Question about Samsung 24 in. DB5710DT Stainless Steel Built-in Dishwasher
SAMSUNG DISHWASHER DISPLAY "LE"
DISPLAY ON DISHWASHER SAYS "LE"
Dishwasher is showing an 'LE' error code? What does this mean?
LE on a sumsung dishwasher is a "LEak" warning. There is water in the base of the machine. If you tip the machine sideways 45% the water will run out and the machine will start again. This will not however fix the leak! But it will confirm that you have one
Sep 22, 2015 | Samsung Dishwashers
How do i reset a Samsung DW80F800UWS with display showing "LE"
Oh, that stands for Leaking - Samsungs have a plastic bottom that catches leaked water which activates a leak detector, which puts up the LEakin message. Most often leaks occur around the drain pump or drain hose. To clear the error, you must remove the standing water under the leak detector; no key sequence will remove that error.
Jan 04, 2015 | Samsung DW80F800UWS/AA 24" Stainless Steel...
HOW TO FIX LE ERROR CODE ON SAMSUNG DISHWASHER DMR78AHS
An LE error code on your dishwasher stands for "LEaking."
There is, what I call, a drip pan on the bottom that the water is dripping into. Remove your dishwasher and take off the lower the side panels to get a look inside the drip pan. If you have water in there, try to find out where it's coming from.
If there are no signs of water, tip the dishwasher over on its side and remove the plastic panel on the bottom of the dishwasher. Once removed, you can disconnect the connector to the leak sensor (it's mounted upside-down, with 4 wires coming out of it. If I remember right, the wires are blue and red).
Flip the dishwasher back upright and plug it in and see if your LE error code pops back on. If it pops back on, then you have a bad board. If it doesn't, then you either have a leak, or the "fangs" on the leak detector are shorting out, somehow.
Oct 29, 2014 | Samsung Dishwashers
Samsung dishwasher le error
LE error means leak. It could be the drain pump came off due to part failure. Or something was spilled into side of dishwasher and it went into bottom tray where sensor is located. For this you would need to pull unit out tip on side and undo bottom pan and see if you can find where leak is coming from. Or if you feel you can't do this call 1800 Samsung for a Samsun product. Or for other brands call there office sometimes with a little work they will help you out.
Feb 12, 2014 | Samsung Dishwashers
Lg dishwasher displays LE error
Display Condition LE = Motor Error
Possible Cause For Error Occurrence:
Wiring connection is OK?
The Impeller of Washing Pump is
locked.
The rotor of Washing Motor is
locked.
The Blade is locked.
Remedy:
Check the wiring connection.
Replace the cause of restriction.
Replace the Washing Motor.
Replace the PCB.
Additional details in this article: dishwasher/how-to-fix-lg-dishwasher-le-error
Hope this helps (remember to rate and comment this answer).
May 26, 2011 | LG Dishwashers
DIGITAL DISPLAY SAYS LE
Hello, W/D here.
The LE code indicates that the dishwasher thinks that there is a leak, and the leak detector shut the machine down and displayed the LE code.
If you in fact have a leak, it should be repaired either as warranty work or by a reputable repairperson. The LE code can be reset by turning off the circuit breaker controlling the power to the dishwasher for several minutes, then resetting it.
If you have a stainless dishwasher, it is guaranteed for life (usually) against leakage. Samsung will require a service call by their tech, and if the unit is unrepairable, will depreciate the unit before offering a refund. Not great. The good news is that these are fairly robust machines, and leakage might be no more than the door seal. Check the seal and reposition it if necessary, as they not only tend to flatten out, but they also tend to pull out of their grooves holding the seal in. It seems that in making the "tall tub" types, there is less space between the racks and the seals. Larger objects, especially on the upper rack, can bump the seal and pull it out of position a bit, creating a leak. It doesn't take much.
If you bought your machine from one of the major hardwares, and you got the extended warranty, they will make three attempts to repair the unit, then replace it if unsuccessful.
Hope that this was helpful to you. --W-D--Please feel free to rate this solution. Thanks.
Feb 21, 2011 | Samsung Dishwashers
Dishwashing cycle starts for about 3 minutes then flashing LE light comes on and the machine stops. Why?
The Impeller of Washing Pump is locked.
The rotor of Washing Motor is locked.
Remedy:
Replace the PCB.
Try the following steps:
Unplug the washing machine if you see an LE error on the two-digit display electronic readout. This error indicates a miscommunication between the control panel and wash motor.
Press and hold the "Start/Pause" button on the front panel for five seconds.
Plug the LG dishwasher back in.
Run a cycle. The LE code will clear.
Aug 31, 2010 | LG 24 in. LDF 7811 Stainless Steel...
LE on display
I just had my LG dishwasher fixed. I told the repair man that LE light was comming on. Even over the phone the repairman said its probably broken wires on the door. Me being in construction for years looked around the door for wires. Anyway the repairman took off 6 screws around the door, took the cover off. You will see about 50 wires taped together. He pulled them aside and visually checked them one by one. Sure enough two were broken in two. He twisted them together put tape and he was gone. $87.50 Still Working!
Mar 25, 2010 | LG LDF6810ST Stainless Steel Built-in...
LE indicater
I have had that where the filters are dirty,
check and clean filters at base of dishwasher.
Chris
lg durban
031-7165444
Jan 22, 2009 | LG 24 in. LD-12BW5 Free-standing...
Samsung 24 in. DB5710DT Stainless Steel Built-in Dishwasher Logo
16 people viewed this question
Top Samsung Dishwashers Experts
vince
Dale Copeland
Dale Copeland
Di Nagy
Di Nagy
Level 1 Expert
Are you a Samsung Dishwasher Expert? Answer questions, earn points and help others
