Question about Kodak EasyShare Z1275 Digital Camera
Screen is flickering
After turning on camera to take a picture the screen is flickering or moving
Screen flickers and pictures have lines across them on my lumix DMC-TZ3
The camera is probably damaged, this also happend to my DMC-TZ5 as well after a few (5-6) years of heavy use but without any visible damage, a repair is most likely more expensive than just buying one of the new lumix cameras which have also improved A LOT, so you wont be disappointed!
Apr 08, 2016 | Panasonic Lumix DMC-TZ3 Digital Camera
Sony Vaio Laptop VGN-CR240E LCD screen flickering
Mostly it is the problem of the screen's internal mechanism. Something has got loose and moves here n there when moved. If you can, you replace the malfunctioning parts or consult service centre for it.
Aug 10, 2009 | Sony Computers & Internet
My camera's monitor/screen is black with no picture
My AIPTEK 1080p was powering on but the screen was turning off within one second of turning the unit on. I verified that the camera was still working and just the output onto the screen failed. I was able to resolve this by hooking the camcorder up to the TV and viewing the menus on the TV and then turning the camcorder off with the power button. I think this problem happened because I didn't do a "clean" shutdown the last time I had my aiptek hooked up to the TV. It is now working perfectly!
Jul 27, 2009 | Aiptek Video Cameras
Constant flickering
This could be early signs of imminent failure of a defective CCD imager. If so, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check the following two links for more info:
http://camerarepair.blogspot.com/2007/11/canon-digital-cameras-showing-black.html
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=225&modelid=13390&keycode=2112&id=29819
Applicable cameras include:
A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110, IXUS V2/300/400/430/500, IXY Digital 200a/300a/400/450/500
Dec 28, 2007 | Canon PowerShot A85 Digital Camera
Fuji S5000
A few questions for you
If you take the picture and move it to a computer do the lines show up on the picture when it's on the computer screen?
If yes you probably need a new CCD. A CCD take what the lens see and turns it into a digital image.
If the picture comes out fine it may be a loose cable or bad LCD screen.
Either way http://www.precisioncamera.com can fix it for you, they are a bit expensive but do a great job.
Nov 14, 2007 | Fuji FinePix S5000 Digital Camera
View screen sticks on view mode when switch to take picture mode
This is a button/firmware problem Canon Customer support will advise on your next move -depending on the age of the camera
Jun 28, 2007 | Canon PowerShot A75 Digital Camera
A340 screen flickers unexpectedly!
i would suggest taking batteries out overnight and letting the camera discharge the stored power. then trying it again. also make sure what mode your in because the shake warning makes certain lights flicker
Jun 14, 2007 | Fuji FinePix A340 Digital Camera
Kodak EasyShare Z1275 Digital Camera Logo
50 people viewed this question
Top Kodak Cameras Experts
Tony
Greg Cann
Greg Cann
Are you a Kodak Camera Expert? Answer questions, earn points and help others
