Question about Magic Chef Freezers
Start capacitor wont cool
Arctic air freezer
motor humming is from 2 things
start / run capacitor is failed
compressor is seized and the motor is not turning
call in an technician for a proper diagnosis and quote
Jul 08, 2016 | Artic Air Arctic Air F22CW12 Commercial...
Samsung refrigerator wont cool down
JUST ROTATE YOUR THERMOSTAT TO THE MAXIMUM AND WATCH IF STARTS COOLING THEN ADJUST THE THERMOSTAT TO YOUR REQUIRED LEVEL LATER ON. iN CASE IT DOES NOT START COOLING CHECK THE COMPRESSOR WHETHER IT IS WORKING, IN CASE YES THEN THERE IS NO GAS IN IT
Sep 29, 2014 | Samsung RF217ACPN - 20 cu. ft. French Door...
My amana Deepfreeze runs but doesnt cool
sounds like bad capacitor wont let compressor start up if voltage going to it but not going out replace
Aug 16, 2014 | Freezers
Hi I have a whirlpool upright freezer ev190nxwn00. That will not cool
Yes I could be. My advice, if this freezer is 10-12 years old or more, you may be getting ready to spend a lot of money starting now. If not, have somebody physically look at it. Hopefully, it is just the relay or capacitor.
Feb 04, 2013 | Whirlpool Freezers
20.0 cu.ft upright frigidaire. I unpluged it because we were moving and it set for a while before we pluged it back up about six to ten months now it nolonger gets cold. what problem do i have?
Hi Kenneth.
I understood that the fridge is starting but does not cool.
Check fridge temperature settings.
Check if the motor is starting. If the compressor is not running of if it clicks and does not start is the relay/capacitor connected to the motor.
Check if coils have been damaged or if the motor runs most of the time. If there have been a leak or if the refrigerant pressure is low the fridge will not cool.
If thermostat or electronic control is defective the fridge will not cool.
I can be a bit more specific if you give me the complete model number.
Jan 07, 2012 | GE 14.8 cu. ft. / 419 liter Chest Freezer...
My freezer defrosted and everything is starting to go bad. i turned the thermastat to 7 in an attempt to get it to start freezing with no luck. when the on/off switch is turned on a very loud alarm...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Aug 08, 2011 | Kenmore 20.3 cu. ft. / 575 liter Upright...
I have a Frigidaire freezer chest. model number: mfc13m4fw3. It will click on for ten seconds and click off. I don't understand whats wrong. It wont stay on. Thank you
heatman101
Jun 29, 2011 | Frigidaire Freezers
Power but wont run the motor to freeze
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
heatman101
Jan 05, 2011 | Haier 13.6 cu. ft. / 385 liter Upright...
Whirlpool Gladiator Freezerator not cold
Just had the same problem on my Freezerator, the compressor would cycle on for a few seconds and then off for about 5-10 minutes. No cooling. Replaced the overload sw and the start capacitor and system running cold and tru. Beer cold again, 0deg in freezer. Parts are available on the web, P/n 2169373 for the capacitor and 213615000 for the switch and housing...may be different # for the sw....PTM
Jul 15, 2009 | Whirlpool Freezers
Freezers Logo
71 people viewed this question
Top Magic Chef Freezers Experts
Dan Webster
Dan Webster
Offbelay
Level 1 Expert
AJMAL KHAN
Are you a Magic Chef Freezer Expert? Answer questions, earn points and help others
