Question about RCA 25250RE1 2-Line Cordless Phone
On incoming calls the caller id says incomplete data. The caller id info shows up on another phone system on the same line.
I have reset the phone to factory settings, however, this has not fixed the problem. We have Caller Id and it works on the other phone in the house. However, on this phone, it says incomplete data.
How can i set up caller id
If you have the Caller iD service on your plan, and your phone is filled with your contacts, then the two work automatically and calls coming in on your list will be displayed as you entered them. Calls without any info will only display the most basic of info they allow like just a name, or just a number. Sometimes neither if they choose to block Caller iD. Caller iD is a cellular service and not a hardware function. Check with your service provider.
Aug 29, 2015 | Cell Phones
Incoming call does not show in caller id window all the time. sometimes it simply says "incoming call" without identifying the caller. other times is works proberly.
Caller ID information is sent after the first full ring. If the call is answered too soon, the caller ID information may not have been sent yet. Some of the many and varied networks do not send caller ID information. In this case you may notice that caller ID is missing only on calls from certain callers. Occasionally bad data is sent, causing your phone to reject it.
Jan 23, 2011 | Panasonic KX-TG5632 Phone
My kx-t7731 does not have an enter button.I can see caller id info when the call is incoming but can not recall data afterward.Is it possible to scroll thru caller id info? Is incoming caller id info...
Did you program the 2 buttons for CID-S and CID-I?
I can tell you how to do it, but it won't mean too much if you don't have the other programming done.
Try storing 96 and 97 under a couple of buttons.
Carl
Dec 17, 2010 | Panasonic KX-T7731 Corded Phone
UNIDEN TRU8888-CALLER ID DOES NOT WORK
Hi
Thanks for using FixYa. I think you have stored more than 100 Caller ID messages and hence the caller ID is not showing on Uniden Tru8888. In the following cases the caller ID will not be shown-
If you answer a call before the Caller ID message is received (for example, before the second ring), the Caller ID message will not appear.
When the call is received via a telephone company that does not offer Caller ID service, the caller’s phone number and name does not appear. (This includes some international calls.)
When the call is via a private branch exchange (PBX), the caller's phone number and name may not appear.
You may receive any one of the following messages:
When a private name is received; Private Name
When a private number is received; Private Number
When a unknown name is received; Unknown Name
When a unknown number is received; Unknown Number
When invalid data is received; Incomplete Data
The Caller ID list stores information for incoming calls - even unanswered calls. You can store up to 100 Caller ID messages and phonebook entries (including Speed Dials) for each handset and the base. You can view the Caller ID list through the handset or base during a call or when the phone is in standby mode.
Memory locations for Caller ID messages and Phonebook entries (including Speed Dials) are common, you can store up to all 100 entries for each handset and the base. Caller ID messages are not stored when you have 100 phonebook entries. When you have stored a total of 100 phonebook entries and Caller ID messages, the oldest Caller ID message is overwritten.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Aug 16, 2009 | Uniden Cordless Phone
Get incomplete data message instead of caller ID we pay for
Call the phone company. If you have another phone, plug that in and have someone call in, that will rule out the phone being the issue.
May 27, 2009 | General Electric 25942GE1 5.8 GHz 1-Line...
Talkswitch caller ID from outside calls not working
Log into your TalkSwitch Management Software.
Go to Telephone Lines.
Under each incoming line make sure that Caller ID is checked.
Click File> Save
Hopefully this will fix it for you.
May 06, 2009 | TalkSwitch CT.TS001.124001.US...
Lg insight caller id wont show who's calling, it just says at&t incoming call instead of someones name
Hi,probably the person who is calling you has activated CLIR (call line identification restriction) or you don't have CLIP (call line identification presentation).
May 05, 2009 | AT&T Cell Phones
CALLER ID ONLY SHOWS "INCOMING CALL"
I was using this site while trouble shooting this in the US...
If the customer has DSL with filters in the same system go back to the NID and Isolate the DSL,
test the caller id and call waiting caller id. If this works you have Data Bleed coming from the DSL.
Make sure there are not two sets of filters on the line. Tjis customer had a filter with the DSL modem.
Doing this we just fixed an on going problem for a field tech who was the second callout on a customer issue.
Oct 27, 2007 | Uniden Cordless Phone
Caller ID not working
This is a Definity system phone. The phones themselves have nothing to do with caller ID, it's the system that handles it. The phone line has to have the caller ID service AND the phone system needs to collect the information and then display it on your phone. If you are sure caller ID service is available on the phone line you are using than this is a programming issue. Definity is a huge system and you cannot program it yourself. Someone in your building is either in charge of making simple changes in the phone system or contacting the company that makes these changes for you.
Aug 20, 2007 | Avaya Definity 6408D Corded Phone
RCA 25250RE1 2-Line Cordless Phone Logo
103 people viewed this question
Top RCA Lands Phones Experts
Are you a RCA Lands Phone Expert? Answer questions, earn points and help others
