Question about Thomson Lands Phones
Ge phone model 5 2830
How do I connect the phone line
Need 9V adapter for GE phone. Checked all over this AM [Best Buy/Radio Shack...] need one with a longer pin connector; none had one to fit a GE Model 29290C phone.
I cheated. I got a new adapter the right voltage and everything but the plug in would not fit so I cut the end off the old one and the end off the new one put the old end on the new adapter..I soldered them together, Taped them with light tape and it works perfect.
Dec 08, 2014 | GE Lands Phones
I have a GE model 28300 and can not connect
The instructions on the setup disk and the manual which came with the skype GE 2 line phone are inadequate. I just wiped out the phone installation, as well as the skype installation, and then reinstalled them both. After installing the phone, I went to make a skype call, from the keypad, and, indeed, it was dialing properly and call was made, so everything started working, so the disk used to install the phone worked, but not in the way described in the manuals -- wasted 2 - 3 hours due to poor documentation.
Jun 04, 2009 | SKYPE Lands Phones
My answering system and my instructions are all in won't pick up
is the incoming phone line plugged into the answering machine directly? the answering machine should then be plugged into the phone. the signal comes through the answering machine then to the phone. you may have the connections reversed on the answering machine. check those connections.
Nov 26, 2008 | GE 27831 2.4 GHz Twin Cordless Phone
Ring Tone
if you want to make it silent hold down the hash key. ifnot then you may have to turn the volume of the ringtone down to 0.
Jul 15, 2008 | GE 2-9438C Corded Phone
Phone problem
I lost my manual for my GE 5.8 cordless gigahertz phone, and don't know how to program numbers in it. Can you please help me out?
Nov 30, 2007 | GE 25952 Cordless Phone
TReset for GE Pro Series Model 29451A
Remove the plastic speed dial card covering and the speed dial card. Press "program" with a pen tip. Press the intercom button. The lcd display says "address-xx" (probably out of range). Type in a new 2-digit address within range (the number of phones you have), probably 01, 02, 03 or 04. Then press the # key. The intercom light should turn green, and there you have it.
Sep 10, 2007 | GE 25413RE3 Corded Phone
My phone works, but it doesn't ring!
disconnect all phones and just connect the GE phones.
there is only a certain amount of power transmited through a phone line to make the phone ring if you have too many phones running off the same line then the ones further away from the main connection suffer
Jan 05, 2007 | GE 21018GE3 Cordless Phone
Lands Phones Logo
18 people viewed this question
Top Thomson Lands Phones Experts
george  peters
george peters
Are you a Thomson Lands Phone Expert? Answer questions, earn points and help others
