Question about Dishwashers
Dishwasher leak I have a General Electric Potscrubber Mobile Maid dishwasher (model GSC720?) that hasn't been used in some time, but appears to still work OK. It has a leak from the left hand vent opening in the bottom of the door when operating. The seal around the door appears intact and doesn't leak. Can you suggest a probable cause, and remedy? Thanks, Bob.
  • 328 Answers
With dishwasher empty and disconnected, find the screws around the area of the "vent",you may need to open it from the bottom. There will be a hose that has either ruptured or just needs the clamp tightened with a screw driver. I think that the hose is a drain or water return. Should be an easy fix.
Posted on Oct 31, 2007
GE Potscrubber,Quiet Power dishwasher leaks while running
Check to see if the door baffles are intact they are little black rubber things in the front on each side of the tub. the pump seal could be leaking underneath. the wrong detergent (dishwashing detergent) could have been used.
Oct 08, 2014 | Dishwashers
General Electric dishwasher model potscrubber 1410 will not pump out final rinse water
So due to this water is still left in the bottom correct? you would have to remove the drain line where it connects into the sink area and also check inside the hole that the hose connects into the sink for any blockages if there are none found here then you would deinstall the dishwasher pull the unit out and check where the drain line connects to the pump. If you also found nothing in the other end of the line then you would disconnect the pump and assure nothing is stuck in the pump and that the impellar can spin freely. lastly you would reassemble the pump and drain hose but you would drain the unit into a bucket and still have the unit pulled out then start the dishwasher and assure there are no leaks. IF you have any further questions message me back Thanks Rick
Sep 25, 2011 | Dishwashers
My GE Potscrubber Dishwasher Model # VSD3104X04WW is leaking at the bottom, to the left of the motor. What seal(s) do I require to solve the problem?
the seal you need is the pump seal. The part number for the pump seal kit is WD19X10032 it could be purchased from your local appliance parts store or online at;
This youtube video shows step by step how to replace the pump seal kit
Sep 10, 2011 | General Electric Dishwashers
GE Potscrubber Mod GSD3630Z00WW Ser Vs783297B 5.2 amps Other 44.4 amps leaking underneath
Here is a tip that I wrote about dishwashers and them leaking.
Leaking Dishwasher
Aug 09, 2010 | GE GSD4100J Dishwasher
Door leaks on a general electric potscrubber 980 dishwasher
Leaking Dishwasher
Sep 26, 2009 | General Electric GE Appliances 24 in....
General Electric Pot scrubber Dishwasher
From what you are describing, the fill valve may have failed or become clogged. Start the dishwasher, when the water stops filling, open the door and check the water level. There should be at least an inch to an inch of water in the center of the tub. If not, replace the water inlet valve.
If you need further assistance, let me know with a model number
Jul 21, 2008 | Dishwashers
GE potscrubber 700
upc leaks when dishwasher is emptying
May 12, 2008 | GE Dishwashers
Dishwashers Logo
295 people viewed this question
Top Dishwashers Experts
