Question about Frigidaire Refrigerators
Broken door bin
Lghs2655keo
Dyson dc07 clear dust bin will not close after emptying. Any time the bin is removed, the dirt falls out.
There is a lever that has a hook on the end that holds the door in the bottom of the dirt cup closed. If the little plastic hook gets broken the trap door will not stay closed by itself. The easiest way to fix this is to purchase a new dust bin. I have a bunch of them in my vacuum graveyard. You may call my store at 260 244-4696.
Apr 05, 2016 | Dyson Vacuums
Embassy shredder open door light won't go off after emptying bin. Therefore no shredding
The shredder probably has some kind of switch or sensor that detects that the bin is in its correct installed position. The interlock may be broken or blocked by paper shreds. An inspection inside the bin recess may reveal the cause so that it can be corrected.
Oct 19, 2014 | Office Equipment & Supplies
Fridigaire lghs2655keo
If your neighbor replaced the main board he must obviously know what he did and is doing.. Maybe he failed to connect something. Check with him first.
Mar 31, 2014 | Frigidaire Refrigerators
Underside of ice bin freezes up built up with frosty ice, dispenses no ice. numerous times we have defrosted with blow dryer, removed, cleaned bin, replaced; cleaned out ice that was built up in lower part...
W10224328 Dispenser Door Spring
The chute door is the reason your ice bin is freezing up and also the chute door being open draws warm moist air inside your freezer compartment causing massive amounts of frost and keeps the compressor runing all the time between defrost. You really n eed to get the chute door fixed. What is the correct model number? For the model KSRX25FT dispenser parts click HERE The chute door spring may be broken but you will not know untill you open the dispenser housing. I'm here should you post the correct model number or have questions, Sea Breeze
Oct 17, 2013 | KitchenAid Architect ® Series II KSRX25FT
Refrigerater - 3 door Model- N-400H, Bottam door (Vegitable bin broken. Looking for new / used vegitable bin.
That is not that hard to fix and you can easily buy the parts yourself online...
Here is a tip that will help you with the online buying...
How to Buy
Appliance Parts Online
heatman101
Jan 16, 2011 | Refrigerators
Ice maker dispenser is not functioning (crushed or cubed), Ice maker makes ice but does not dispense, motor seems to be frozen. Kenmore Elite 106.57703701 model refrigerator
Open the door and hold the door switch down and try the ice dispenser. Do you hear any thing.You should hear the ice door open and the augur motor turning to turn the augur which pushes the ice out the door. If the augur doesn't turn Take all the ice out of the bin and try. perhaps the motor is too weak or the augur is locked up. Take the bin out and try to see if the motor will turn with no load. The motor is behind the back cover where the bin sits. See if you get power to it using a voltmeter when you try the dispenser. If you are, probably bad motor. If not ,dispenser switch or solenoid is not working.
There is a solenoid that operates the door that could have stopped working. Can you hear it?
The hinge on the door could be broken or the bracket it goes in could be broken. You'll have to look to see what's wrong.
Remove the dispenser cover by gently prying starting at the bottom going round and round a little at a time to prevent from breaking it. When it's off the screws will be exposed to access the other components.
Dec 01, 2010 | Refrigerators
Broken trap door on dirt bin, can I just replace the door or do I need the whole bin
I have the same problem, and found the "trap door" available at http://platinumvacuum.com/dyson-dc07-bin-base-assembly-904279-10.html Since the part number is shown there, you may be able to find it elsewhere more easily using that. I will keep looking elsewhere myself.
Jan 27, 2010 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Broken Optibin door on LG refrigerator
I got a new bin from repairclinic.com, but the little nubs that hold the bin onto the door (in the thin plastic lining of the door itself) are snapping off. Sigh.
Jun 20, 2009 | LG LRFD25850 French Door Refrigerator
Frost build up on the ice bin
the ice door is not closing or not sealing .. maybe a broken spring or lever...you will need to replace that broken part..
Sep 13, 2008 | GE GSS20IEM Side by Side Refrigerator
Jenn Air model JCB2388AR, about 11 years old
We got heavy duty velcro and put it on the back of the bins. Works like a charm
Aug 08, 2008 | Jenn-Air 25.6 cu. ft. Side-By-Side...
Refrigerators Logo
10 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
