Question about Barnes & Noble Tablets & eReaders
Nook stuck at 99%
How do i restsrt nook stuck at 99%
How do I transfer my library on my old Nook to my new Nook?
How to transfer books from old nook to New Nook? Therefore, to transfer your Nook books to a new Nook, all you have to do is perform a synchronization between the Nook and your Barnes and Noble account. Press the "Power" button on your Nook and hold it down for two seconds to turn on the device. The Welcome screen opens.
How to Transfer Nook Books to a Different Nook ' Chron.com
smallbusiness.chron.com/transfer-nook-books-different-nook-27403.html Search for: How to transfer books from old nook to New Nook?
How do transfer my library on my old Nook to my new Nook Google Search
Feb 07, 2017 | Tablets & eReaders
Nook HD+ hard restart
Sadly, the only cure is to do a factory reset. BEFORE YOU DO THAT, realize that you may lose what you have put onto your Nook since you bought it. The good news, is that you can reclaim all the stuff you bought from Barnes&Nobel (nook.com). You only really lose the stuff you put on yourself. I suppose you have a backup of your personal stuff stored onto your computer. How do you do a hard reset? You press and HOLD the power button for about 20 seconds.
Jun 26, 2016 | Barnes & Noble Nook HD
My nook says everything has stopped responding how do i get tothe page to reset to factory settings
There are two methods to reset your nook device:
Just follow the link and reset with these simple steps
Hard Reset Procedure For Nook Users
May 23, 2016 | Barnes & Noble Nook HD
Shows 99% won't open and can't shut down
You can first try doing what's called doing a Soft Reset. It's the first and preferred method to try as you don't lose any files or settings. Hold the power button until the Nook turns itself off. In most cases that will be twenty seconds or more. Then turn the power back on by holding the power button down for about two seconds. Hopefully this will allow you to complete a normal boot process. The second and more dramatic way to get a working Nook back is what's called doing a Hard Reset. This process will put your Nook back to "Just Out of the Box" mode. You will lose any files and settings stored internally inside the Nook itself. The good part in all this is it won't touch anything stored externally on your external SD Cards. To do a Hard Reset Turn the NOOK off completely. Hold the Power button and Home (n) buttons. The device will turn on. Continue to hold both buttons until the device shuts off once again (~15-20 seconds). Turn the device on normally. It will prompt for a factory reset. Press the Home button twice to confirm. ------- The important part in the above is to be sure you start the Nook via holding down both the power button and the Home (n) buttons at the very same time and keep them both pressed down until the Nook turns itself off.
Mar 07, 2015 | Nook HD+
Why can't I log in to my nook it just pulses at 99
The "99" is a code for a malfunction that you should call the manufacturer tech support for. They're helpful for that kind of thing. Google your model number and get cust. service.
Feb 19, 2015 | Barnes & Noble Nook Tablet
Unbricking a nook tablet
Well i fixed my nook like that simple, If you mean its gonna reset just re-input your past data and it'll be all right! If not u need to goto the store or ask for help from an expert.
Feb 24, 2014 | Barnes & Noble Nook Tablet
Charging my nook and the screen came on and went to 99% and thats all the screen will do. Charging light shows green and then it sometimes goes back to orange.
It could be your cable, Nook is know to have faulty charging cables, you may have to buy a new one. If you do, here is a tip, search for a pen that you have to click the top to use it, take it apart and take out the spring, now wrap the spring carefully around the charging cord starting at the end where you plug it into the Nook, I attached a photo. This keeps the cord from bending and cracking the wires inside the cable cb393b2a-435d-4472-be29-0ac4a57497ee.jpg
Aug 04, 2013 | Nook HD+
Tablets & eReaders Logo
50 people viewed this question
Top Barnes & Noble Tablets & eReaders Experts
John mullen
john smith
David Payne
David Payne
Are you a Barnes & Noble Tablet and eReader Expert? Answer questions, earn points and help others
