Question about ClickFree HD535 hard drive 500 GB USB
Are thrre drivers for the clickfree hd535?
Do I need a driver
    Master:
  • ClickFree Master
  • 752 Answers
Many USB devices do need drivers, but if you computer is connected to the internet, when you connect hard drive up to your computer, it will automatically search for the correct driver and download it and install tour device, with the message (at the bottom right of your screen) 'Your new hardware is installed and ready to use'. Sometimes, devices use drivers already included with your operating system, eg WD external HDs. Some are plug'n'play - you do not need drivers.
According to (3) reviews of this I have seen on Amazon, it is as easy as it seems.
22.April.2014
Posted on Apr 22, 2014
2 Suggested Answers
intower18
  • 957 Answers
SOURCE: My old computer (XP) crashed.
I see. Try to restart your computer, if the computer is completely opened try to check if it worked. If not, try to uninstall it then restart your computer, after restarting re-install it then check it if it will work perfectly.
Thanks.
Posted on Sep 25, 2011
Windows 10 does not reconnizes clickfree
FIRST CONTROL THE USB CONNECTORS
SECOND USE IN ANY CASE A LINUX LIFE CD/DVD/ USB TO MAKE YOUR PC BOOTABLE IN A LIFE DISTRO TO SIMPLY CONTROL THE USB PORTS AND THE DRIVE. BECAUSE THAT WILL ALWAYS LET SEE YOU THE DRIVE IF ITS IN GOOD CONDITION..
Dec 19, 2015 | ClickFree HD535 hard drive 500 GB USB
Clickfree cannot be fixed because of an I/O device error
Not much you can do except sending it to Clickfree.
Aug 31, 2014 | ClickFree Computers & Internet
Data on clickfree is from my old XP, when i connect to my newer windows 7 computer, it wants me to format.
Win 7 doesn't recognize the format of XP drive. Put the Click drive on an XP machine on the network and copy files you need then format on Win 7 machine.
Mar 29, 2014 | ClickFree HD535 hard drive 500 GB USB
Why isn't my clickfree C6 backing up my files on the second time I needed to backup my files it just keep saying that it is backing up but all colums saying 0
It would appear that your Clickfree C6 is stuck on searching when attempting to backup. If you find that the backup is stuck at this phase, where 0 files are backed up and the status reads "searching for files": you should be able to resolve this issue by applying an update from Clickfree's website.
Pre-requisites:
-Administrator rights
-A computer using Windows XP SP3, Windows Vista, or Windows 7 (32-bit, or 64-bit is okay)
-The C6 must be detected correctly by the computer (where both CF_Storage and Clickfree_System appear in Computer/My Computer)
Try the following to resolve the Stuck on Searching issue:
1. Ensure that your Clickfree device is plugged into USB
2. Close any open applications that may be running
3. Using a web browser, navigate to the following address: http://www.storage-corp.com/customerservice/C6_Updater_search_issue.exe
• The website will prompt for a username, use: cssupport
• The website will prompt for a password, use: cssupport
4. When prompted, save the file to your desktop
5. Double click on the file named "C6_Updater_search_issue.exe"
6. The update will take place automatically. Do not close the update application until completion.
7. When the update is complete, click on the OK button
8. Disconnect your Clickfree from USB
9. Plug the Clickfree back into USB
Attempt another backup to see if the issue persists.
Jul 29, 2012 | Click Free Automatic Backup C6 1 TB USB...
I have a 16 GB Clickfree Flash Card and when I plug it into my laptop the laptop fails to recognize it. Any ideas?
click start control panel administrative tools computer management device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X
you will need to update/reinstall drivers
right click to reinstall drivers
if you can see your usb drive but its not working
ports (com&lpt) right click update driver if this fails to fix the problem
check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems to a computer and its parts
you might have restore it to its defaults
Right click on usb drive select properties you will have an array of options
Select the hardware option then select your drive properties policies
restore defaults
In XP
Right click on your drive select properties then on customize restore Default in W 7
If you need more help with this post a reply
hope this helps you
May 08, 2012 | ClickFree 16GB TRAVELLERMULTIPLE COMPUTE...
Clickfree C2N Won
IF IT DONT WORK MAYBE YOU WILL NEED TO REFORMAT IT.IN THE PROCCESS YOU WILL LOOSE ANY DATA ON IT.
PLUG IN AND FIND IT THEN RIGHT CLICK AND SELECT FORMAT
Apr 10, 2012 | ClickFree 500GB Clickfree C2 Portable...
Clickfree hd 735 manual
Clickfree hd 735 is an external hard drive backup solution. The manual can be downloaded here.
Jan 09, 2012 | Cameras
I need to format my HD325 click free for mac
I'm sure the OP no longer needs to format their Clickfree C1 HD325 for use on Mac OS X, but I'll answer this question for anyone else who may need a solution.
Before you begin, there are a few things that you should know about Clickfree C1 and Mac OS X compatibility:
-Most Clickfree devices are compatible with Mac OS X 10.5 or higher, but there are some Clickfree C1 devices that aren't compatible with Mac OS X. If your Clickfree C1 was manufactured prior to 2009: your Clickfree C1 won't be compatible with Mac OS X.
-Take a look at the label located underneath the Clickfree C1: if you see WD08xxXM (WD08 is what's important here, you can ignore the rest of the numbers/letters that follow), your Clickfree won't be Mac OS X compatible.
-Formatting the Clickfree C1 using HFS+ will prevent any Windows operating system from detecting the Clickfree correctly. Try formatting the Clickfree in NTFS from a Windows computer for compatibility with both Mac OS X and Windows.
Pre-requisites:
-A Mac using OS X version 10.5 or better
Try the following steps to format your Clickfree C1 for use on a Mac (note that this will erase the contents on your Clickfree C1):
a. Using your keyboard, press the option key + command key + spacebar at the same time; a finder window will appear
b. In the search field located at the top-right of the window, type: Disk Utility
c. Finder will perform a search, and will display the Disk Utility application icon; double-click on the Disk Utility. The Disk Utility application will start
d. Plug your Clickfree into USB, wait a few moments for the application to recognize the Clickfree
e. Click on Clickfree Backup Media from the left side of the Disk Utility window
f. Select the Erase tab
g. Click on the Volume Format drop-down, select: "Mac OS Extended (Journaled)"
h. In the Name field, type: CF_Storage
i. Click on the "Erase" button.
j. Once the erasing is complete, close the application
k. Unplug your Clickfree from USB
l. Plug your Clickfree back into USB
Sep 03, 2011 | ClickFree HD325 320 GB USB 2.0 Hard Drive
ClickFree HD535 hard drive 500 GB USB Logo
104 people viewed this question
Top ClickFree Computers & Internet Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Bill Boyd
Are you a ClickFree Computer and Internet Expert? Answer questions, earn points and help others
