Question about Schonbek 5891-20S Gold Petit Crystal Deluxe 4 Light Down Lighting Flush Mount 5891
Does mirror side of disc face up toward ceiling or down?
Mirror plate, Mirror up toward ceiling
How can I attach a baby mirror to see my baby?
I assume that you want to see while driving, I use a suction cup backed mirror stuck to the windscreen to one side of the rear view mirror. If your child is in a rearwards facing seat you would need two mirrors one at the front and one towards the rear of the car. Hope this helps.
Oct 28, 2015 | 2006 Buick Rainier
How to remove door mirror cover from 2009 ford focus
There are 7 tabs holding the mirror cover on three along the bottom ,two just below the horizontal middle line and two at the top.Squeezing the bottom corner near the car towards the outside of the mirror and pulling gently forward will release the weakest clip at the bottom.The other two bottom ones poke vertically down, the middle two hook over their slot with the hook facing down.Lifting the bottom edge of the mirror cover will help release these. As in the manual push the mirror back along the bottom edge to get some access at the top then using a thin screwdriver push down on two black clips at the left and right upper side edges of the top of the mirror try at the same time to lift the mirror cover up and towards the back of the car to release the remaining bottom and middle clips.Have a look at night with a torch and you may be able to see what is going on with the top two clips. Be careful not to apply too much pressure and break the clips.
I have taken pictures which I will try to post on another site.
Most mechanics were useless in explaining how to do this but I finally found one who could.
The other answers above are not relevant.
Jun 10, 2012 | Ford Focus Cars & Trucks
How do I change side mirrors
Hello, the door outside mirrors are stud mounted to the door filler. The mirror glass face may be replaced by placing a piece of tape over the glass then breaking the mirror face. Adhesive back mirror faces are available. Left side flat and right side convex mirror faces must be replaced with the same type mirror face when surfaced.
  1. Remove the door trim panel.
  2. Remove the upper trim panel.
  3. Remove the sound absorber.
  4. Remove the (3) nuts.
  5. Remove the control cable from the upper trim panel.
  6. Remove the filler and mirror.
INSTALLING THE NEW MIRROR:
  1. Place the filler over the studs on the mirror.
  2. Install the control cable through the filler and connect to the upper trim panel.
  3. Install the (3) retaining nuts and tighten to 42-72 inch lbs. (4.7-8.1 Nm).
  4. Install the sound absorber, upper trim panel and trim panel.
Thanks
Jul 28, 2010 | 1996 Chevrolet S-10 Pickup
Reglue the rear view mirror. How do I remove the metal disc to glue on the window? Every other one I've done their was a set screw. When you remove the screw the small metal seat slides out. This one is...
They changed it. You have to slide the mounting bracket out the bottom of the mirror case.It's a tight fit but the mirror assembly will slide off, toward the roof. Once you have it off you will see a small slot on the bottom of the mounting bracket. Slide a small screwdriver in the slot and push toward the mounting plate (windshield). The plate that goes on the windshield should pop off. Hope this helps.
Jun 02, 2010 | 1998 GMC Jimmy
How do I replace a side mirror chevy corsica?
Please don't forget to rate....thanks:
Removal & Installation The door outside mirrors are stud mounted to the door filler. The mirror glass face may be replaced by placing a piece of tape over the glass then breaking the mirror face. Adhesive back mirror faces are available. Left side flat and right side convex mirror faces must be replaced with the same type mirror face when surfaced.
To install:
Mar 06, 2010 | 1996 Chevrolet Corsica
How to replace mirror plate, the plastic behind the glass mirror on passenger side, heated, power mirror.
push the mirror all the way in, firmly support the face of the mirror with a rag and your hand, reach in behind the mirror, stick the screwdriver between the glass and motor assembly. with a twisting motion, you should be able to free the mirror, and then disconnect the wires. after obtaining a new mirror from your local dealer, position the mirror motor assembly so its straight across, cover the new mirror face with a cloth plug the wires in and firmly press glass into place it should snap in
Jan 08, 2010 | 2009 Chevrolet Silverado 1500
I need to reattach the rear view mirror to the windshield cannot remove the button from the mirror or disconnect the plug for mirror lights.
Just finished this job 5 mins ago. To disconnect the lights, use a small screwdriver to lift the locking tab on the plug. It's on the top of the plug. You should now be able to pull the plug from the socket. First check for locking screws on the housing. If there are none, take a scrap piece of 2x4 and place on edge. Place the pivot arm of the mirror on top edge of 2x4 with flat side of mounting plate facing down. Gently tap the plate out of the housing using a screwdriver and small hammer.
Jul 31, 2009 | 1998 GMC Sonoma
How do i get the metal piece off the review mirrow-96 caprice the thing fell off i cant figure how the metal comes out and it doesnt have a place where you can use a allen wrench
I'm guessing that you mean the mounting plate that attaches to the windshield. The plastic cover over that piece of the mirror comes off. It slides off toward the ceiling end of the mirror. With that off, you will see a small slot on the bottom of the mirror and mounting bracket. Slide a small screwdriver, like a sewing machine screwdriver into that slot. There is a clip in there that needs to be pressed and the plate will come off. The clip should press toward the windshield.
Jun 12, 2009 | 1998 GMC Jimmy
2003 GMC sierra side view mirror glass replacement
That dependso on if the housing itself is broken then yes. If the face plate that is attached to the mirror itself is flapping around then maybe. If it is just the mirror, just go to your neighborhood auto glass shop and but a "Ready-Cut" mirror for a small amount of money. they come already cut to fit perfectly. As for removing the old glass, take a very small flat screw driver and pry the glass away from the face plate. Once completely cleaned out use the adhesive from the ready cut and place them on the face plate. Next press the new mirror onto the flace pate, being careful not to press to hard or it will snap it in half.
Jun 03, 2009 | 2003 GMC Sierra 1500
How to remove mirror glass 2008 ford f350
here's 2003, don't have 2008
Removal
NOTE: Left-hand dual arm mirror with heat shown, non-heated and aero mirrors similar.
All exterior mirrors
  1. Position the exterior mirror glass in the full down position.
  1. Grasp the top and carefully pull the exterior mirror glass away from the mirror housing.
  1. Disconnect the electrical terminals (if equipped) and remove the exterior mirror glass.
Power exterior mirrors
  1. Remove the jack pins from the exterior mirror glass backing plate.
    • Use pliers to grasp the jack pins at the base to remove.
Installation
  1. Remove the sealing boots from the exterior mirror motor.
  1. Install the jack pins in the sealing boots.
  1. Install the jack pins and sealing boots.
    1. Hold the legs of the jack pins and push the jack pins back into the exterior mirror housing.
    1. Install the sealing boots so the boot shoulder is under the mirror collar and turn each jack pin until the head of the jack pin is aligned with the slots in the sockets on the backing glass plate.
  1. Place the new exterior mirror glass assembly down on a smooth firm surface.
  1. Align the friction pins vertically to the exterior mirror glass backing plate socket and push down to snap the pivot ball into the socket.
  1. s3o~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Do not over heat the exterior mirror glass backing plate. Heat only until backing plate is warm to the touch.
    Using the special tool, warm the main pivot sockets in exterior mirror glass backing plate.
  1. Loosely install the glass.
    1. Connect the electrical wiring to the electrical terminals (if equipped).
    1. Position the friction pins in the mirror housing.
    1. Align the jack pin locating tabs to match with the mirror glass back.
  1. Using a flat hand, press on the center of the mirror glass until seated on the center pivot of the mirror housing.
    • Press the mirror glass toward one of the jack pins until snapped in place.
    • Repeat for second jack pin.
NOTE: If the jack pins do not engage, they may not be aligned correctly. Remove the exterior mirror glass, align the jack pins to the slots in the sockets and repeat the installation procedure.
  1. NOTE: The jack pin should click while manually adjusting the exterior mirror glass.
    Tilt the exterior mirror glass to the full outboard position and then press on the outer side of the class until the in/out jack pin snaps into the socket on the exterior mirror backing plate.
    Tilt the exterior mirror glass to the full down position and then press on the outer side of the class until the up/down jack pin snaps into the socket on the exterior mirror backing plate.
Nov 14, 2008 | 2008 Ford F-350
Schonbek 5891-20S Gold Petit Crystal Deluxe 4 Light Down Lighting Flush Mount 5891 Logo
60 people viewed this question
Top Schonbek Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Schonbek Boating Expert? Answer questions, earn points and help others
