Question about Amana 30" Self Cleaning Electric Range Stove W/ Oven Freestanding Black & Gray
Where is location of fuse block for 1995 FXSTSB
Can't find the fuse block!
Where are the fuses on a fridgidare range,glass top,everything works except thesettings for my stove doesnt light up
Thank you for your post, friend!
Based off what you have described the settings on your Frigidaire range do not light up and you would like to know the location of fuses. There are no fuses within your range, if the control panel is not lighting up it could be a short within your panel and that may need to be replaced. I would recommend having a professional technician out to disassemble your range and replace any electrical components. This will protect you from any personal injury and future issues with your range. Hopefully this information is helpful. -Matt
Mar 10, 2015 | Frigidaire Stove/Oven/Range Black Glass...
Where are the inline fuses on the Electrolux Frigidaire double ovens?
I appreciate your post, Richard Balzer!
I see that you would like to know the location of your inline fuses on your Electrolux wall oven. I have located the wiring diagram and the parts manual for your wall oven. I do not see the location of an inline fuse. I hope this is helpful information. -Matt
Frigidaire Manual Search Results
Jan 18, 2015 | Electrolux Frigidaire Gallery 30" Double...
How do I find the fuses for my Electrolux PCHV42P88 hood? One row of lights is out and it is not a bulb issue.
Good Morning James Formalyn, thanks for your post!
I see that a row of lights is out on your Electrolux hood and you are searching for a fuse. I was unable to locate any additional information for your hood. The model number you have provided is PCHV42P88. If you could check the model number I would be able to locate any additional information. I look forward to helping you. -Matt
Dec 17, 2014 | Electrolux Cooktops
Where is the fuse in a sr4002?
Generally behind the back panel, some models use a fusible link rather than a glass/wire fuse, un less you know what it looks like you will need a multimeter to check for continuity till you locate it.
May 02, 2014 | Amana 30" Self Cleaning Electric Range...
Fuse location
How to locate and install a turn signal flasher fuse and 92' izusu rodeo
Jan 08, 2014 | Amana 30" Self Cleaning Electric Range...
Blown fuse jed8430adb
I would like to assist you but I am confused as too your model and fuse you refereed too. Is this a Kitchen-Aid or a Jen-air model?
Where is this fuse located? If I remember correctly in the Kitchen-aid model there was a single unit that had fuses with the harness and not on the lookup when you seek parts. But without more information I don't want to lead you down a goose chase.
Get back to me and I will be glad to help.
Thanks
Oct 14, 2013 | KitchenAid 36 in. KECC568GSS Electric...
Hi, I have a creda colonial range cooker. Yesterday I was using the fan oven and it tripped a fuse in the main fusebok of our house. I reset the fuse and now the 2 oveens wont work. The lights come on and...
All electrical appliance has a safety fuse located somewhere in the interior, most of the time it can be replaced.
always unplug electricity before attempting to repair on any electrical appliance
Sep 13, 2017 | Creda Colonial 42352 23 in. Electric...
Hotpoint
just a thought - check the connection block where incoming mains connects to the hob. these quite commonly burn out
Sep 07, 2008 | Cooktops
Jenn air electric range wiring diagram
In a normal house, black and red are the hot wires and are wired to a circuit breaker or fuse at the panel box. White goes to the ground bar. Sometimes the white(neutral) is seperated from the ground. Sometimes they can be connected together. At the fuse box they both go to the silver ground bar. If you are attaching a cord and plug purchase one to match the outlet you have. Usually at the terminal block the hot wires are on the outside. Neutral in the middle. At the terminal block there is a metal strap or wire going from the center terminal to the frame of the stove. If the cord you have is just 3 wires leave it. If the cord you have uses 4 wires remove the strap and connect it seperately to the green or ground wire on the cord.
Jul 02, 2008 | Jenn-Air JED8230 Electric Cooktop
Amana 30" Self Cleaning Electric Range Stove W/ Oven Freestanding Black & Gray Logo
57 people viewed this question
Top Amana Cooktops Experts
Dan Webster
Dan Webster
Paul Carew
Thomas Perkins
Thomas Perkins
Are you an Amana Cooktop Expert? Answer questions, earn points and help others
