Question about Hitachi PJTX100 Multimedia Projector
Unit will not turn on
Bulb went out,replaced.watched for few hrs,shut it down next time would not turn on
2 Suggested Answers
SOURCE: Television will not turn on
Wow, this just happened to me( 12/12/08). Mine was under warranty, but it took the guy like 2 min to replace the buld. It's in the front bottom panel on the left side. I think the buld cost a little over $200. I hope you don't ened up with the same problem I am having now, "the red glow" on 75% of the screen. I think it's the light engine.
Posted on Dec 23, 2008
Shuts off after approximately 2 minutes
I have exact same problem. According to the manual its time to replace the bulb. But when I check the runtime on the bulb it shows 326 H. I am not certain if this is the remaing hours on the bulb or the usage to date hours.
I would appreciate anyone commenting and recommending a solution.
Jun 13, 2010 | Panasonic PT-AX100U-EC DLP Projector
Intermittant shut down with blinking green light on Sony TV 55"
Hi,Make sure you get the Original Philips lamps since they last 6000-8000 hrs 2-4 yrs,way better then Osram which last 4000-5000 hrs 1 - 1/2 yrs.
Oct 01, 2009 | Sony Grand WEGA KDF-55WF655 36" Rear...
New bulb/TV still shuts down
Its far more likely the result of the power pwb capacitors that have failed. As the 34 code will appear if the capacitors fail on the Power PWB. You can get the V26 DLP Power repair kit at the following link.with free instructions
http://servicemanuals.vstore.ca/product_info.php/pName/mitsubishi-v26-dlp-power-pwb-repair-kit/cName/repair-kits
Apr 30, 2009 | Mitsubishi WD-62725 62" Rear Projection...
Fuel problem
you need to check fuel pump pressure at the fuel rail the next time it shuts off ,
have a great day.
Dec 31, 2008 | 1992 Cadillac DeVille
NEC LT240 has Power, Status & Lamp indicators lit & wont turn on!
If your bulb finally reaches it's end before you have the chance to replace it you unit will shut itself down and go into a permanent standby mode. Changing the bulb alone will not remedy the issue. The solution is quite simple but not posted in the manual or anywhere else that I could find for that matter! All that is required is to hold down the HELP button on your remote for 10 seconds while aiming at the infrared sensor on the unit. This will reset the units bulb timer and remove it from the standby mode.
Dec 10, 2008 | NEC LT 240K Multimedia Projector
NEC projector LT220 - replaced bulb, works for 1.5 hrs then switches itself off
Hi Matt
There might be a couple of reasons for this problem.
Best is to start with the lamp - return the lamp to whoever you bought it from and insist on a another new one.
If the problem still occurs you should rather take the unit to a repairer - because it could be the Mainboard or the Ballast ( lamp's powersupply ) that is faulty and will need replacement or repair.
Check if your unit is under warranty - because the replacement of a Mainboard is quite expensive.
Apr 04, 2008 | NEC LT60LPK Projector Lamp for LT220,...
No picture, hear sound, television will shut off after a few seconds.
Lamp life is only a few thousand hours. Hopefully its only the lamp that made to noise. Don't turn on again until lamp is replaced.
Nov 05, 2007 | Toshiba TheaterWide 52HM84 52" Rear...
Hitachi PJTX100 Multimedia Projector Logo
16 people viewed this question
Top Hitachi Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Hitachi Office Equipment and Supply Expert? Answer questions, earn points and help others
