Question about 6019002218 Co-Pilot Transmission Controller 98.5 to
No power to controller
I hooked up everything but have no power to controller. also, now have a engine code on my truck which is P0935
    Sergeant:
  • 365 Answers
P0935 Dodge - Gear Shift Lock Solenoid Ctrl Circ Low
Read more: http://engine-codes.com/p0935_dodge.html#ixzz3a0tHi2gA
Posted on May 13, 2015
I have a 2009 Dodge Ram SLT 4x4 with 120,000.on a 4.7 engine. The check engine light illuminated. These are codes: P0935, P0733 and P0734. Any information on what they are and how to repair them ?
P0935 line pressure sensor circuit high
P0733 gear ratio error in 3rd
P0734 gear ratio error in 4th
Start with the P0935. Get a shop manual and test the circuit FIRST. Do NOT simply replace the sensor. If the wiring tests good, then test the sensor values with engine running. If the sensor is good, you've got an internal pressure problem that would cause the other two codes
Mar 17, 2018 | Dodge Cars & Trucks
Replaced head gasket on my Vitara g16b everything timer correctly now seems to have no spark. Check engine light doesn't light either
If the check engine light doesn't come on when the key is turned to run then the computer module has no power, check for blown fuse. If you have a code reader hook it up, If it will not light up your PCM is dead.
Jul 01, 2016 | Cars & Trucks
Dtc p0935
Dtc p0935 easy federal code P0.
first hit in google, google is your friend.
read that and then ask questions.
or you have tools ,and training, , you and read the FSM
the FSM discoverers this 100% .
or do this:
1: reset the ecu.
2: drive and see if it comes back.
or
3: get radio codes, RTM , if not the radio may brick on you, RTM.
4: the pull battery neg. lug for 5 minutes, some step on brake and shorten this time but not me i do both. I want 0volts to a puter brains in car. then you get a full reLearn.
5: then drive. see if comes back.
this is true with all DTCs, the hope thing.
reset
drive 20miles, and drive aggressively, (safely)
see? it it returns......
as you see the tranny dont like open loop (means future damage)
Nov 07, 2013 | Jeep Cars & Trucks
2007 jeep cherokee 3.7 auto. Codes p0935 and p1745. please any help. new box was fitted by agents 3500km ago. over a year back. . no seems to know jeeps around here.
code p0935 refers to hydraulic pressure sensor--circuit high input===causes --wiring--short to positive--hydraulic pressure sensor--ECM/TCM--TCM -transmission control module.
. Have a pressure test done on the box to ensure that the pressure is correct and that there are no internal issues. Most issues concern the TCM
Nov 07, 2013 | Cars & Trucks
Please I do not know where to start. P0935/p1745 comes up .
wow ,no year stated, kinda makes this very hard....
not even what car it is, wow amazing...
i see 5 engines, in 2008, so what engine. in GC.
start by buying a real FSM on your car, and read the long tests
for finding code fails,, with more tests.
this is what your mech does. (no guessing, we do the tests)
where to starst
1: guessing,
2: testing.
there are 2 paths. only you know which one is best for your.
if rich?, guessing works great. (1/2 the time)
if short cash, try alldata.com for $15 its all there.
the FSM is the best , bar none.
on my cars I have the FSM on DVD. all cars.
and some on paper or both, that way i can be ready.
answer. best i can tell with zero input
is the tranny is bad.
or was overheated, driving.
reset it and pray.
Nov 05, 2013 | Jeep Cars & Trucks
Check engine light came on for 2007 kia rio and had it checked out and im getting 2 codes p0011 and p0012
I guess I will start by saying I would take it back to Kia and tell them it is not fixed. They are on the hook for the cost of repairs if they failed to diagnose the problem the first time. Once you have other people work on the car, the dealer is off the hook.
It could be dirt or something in the cylinder head blocking oil pressure to the control valve. The control valve uses oil pressure to adjust cam timing.
You may need to have the engine oil flushed, or have the oil pressure checked with a mechanical gauge.
Aug 23, 2012 | Kia Rio Cars & Trucks
Check engine comes on and the car will not move in Drive! The car stays on but will have no power in Drive, if you put it in L gear it will move but at 5 miles an hour. Took it in to the shop and they...
Hello
When the service engine soon light (Also called the check engine light) is turned on this is to alert you to the fact that powertrain control module (computer) has detected a failure somewhere in the systems it controls, this can be the transmission or the engine or emission system, there are fault codes set in the modules memory for these faults. What needs to happen now is to have the powertrain control module scanned with a special tool called an OBD2 electronic engine control scanner or a OBD2 code reader. Once the code(s) are read then you must perform the diagnostics for each code and make the appropriate repairs based on the findings of the diagnosis that was performed, this is called doing "Pinpoint" testing.
Jun 22, 2012 | 1994 Lexus Es 300
Codes 441, 446, 455 on a 2005 Camery
P0441 Evaporative Emission Control System Incorrect Purge Flow
P0446 Evaporative Emission Control System Vent Control Circuit Malfunction
P0455 Evaporative Emission Control System Leak Detected (Gross Leak)
http://www.toyotanation.com/forum/showthread.php?t=128923
Jun 04, 2009 | 2004 Lexus LS 430
6019002218 Co-Pilot Transmission Controller 98.5 to Logo
42 people viewed this question
Top ATS Diesel Performance Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you an ATS Diesel Performance Vehicle Part and Accessory Expert? Answer questions, earn points and help others
