Question about Underwater Kinetics Uk Dive Light Sunlight C8 8 C Cell Yellow Waterproof Flashlight
Light dont work
Light doesn't work
My 2006 stratus sedan rear defrost dont work and will not light up
if you push on the rear defrost switch and it doesn`t light up then check the fuses with a test light. if the fuse is good then the defrost switch is likely bad.
Sep 17, 2014 | 2006 Dodge Stratus Sedan
Cruise control doesn't work on my lexus
cruise control best let garage check out,here are few things to check,check fuse and check to see if brake lights dont work.check brake light fuse if fuse okay brake light switch could faulty or bad connection then brake light will reset cruise control you apply brakes.if all is good problem could be speed sensor or accelerator pedal to ecm.you need diagnostic euipment to troubleshoot.
Sep 15, 2012 | 2002 Lexus IS 300
The fn keys dont work in my asus except for the fn+f7 one. when i press fn+f2 the led light goes on and off but it doesn't seem to work??? what should i do??
Hook a external keyboard to the laptop, if all functions checkout. The keyboard in the laptop will need to be replaced..
Mar 30, 2012 | ASUS Computers & Internet
Left and right signal doesn't work
Light fixtures are bad check with a light tester
Mar 19, 2012 | Chevrolet Cavalier Cars & Trucks
Radio, dome light and door open warning bell doesn't work
try changing fuses any way somtimes there dirty or coroted and dont make good contact even though they test good and look good still could be the problem
Mar 02, 2012 | 1997 Dodge Neon
It dont work
contact Whistler at info@whistlergroup.com and let them know what doesn't work on your detector. Does it not power up? does it not pick up radar? does it not make any sound? does the lights not work?
Sep 03, 2011 | 1640 Radar Detector
I installed a new brake light switch on a 1999 Chevy Cavalier. Changed the bulbs, and checked the fuses. My brake lights still dont work.
You might need to adjust the switch so that when the brake pedal is fully off, the brake switch is disengaged. You should be able to adjust it by screwing it either in or out. Make sure you have connected the wires and that they are fully seated.
If it still doesn't work chances are it is faulty.
Aug 01, 2011 | 1999 Chevrolet Cavalier
After having my 2006 santa fe serviced at 60000 miles, my cruise control doesn't work. I had it lubed, radiator flush, oil change, brakes checked, timing belt replaced, water pump replaced.
Try checking all of your rear brake lights to see if they are working.If you have a burned out bulb the control cannot complete the circuit and the cruise will not work. Dont forget the third brake light sometimes have more than one bulb in them so check closely to make sure that all bulbs are good.
Jun 11, 2011 | 2006 Hyundai Santa Fe
Driver`s window works, all the other windows do not .
My Cherokee has a window lock button on the driver door (A child safety feature). See if your is locked... push the button and try your windows.
Hope this helps... Good luck!
Sep 25, 2009 | 2004 Jeep Grand Cherokee
Transmission problem
take it to dealer for computer diagnostic check,this sounds like an ECU fault
Sep 15, 2008 | 2002 Volkswagen Jetta TDI
Underwater Kinetics Uk Dive Light Sunlight C8 8 C Cell Yellow  Waterproof Flashlight Logo
29 people viewed this question
Top Underwater Kinetics Camping, Backpacking & Hiking Experts
Tom Chichester
ray gallant
Are you an Underwater Kinetics Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
