DVD Philips BDP 2500/12 doesnt start
When turned on displays letters DVD and does not go farther
Model BDP 7200. Why does display indicate 'BLOCKED'?
Cry. Machine is fubar and needs to be replaced. If you have a disk in there you have to open it up and remove the case.
Mar 13, 2016 | Philips Televison & Video
Philips register product
Direct your query directly to Philips.
Jul 20, 2014 | Philips Televison & Video
Unlock philips bdp 5200 region code
It works.
I tried it on Philips Blue-Ray BDP 5200.
Jan 04, 2013 | Philips DVP3560 DVD Player
Sony blu-ray player BDP-S280 unlock
Turn on the Sony Bluray disc player - BDP-S280. Press and hold the play button for 10 seconds. It should display unlock on the front panel display. You can lock by pressing and holding the play button for 10 seconds again.
Oct 20, 2012 | Sony DVP-NS330 DVD Player
How to unlock region free on U.S sony bdp-s350
Sony BDP S350 bluray - unlocking to region free Yes, it is possible, but you'll need a programmable remote - most use the "one for 3/4/6/all". You can hack it by using the same code as for the bdp-s350. Follow the instructions exactly and it should work - mine does.
Programming the 7040 OneforAll remote to enable region free playback of DVD's on the Sony BDP-S350 Quote: 1. Press DVD 2. Hold the magic button until the DVD button flashes twice. 3. Press 0533 4. Hold the magic button until the DVD button flashes twice. 5. Press 994 6. Press Magic Key (don't hold) 7. Press 1891 (this sets key 1 - the DVD button flashes twice) 8. Hold the magic button until the DVD button flashes twice. 9. Press 994 10. Press Magic Key (don't hold) 11. Press 2552 (this sets key 2 - the DVD button flashes twice) 12. Hold the magic button until the DVD button flashes twice. 13. Press 994 14. Press Magic Key (don't hold) 15. Press 0953 (this sets key 3 - the DVD button flashes twice) 16. Hold the magic button until the DVD button flashes twice. 17. Press 994 18. Press Magic Key (don't hold) 19. Press 2214 (this sets key 4 - the DVD button flashes twice) 20. Hold the magic button until the DVD button flashes twice. . 21. Press 994 22. Press Magic Key (don't hold) 23. Press 0795 (this sets key 5 - the DVD button flashes twice) Done - the remote is now programmed and ready to use Quote: 1. Now to make your player region free use the Sony remote that came with the player to bring it out of standby and wait while HOME is displayed 2. Make sure there isn't a disc in the machine. 3. Now on the OneforAll remote press 1, 2, 3, 4, 5 (The blue 24p light on the player will start flashing) 4. Put the player back into standby with the Sony remote 5. That's it, the next time you turn on the player it will be region free for DVD playback If the blue 24p light doesn't flash then it hasn't worked, try a new set of batteries and start a fresh Good luck
Dec 02, 2010 | Sony BDP-S350 Blu-Ray Player
My player doesnt work anymore display is not working and it doesnt turn on anymore? what do i do?
Hi, thats look like its the power supply,
a zener diode and some caoacitor or its could be the fuse
if the fuse is dark burn inside thats indicate a good short circuit
on the primary side off the power supply,
hope that will help
regards Alan
Oct 09, 2010 | Pioneer BDP-51FD Blu-Ray Player
Unlock sony blu-ray bdp-s370 player
Turn on the BD player. Press and hold the PLAY button and the STOP button until UNLOCKED appears on the front panel display.
Jul 24, 2010 | Sony BDPS370 BluRay Player
Have purchased Terminator Salvation and 2012 on bluray, both Sony discs, they load and go to menu screen, however the icons to allow you to play or scene select etc do not appear, menu just plays over and...
Most likely you need to 'flash' (update) your BDP-S300's firmware. I had the same issue while trying to play AVTR in my BDP-S300. I downloaded Sony's latest firmware update, burned it to disc and popped the disc into the player... It takes 5-10 minutes for the 'flashing' to take place. AVTR now works in my player... Had to do this with one other Blu-ray movie about 18 months ago also.
Download the latest firmware version for the BDP-S300 here...
http://esupport.sony.com/CA/perl/swu-list.pl?mdl=BDP-S300%20®ion_id=3
Follow the instructions to the letter!
If you have any problems with updating your BDP-S300 firmware, feel free to contact me at bambu@rogers.com
Apr 27, 2010 | Sony BDP-S300 Blu-Ray Disc Player
Sometimes doesnt even start playing dvd othertimes sound goes off mid movie
The most likely cause of your frustration with the BDP-S350 is that your player's firmware is not the most current. I have the same model, and had similar problems with Blue Ray Discs like 'Wall-E'.
The solution is to go to sony's website, download the firmware upgrade, burn it to a disc and then load the disc into the player to fix it.
I hope that helps.
Dec 23, 2009 | Sony BDP-S350 Blu-Ray Player
Help
DVD Unlock code is 136900
Jun 04, 2008 | Philips DVP3140
Televison & Video Logo
19 people viewed this question
Top Televison & Video Experts
Electro Med Services...
