Question about Beko Refrigerators
How to fix the door onto wmi 61241
Have put the hinges on the maching and on the door but won't fit, how is it done?
SOURCE: door hinge
Firstly if you haven't already done so remove the door and the old Hinge. You can do this by undoing the screws at the back that hold the top of the machine on and remove the top of machine. Now you will see a piece on the inside where the hinge screws into. Hold onto this piece and undo the screws from the outside. Carefully remove the inside piece (because I dropped mine inside and it took me an age to get it out!!). Now undo the screws on the door and pull it apart. Replace the old hinge and screw door back together. Now holding the inside piece back in original position screw the hinge and back onto the machine. (You might need someone to hold the door in place for you....it makes it much easier). Finally screw the top of the machine back on.
Posted on Jun 06, 2008
barkencoa
  • 3463 Answers
SOURCE: Fit a new door hinge
Remove the wire clamp securing rubber seal to front of washer, pull seal of front of washer, this will give you clear access to tjhe door hinge, ondo the 2 screws securing the door hinge, remove door ,and seperate the 2 door halves by removing the screws securing it together
Replace with new hinge, fit back in reverse order.
Please rate my solution.
Thanks.
Posted on Nov 12, 2009
  • 8404 Answers
SOURCE: best way to fit saloon door hinges
Set the bottom height first and make sure the two are level ... then fit the door ... allow for the up and down movement required by the bottom hinge.
Posted on Mar 24, 2010
blueextc3221
  • 15935 Answers
SOURCE: the door hinge has snapped on my washing machine
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 16, 2010
SOURCE: Changing the main hinges on the oven door
There is a good "How to" on u-tube a very easy job.
Posted on Feb 24, 2016
I have a Maytag MFW2055YEM Refrigerator. It is a French Door type. The left refrigerator door has a "C" shaped plastic washer that fits under the bottom door hinge. This washer keeps popping out after...
Is there an easy way to disassemble the hinge and put a solid washer? You can make it quickly by cutting it out of suitable useless plastics. If the door is heavy, please use something to fix it open. Another way is to stick the "C" shaped washer very carefully, so that you do not block the hinge, f. ex. with silicone or other not very aggresive glue. Maybe even turning it on 180 degrees after inserting will be enough.
Jan 20, 2014 | Maytag MFW2055YEM Refrigerator
One side of oven door hinge won't fit back in when putting door back on after cleaning
when you insert the hinges back into place flip the small lock tab at the hinge pin the locks the hinge for removal
Oct 19, 2017 | Indesit KP9508EXG Dual Fuel (Electric and...
Sharp Convection Microwave won't heat and turntable won't turn.
I typically find it is not door hinge issues but door switch issues, especially with sharp. You may heve a little movenent in the door hinge and that is allowing the door hook to move up and down on the plunger for a door switch that is probably a bit melted due to bad connections. If you check the door switches and look for any browning around the terminals where the wires push onto the switch you will probably find an overheated connectoion. Replace the bad switch and run better wires and better termninals to the new switch and it will probably be fine.
Oct 09, 2017 | Sharp R-930AK Convection/Microwave Oven
The handle to the stove has fallen off. How do I fix it?
hello. Get an assistant. Open the door about 1/5 until it stays open. With the help of the assistant lift the door straight up and off of the hinges. Put the door upside down on some towels or other padding on a table. Use a screwdriver to remove all of the screws. Then lift inner panel off. Now you will see where the handle screws are. Put the handle back, screw it on, then replace the inner panel and screw it down. With the assistant slide the door back onto the hinges. Done!
4 thumbs up please. thanks. Joe
Oct 09, 2010 | Frigidaire 30" Self-Cleaning Slide-In...
My roper oven door fell off. We have tried locking the spring loaded hinges in place but they don't stay long enough to fit them into the grooves.
I put something behind the hinges, usually screwdriver handles, to hold them open long enough to slide the door onto the hinges. If you have the style that has the hinge on the door, you usually have to stick a nail into a hole in the hinge (in the open position), that is designed to hold it in the open position. Install the door, and remove the nail. Good Luck, Appliance Specialists
Jan 18, 2010 | Ovens
My Beaumark Stove is from about 1964. The hinge on the oven door popped out while i was moving it. Now both hinges are out and I see no way to put them back.
there is a lock for each hinge
lay the door down with hinges facing up.take a towel pull long piece
of hinge toward you(BE CAREFUL) take other piece up and lock them together do the same to the other hinge it should then go on easy next time lock before taking off .These are the instruction on how to remove and replace the door, be sure you locate the removal pins to being able to put it back
This [link] http://tinyurl.com/kogjg3 should help you out.[link] http://tinyurl.com/mzgjtq is added to the hold the hinge in place on the self clean doors. The screw and bracket have to be removed to remove the door and hinges. The metal clip bracket has to be reinstalled once the door is put back on. To reinstall the [link] http://tinyurl.com/mszglp just do the opposite, start the hinge blade in the receiver, lift slightly on the door and with your knees push the door and hinges back into place. One thing most people forget about these hinges is that there is a clip that must be moved to hold the upper (A) and lower (B) parts of the hinge together. Once the door is put back on, the clip must be put back in the rest position. To reinstall the door, put the door at a 80degree angle to the range front, push in the larger upper hinge parts first and then lower in the smaller hinge parts, push the clips forward into the rest position and close the door.
On this [link] http://tinyurl.com/lg76wg one common problem is the hinge will sometimes "pop" forward against the range instead of staying still while you reinstall the door onto the hinges. If this happens, use a screw driver at the marked spot to help hold the [Link] http://tinyurl.com/kren2c so you can start the door onto the hinge, them remove the screwdriver to finish installing the door.
I hope it helped.
Jun 06, 2009 | Kitchen Ranges
Fixing of door hinge?
undo screws holding both halves of the door togethet then hinge can be removed. hinge is just held onto the cabinet with a couple of screws
Aug 14, 2008 | Hotpoint WD62 Front Load Washer / Dryer
Replace lower door seal
Well, job done. I tried using cable ties to hold the hinges down without success, string would have broken immediately. The only way to do it without a specially made tool is to insert screwdrivers in the narrow gaps between the hinge and the frame with the handle held in place by the bottom of the door and the seal that is being replaced. The problem with this is that when the door is fully removed the screwdrivers are likely to slip and the hinges slam shut, disastrous if any body part is in the way. What is needed is another pair of hands to hold both screwdrivers in place. Apart from having to work around your helper( get a thin one if possible) the rest is easy. Fit the seal to the frame first, then position the fixing plates and hod in place with a paper clip in the lower screw hole. Re-attach the door to the hinge fixing the top screws first, remove the paper clips and fit the lower screws. Your helper can now make the tea whilst you re-fit the rest of the door.
Jun 28, 2008 | Neff 24 in. S5456 Built-in Dishwasher
Door hinge
Apr 21, 2008 | Creda W100FW Front Load Washer
Subzero CHANGING THE PANELS
Service manuals can be gotten from:
https://docstore.kinkos.com/subzero
user name subzero
password subzero
Apr 07, 2008 | Sub-Zero 650 / O Bottom Freezer...
Refrigerators Logo
19 people viewed this question
Top Beko Refrigerators Experts
AJMAL KHAN
ray gallant
Are you a Beko Refrigerator Expert? Answer questions, earn points and help others
