Question about Denon AVR-2312CI
Hdmi video card not wroking - Denon AVR-2312CI
+I have a dell 4600, it came with a geforce fx5200 graphic card, i need a vga and a hdmi coneection, my monitor is vga and i want to hook up a tv monitor with hdmi
Dear civetscat,
Hello and welcome to FixYa!
I have research these converters/adapters before that can convert from the DVI port on the video card to an HDMI source. They are very exspensive for the type that truely work, and the cheap ones provide terrible graphics. Your best bet, is to research both the adapter and a replacement video card for your PC that will have the HDMI and VGA outputs you seek.
I have provided links to both below, from a site call newegg.com
Adapter/Converter: http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&DEPA=0&Order=BESTMATCH&Description=DVI+to+HDMI+converter
Replacement video card: http://www.newegg.com/Product/Product.aspx?Item=N82E16814161308
Happy hunting and have a great day!
Sep 01, 2011 | Nvidia GeForce FX 5200 Video Card Graphic
Tip
How to Connect PC to HDMI TV Step 1 Turn your...
  1. Step 1 Turn your computer off, and turn it around to view the rear of the unit. Find the cable that comes from the computer's monitor, and follow it to the back of the PC. The cable will be plugged into the output of the video card, which will be either a 15-pin VGA port or a 29-pin DVI port. If you are fortunate, there will be a second port directly next to it, of either the DVI or VGA variety. On the newest machines, you may even find a regular HDMI port on the card.
  2. Step 2 Choose the connection for video output. If your computer has an HDMI port, you can simply connect an HDMI cord of the correct length between the computer and the TV. Otherwise, you will need to make a few decisions. If your computer has only a single video output, and it will not be used solely with the television, you may want to invest in a new video card. Purchase one with either a DVI or an HDMI output, and install it in an available slot, according the instructions included with it. If you intend to use the VGA output on a single-output or dual-output card to drive the HDMI display, then a special device will be needed to convert between the formats, and the price of the converter is actually about the same price as an entry-level video card that will be easier to use with your TV. In that case, it may be a wise idea to upgrade the card in order to obtain a DVI or HDMI port. However, if your chosen output port is of the DVI variety, an inexpensive DVI to HDMI cable can be purchased to convert your computer's output into the proper HDMI input for your TV.
  3. Step 3 Connect the HDMI cable from your television to your computer. Install the correct adapter or converter for your computer, if necessary. Unless your computer has HDMI output, cords will also need to be connected from the sound card output to the HDMI video cable or adapter, because HDMI carries both video and audio signals.
  4. Step 4 Boot your PC, and configure the new display, by selecting "Control Panel" from the "Start" Menu. Then double-click the "Display" icon and click the "Settings" tab. The manual for your HDMI TV will list the screen resolutions it supports, along with the refresh rates. Configure the resolution in the "Settings" tab, and then click the "Advanced" button to set the refresh rate. If you are using the HDMI TV as the second monitor, you will also have to configure how it is used by Windows, according to the instructions pertaining to your video card. Most cards offer a "Clone" or "Mirror" mode, where both screens display the same content. Alternately, the "Extended Desktop" mode can be used, in which each monitor will operate independently.
  5. Step 5 Reboot your PC to apply the changes, if necessary, and prepare to relax on your couch and watch your movies on the big-screen HDMI TV.
on May 24, 2010 | Computers & Internet
I cant seem to figure out what kind of video card upgrade to get for my desktop that has an hdmi imput
I don't know of any video card that has a HDMI input. There are several that have HDMI outputs, but none are AGP cards, this is the older model.
But the HDMI can be easily obtained with an DVI to HDMI adaptor like
http://www.amazon.com/Cables-Unlimited-PCM-2296-06-HDMI-Cable/dp/B0007MWE1E
that can be plugged in every card that has an DVI output like
http://www.amazon.com/MSI-Radeon-PCI-Express-Graphics-MD512H/dp/B002EECNPA/ref=sr_1_14?s=electronics&ie=UTF8&qid=1307599951&sr=1-14
Jun 08, 2011 | HP Compaq Presario SR1550NX (PY059AA) PC...
Unable to get sound with a HDMI cable. Zogis 9400GT 1Gb 128bit PCIExtra Video card.
Video cards do not process sound, so sound will not come through an HDMI cord that is connected to a PCI video card, you will need a seperate sound wire plugged into your sound card or motherboard to connect to your monitor or speakers. I hope this helps!
Mar 15, 2011 | Zogis GeForce 9400 GT 1 GB 128bit GDDR2...
I have my PS3 plugged into my tv with an HDMI cable, and it was wroking fine just yesterday. But today I moved it back to my living room tv where it usually is but nothing shows up. It just says...
Please do the following to reset your display -
1. Turn the PS3 off into standby mode (red light on)
2. Press and hold the power button for 2 beeps (the first beep will be when you first press the button and the second beep will be around 5 seconds later)
3. Release the power button after you hear the second beep
4. Wait for the display to restart
Hope this helps and thank you for using FixYa
Jan 13, 2011 | Video Game Consoles & Games
Can i use a HDMI vga card on Asus p5kpl se? how?
Yes you can. If you would be buying a Video card. Make sure it is PCIE interface. You would also notice that some video cards may have the letters HD (specially those with ATI chips) after their model name. That clearly indicates that it has HDMI output. If you would be prompting for NVIDIA, just make sure to check the card itself if it has an HDMI Port. There are some Video cards that doesnt require PCIE Power but still has HDMI functionality and there are some that does require it so you need to consider your power supply if it can handle the video card that you want to purchase. Take note, the stronger the video card you will be getting, the more it needs power (On the good side you would get very good results even if it is power hungry). Once you have the video card, you just need to install it properly on the motherboards PCIE slot and run the driver disk that is included for it to be recognized by your computer.
here are examples of the cards that you might want to check:
ATI 3850HD, ATi 4850HD, ATI 5750HD, ATI5850HD,NVIDIA 9400GT HDMI and other geforce 9 HDMI series cards
hope this helps
Jun 18, 2010 | ASUS P5KPL-AM SE Motherboard
Need hdmi video card for gateway 510x i have one pci slot open No APG slot I want to us my 42'' hdtv as monitor. Also, looks like the gatewat slots on on the wrong side. Can I flip the card over?
I'm guessing you have a PCI-Express slot in your computer. In that case you can buy almost any PCI-Express video card these days and have it output to your HDTV.
Newegg's list of HDCP-capable video cards
What you're really looking for isn't a "HDMI" capable video card really, since all video card with some sort of digital connection, DVI, DisplayPort, can all be converted to HDMI using a converter even if you doesn't have a HDMI connector built in.
What you need is a card that is HDCP-compatible, which is the encoding/encryption for HD content output. Almost all new video cards now have it. So you shouldn't have a problem.
As far as inserting the card... they're often placed differently depending on chasis and motherboard, but you shouldn't have any issues with that either.
May 25, 2010 | Computers & Internet
I loaded some software for a friend... on a new HP... she has an HDMI video card... i had to remove the card to get the standard video to work... now when i plugged the card back in... it will not bring up...
Is it possible you uninstalled the driver for the HDMI video card in other to get the new video card to work? if so you will need to remove the HDMI video card and replace the standard card, start up the computer and reinstaill the driver for the HDMI card.
Jul 17, 2009 | HP f1905 19" Flat Panel LCD Monitor
Connecting computer to tv using usb ports
You cannot,the best thing that you can do is to use the computers video card HDMI output to the HDMI input on TV. The USB is there for things like firmware updates and if your lucky,u may be able to plug in flash drive and view media through it. If your video card has SVIDEO you might be able to use that as well, but HDMI is the way to go if your serious about it, and an HDMI ready video card upgrade for your computer shouldnt cost more than $100,in fact 49 bux at STAPLES right now for a PCIex card.
Dec 20, 2008 | Philips TV Tuner Video Capture PCI Card -...
How to set my audio to hdmi while connecting my tv to my pc. my graphic card is Gforce 9600
I am pretty sure that the nVidia GeForce 9600 series of video cards use a DVI connector, not an HDMI connector.
While the HDMI connector has the ability to transfer digital and analog audio across it, the DVI cable does not.
You can connect a DVI video card to an HDMI display, and it is compatible for the VIDEO portion, but again, the DVI connector does not output audio at all.
You will need to connect the audio outputs of your audio card or motherboard to your TV by using a 3.5mm headphone jack to RCA jack adapter.
Dec 08, 2008 | Sharp Audio Players & Recorders
Denon AVR-2312CI Logo
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
