Question about Garden
Roto tiller rear tine tiller jumps out of gear
  • 10865 Answers
SOURCE: rear tiller won't go into gear.belt needs replacing
find your model number from the list on this link and click to get your manual
http://www.managemyhome.com/mmh/owner_manuals/search?query=Craftsman+rear+tine+tiller
Posted on May 20, 2009
harlan301
  • 205 Answers
SOURCE: Tiller goes For./Rev. but wont drive forward with tines engaged
check the sher bolt on the tine to drive shaft. ill need model and ser number off the unit before i can go further with helping you thy changed them around a lot
Posted on Oct 13, 2009
SOURCE: Yardman Rear Tine Tiller tines won't turn. Belt
The problem lies in the shift lever in the gearbox. A poor initial design that was upgraded twice. The shift fork arms have spread enough for pins to come out of the groove they run in when the tiller is shifted to the last position. (Bending back into position would only be a temporary fix as would not be any stronger.) To replace shift lever, the gearbox cover has to be opened. Seperating the cover can be somewhat challenging. When prying cover apart try to not damage the cover gasket. Gearbox grease is very thick, so gasket's real purpose is to keep water and contaminants out. Leave all gearing and chains in place. The shift lever part number is 618-0245B. Or use assembly kit number 753-0869 (contains shift lever 618-0245B, position indicator, and roll pin.) Part will run in the $56-$68 range and can be found through MTD as well as Cub Cadet. Also can get through Sears PartsDirect.
Posted on Dec 13, 2009
SOURCE: mtd rear tines tiller won't engage tines. F and R
I had similar problem recently with 2007 Huskee MTD series 410. The shift assembly bent and couldn't move the clutch collar all the way over on the drive shaft.
Posted on May 27, 2010
SOURCE: tiller tines won't turn where put in gear.
The spring goes in first followed by the ball. The ball should not get in the key way because that is filled by the slider pins that go up into the spur gear that drives the tines. Actually the slider pins drive all of the gears by engaging different gears as the gear collar is moved up and down. The detent spring and ball is the mechanism that is supposed to hold the the clutch collar in place. Mine jumps out of gear when tilling any depth except very shallow. I have reinforced the shifting forks and replaced the pins on the end of it. I believe that the pins wear and the arms spread because i have to keep pressure on the shifting rod or it will jump out of gear when tilling. Even with the reinforcing, pressure on the shifting rod will wear out the pins on the shifting arm. This will be my 3rd reassembly and I am leaning toward the detent spring being weak and allowing the shifting collar to move too easily. I may order an new spring and ball and see if that helps. I am getting pretty good at taking it apart.
Posted on Apr 16, 2011
I have a sears roto tiller model 785 295350. It fires right up but when I try to put it into gear it grinds to a stop. Pleaee help me out.
Sounds to me like you've got something wrapped around the tines or perhaps you have one of the tines on backward. I've done that myself. . .
Aug 01, 2016 | Sears Garden
Gilson roto tiller model 51082
Something in the wheels drive is jammed preventing them from turning. That is why the turning belt starts to smoke when it is turning but cannot unstick the wheels. Need to unstick them for unit to work.
Apr 01, 2016 | WI Gilson Bycast Club Chair
I have a Craftsman 17" rear tine tiller with
check to see if there is a snap ring on the shaft or a roll pin.
Feb 23, 2011 | Craftsman Garden
Put tiller in till gear, goes fine for 30 sec and jump out of gear. tine stop. How do i fix it
Try adjusting the linkage or the shifter cable. If its too tight that will happen. I have almost the same one you do. Look at your manual and check out the blow up diagram. there is a way to adjust most models. If not you may need to replace the cable. But...before you do that make sure your cable isn't meeting with resistance somewhere causing it to be too tight.
May 04, 2010 | Craftsman 8.50 Torque Rating Rear Tine...
Need a manual
here is the Tuffy webpage at the troybuilt.com... directly under the photo of the tiller is a gray "download manual" link...
best wishes,
k
May 28, 2009 | Troy Bilt, Tuffy, Rear - Tine Tiller, 4.0...
Roto Hoe levers
If you have a model 990 rear tine then I could send photos of mine, I have two and they are bulletproof.
This may be all you need: http://www.youtube.com/watch?v=RvuCXCT5Blk
This shows same model in action, let me know if you want photo's.
Mar 25, 2009 | Garden
Tiller tines won't turn where put in gear.
Mar 18, 2009 | Mtd Bronco Rear Tine Tiller
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
