Question about Jeep 2004 Grand Cherokee LAREDO 4WD
Removing and installing spark plugs 04 jeep grand cherokeee
I need to change the spark plugs to do a tune up
motor1258
  • 6674 Answers
SOURCE: change a serpentine belt on 04 jeep grand cherokee laredo
Check this link & scroll down to your engine. Click on picture to expand.
http://www.autozone.com/shopping/repairGuide.htm?pageId=0900c1528004328a
Posted on Feb 03, 2009
Mikey108
  • 475 Answers
SOURCE: 2002 Jeep Grand Cherokee Lardo misfiring
You say you changed the cam sensor. A1391 code is a crank sensor on the top of the trans. bell housing.
Posted on Feb 24, 2009
  • 94 Answers
SOURCE: Spark plug location
this has coil over plug (c.o.p.) ignition.you do have to pull the 8 coils to get to the plugs.
Posted on Mar 10, 2009
  • 6982 Answers
SOURCE: how to change the ball joints on a 1996 jeep grand cherokee
'dont remember any. Be sure you have the joint square with the knuckle when installing... If it cocks to one side, it will jam. take care not to damage the boot. When using fork, it can damage stuff . I refrain from using it as much as possible, using a good sized hammer and giving a shot on the side of pin recievers (like where tie rod end goes through arm on knuckle) this saves tearing tie rod end boot. When in doubt get a manual...any more questions, ask!!
Posted on Mar 14, 2009
csmock132
  • 4669 Answers
SOURCE: spark plugs location
What engine 6 cylinder? If yes you have to remove the coil rail on the passenger side of the cylinder head.
Posted on Apr 04, 2009
Estimated parts n labor change transfer case 2001 jeep grand cherokeee
are you asking, blind people how much things cost.
what country, what town, what shop
new parts or used
what is your labor rates, (varies by all geography on planet earth)
why not ask YOUR mechanic this.
and get 2 more opinions in YOUR town.
there are no fixed prices in USA, (well milk)
still mostly a free country.
Dec 12, 2015 | Jeep Cars & Trucks
How to fix locked liftgate on 2008 jeep grand cherokee ?
first is diagnosis.
you examine and test it. to see if its electrical or mech. failure.
and once discovered that follow that to logical conclusions.
Jul 08, 2014 | Jeep Grand Cars & Trucks
Poor gas mileage-6 cyl-,.10-12 mpg -city
Get a complete tune up. Change the spark plugs, spark plug wires, oil change, electronic ignition starter, and points..if you have an older vehicle.
Apr 08, 2013 | 1993 Jeep Grand Cherokee
How much is a tune up for a 1996 jeep cherokee
It varies greatly on how much you want to spend and how much of a tune up your doing. For me replacing all the spark plugs, spark plug wires, cap and rotor, air filter, oil change/ oil filter change and fuel filter change is a big tune up that would run a do it yourselfer about $80- $125.00 or more if you get higher performance parts. You can also add to that coolant flush and some good fuel additive. make sure to check your serpentine belt for cracks or wear.
Jan 07, 2011 | 1996 Jeep Grand Cherokee
04 jeep grand cherokee 4.7 v8. I changed 7 spark plugs with ngk plugs could not get to the 8th passenger side firewall plug. engine seems to missfire upon startup for 30 seconds or less then runs smooth...
Change the pcv valve this will cause problems. You can get the eighth plug, put the socket on the plug and use a wrench that fits the socket to get it loose or out. It's a pain but necessary.
Randy
Nov 10, 2010 | 2004 Jeep Grand Cherokee
What does the 2003 cherokee jeep needs for tune up.. I have 94,000 mileage on it..
spark plugs, new spark plug wires, fuel filter, air filter those are the critical parts. suggest that if you change the fuel filter yourself to get a chilton's auto repair manual for detailed information on the procedures
Apr 23, 2010 | 2003 Jeep Grand Cherokee
I need a tune up ,jeep 2004, do i need a professional for a tune up. or can somone do a tune up whose not mechanic. And how can i find out the parts needed.do I need ie 2004 need a wire set, or roto/cap
It depends on how many miles you have. A typical tune up would consist of changing transmission fluid, differential fluid, and engine oil. Also check the air filter, and oil filter. You should also check the serpentine belt for wear. You can change your spark plugs, but you will need to buy tools. Typically you would need to by a 3/8 size spark plug socket, a couple of extentions, and a ratchet. Make sure you change your plugs and wires one at a time, or you might put the wires in the wrong place. Your vehicle is new enough that it probably doesnt have a distributor (no rotor button or cap). But if it does, they are cheap to replace and I recommend doing while your at it. If you take your vehicle to a shop, double check anything they say is wrong. They will fudge and stretch the truth.
Jan 21, 2010 | 2004 Jeep Grand Cherokee
Jeep 2004 Grand Cherokee LAREDO 4WD Logo
23 people viewed this question
Top Jeep Car Audio & Video Experts
xxxxxx xxx
Tom Chichester
Kevin Daniels
Are you a Jeep Car Audio and Video Expert? Answer questions, earn points and help others
