Question about Samsung Dp700a3b-a01us Touch Desktop All-in-one Pc Touchscreen 6gb 1tb
Cd tray ?
How does it open
How do i open the disc tray on my laptop
Presuming you are talking about a CD-ROM drive, you should first check your manual for information on operating the drive. There are many ways drive trays may be opened. Sometimes there is a button on the laptop that has the standard symbol for CD eject on it that will open the cd tray. Sometimes, there is a small button on the cd-tray itself that when depressed will cause the tray to open after a small delay. This all presumes that you don't have a tray-less
CD drive, that is just a slot on the side of your laptop. If the CD tray is stuck, because of some problem, look for a small hole on the face of the CD tray. Take a straightened out paper clip and push it gently STRAIGHT into the hole until you feel it stop against a bar. Push just a little harder, and the tray should pop open. This latter procedure should only be used when all other methods have failed to open the CD tray.
Sep 04, 2014 | Toshiba Satellite Computers & Internet
Cd tray wont open
CD/DVD Drive Tray problems
There are two ways to open the CD/DVD drive door if the button just below the drive tray does not work.
Go to My Computer and right click on the drive and click on Eject.
If this does not work then you can manually open the CD/DVD drive tray by -
Straighten a paper clip and gently insert it into a tiny hole below the drive tray next to the Eject button. Push the paper clip gently until the drive tray pops out, then pull the tray until it is fully out, then you can remove the CD/DVD disc.
If you still having problem opening with the Eject button, then the CD/DVD drive is faulty and needs replacing.
Apr 13, 2013 | HEWLETT-PACKARD Hp G62-225dx Laptop...
Dell cd drive door won't open
Feb 22, 2013 | Dell Studio XPS 8000 (DXCWKW12) PC Desktop
The cd door won't open on the tower
CD Drive Tray problems
There are two ways to open the CD drive door if the button just below the drive tray does not work.
If this does not work then you can manually open the CD drive tray by -
Straighten a paper clip and gently insert it into a tiny hole below the drive tray next to the Eject button. Push the paper clip gently until the drive tray pops out, then pull the tray until it is fully out, then you can remove the CD disc.
If you still having problem opening with the Eject button, then the CD drive is faulty and needs replacing.
Feb 16, 2013 | ZT Group Cisnet PC Desktop
My dvd tray is not ejecting,i cannot insert a cd
Feb 05, 2013 | Computers & Internet
CD DOOR WON'T OPEN
Just below the CD/DVD tray there is a tiny hole. Insert a straighten paper clip in this hole and gently push the paper clip until the CD/DVD tray pops out. You can now pull the tray out until it is in the fully opened position to remove the disc.
Try pushing the eject button to see if the tray closes, then push the eject button to see if the tray opens.
If this foes not work then the CD/DVD drive is faulty and it needs to be replaced.
Mar 06, 2012 | Dell Computers & Internet
The cd tray on my computer will not open
HI
use thin and long paper pin to open it,
insert pin in cd tray"s hole which u see in front of CD tray and push it,you will get the Cd tray out..
May 28, 2011 | Computers & Internet
I have a CDX-602 CD Player. I was on a gig the other night I placed a cd in the tray. I pressed the button to close the tray and a cord was wedged so that the tray would not close. Naturally the tray...
The gears have probably come out of sync, meaning the tray is riding on the limit switch. You need to remove the deck, dismantle and re-sync the drawer mech. Check the limit switch isnt bent, it's quite flimsy
Aug 21, 2010 | Philips Gemini CDX-602 Dual CD Player with...
I cant open my cd tray on my tascam dp01
Look on the front of the CD tray for a little hole... push the end of a paper clip in the hole and the tray should open.
Dec 12, 2009 | Tascam DP01 All-In-One Recording Package...
Samsung Dp700a3b-a01us Touch Desktop All-in-one Pc Touchscreen 6gb 1tb Logo
44 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
phoenix chi
phoenix chi
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
