even if its turned off. I will NEVER EVER EVER ...
TV not turning on; making high-pitched sounds - Tom's ...
Dec 13, 2015 | Televison & Video
Why has my acer a3 screen gone blank ?
The program of your unit is wiped out. reprogramming is the solution.
Jul 27, 2014 | Acer Iconia A3 10.1 Tablet - 16GB
My wife said that the tv made a buzz sound then the screen went blank. The tv still turns on, but the screen remains black. I tried leaving it off for awhile, but the problem is the same. Is there a...
This tv have a circuits section call the Deflection board and it is dead,it could be burn any parts of the electronic components on this area.The buzzing sound u hear is the FBT-The high voltage Flyback Transformer have it high voltage current have no where to go,the FBT it could be dead also.This tv can't be done any quick fixes.Must hire a Tv Tech. have to troubleshoot and find out which eclectronic components are dead and require replacing on the tv Deflection sections circuitries of the board.
Dec 04, 2010 | JVC AV-48WP30 48" Rear Projection...
My screen went blank and the 3 lights on the front of the tv were flashing (lamp/temp). I ordered, received, and replaced lamp as I had done previously with this problem. The tv worked beautifully for...
Hi,do you hear any strange noises? if you heart clicking or like wanting to turn on it could be the ballast that's the board that powers the lamp.Do you hear buzzing,whirling,or high pitch sounds?If you do it could be the color wheel which is a little disc looking that when the light of the lamp goes through it creates the colors on the tv.This are the most common failures on samsungs.
Sep 30, 2009 | Samsung DLP HL-P4663W 46" Rear Projection...
Sony KV-27fs100 screen will not do anything, power is on
You may have had the sleep mode set itself. Try unplugging the set for 8 hours and let it reset itself to see if problem persists.
Aug 26, 2009 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Turn headlight arm off and buzzing sound under the hood
change the part that its not comfortable in yore buzzer
May 02, 2009 | 1993 Honda Accord
We have a Samsung HDtv 1080i. While playing a video game yesterday just out of the blue the screen went blank and then all we could hear is a very light buzzing sound. The red light on the front of the...
The flashing light is giving you an error code as there has been some sort of failure in the TV. The buzzing sound could be the flyback transformer. Count the number of flashes. I'm sure the code will be for the flyback.
Jul 07, 2008 | Samsung Televison & Video
SCREEN IS BLANK
I know this sounds crazy but it works Put the cell in the freezer without any leather case for 10 to 15 minutes this will give you around 5 minutes to get into the stored memory and retrieve your stored data if 15 doesn't work I have gone up to an hour don't worry these phones are very durable people use them in sub zero temps with no problem good luck !
May 27, 2008 | LG VX6100 Cellular Phone
Philips 42PF5321D/37
cuse its a philps bad trasiters in back i would take it back get your self a real samsung or sharp ok best on market if that buzzes now u just got it also take it back no good wile u can asap today ok get a nicer samsung u love it on sale circuit city
Dec 26, 2007 | RCA Scenium HDLP61W151 61 in. HD-Ready...
Dynex DX-L19-10A LCD TV Logo
Top Dynex Televison & Video Experts
Jaime Hernandez
Are you a Dynex Televison and Video Expert? Answer questions, earn points and help others
