My I7 samsung laptop is turning on but shutting off
It is the np350e7ca01us. It sometimes gets to the start menu, but it will shut off shortly after. It is windows 8
    Sergeant:
  • 446 Answers
Check the fan
Posted on Apr 07, 2014
naslicer
  • 73 Answers
SOURCE: Travelmate 290 starts then shuts down
please re install the recovery software.
Posted on Dec 11, 2008
  • 51 Answers
SOURCE: My laptop turns itself of after 8 minutes - every time i turn my laptop on it lasts for about 8 ....
Sounds like something to do with a power saving feature either from HP itself or from Windows. It could also be that for some reason your computer is overheating, which it than shuts itself off to protect the processor. I would try playing with your power saving features, and cleaning out the fans.
Posted on Mar 13, 2009
zohail
  • 1223 Answers
SOURCE: My VGN FS920 shuts down at the window loading screen
ok no need to get a bcakup disk or downlaod anything
if ur hard drive is original factory fitted
and
ur laptop came with pre loaded OS as XP
then do this without disk
Sony: When you first turn on the laptop and see the VAIO logo screen, press the F10 key (you need to do this before the VAIO logo disappears).
pls let me know and rate me FIXYA for help
Posted on Apr 01, 2009
durtopian
  • 408 Answers
SOURCE: Problems with my HP G7000 Laptop
Sounds like a failing HDD and/or overheating.
Posted on Jul 31, 2009
SOURCE: Dell Laptop shuts off
Check PSU
Posted on Aug 05, 2011
Reset ram
are you sure its ram fault?is it beeping on start up?if so then replace ram.
some laptops shut off if the fan is not running and it gets hot.
clean fan out.
let me know if it still wont start.
Jan 08, 2014 | Samsung R540 Laptop
E6410 Bluetooth randomly shuts off
The mouse is the issue, check all connections and battery contacts, if unit can run on standard battery, " replace " to see if that will help, and make sure wfi plugged into laptop properly,also try another usb plug on your laptop.
Apr 02, 2012 | Dell Latitude E6410 Notebook PC Core i7...
Hi, My Samsung R580 I3 JBB2-US keeps on shutting down. If I close the lid when I re-open it shuts down & I have to restart or it freezes and I have to force restart. Sometimes when I boot up it...
You can try go to Start - Control Panel - Power Options and check what you want computer do when you close the lid of your laptop. Fix that and restart laptop to apply the setting.
If the boot up not complete and restart by itself, in my opinon, there is something wrong on the start up process, could be hardware malfuctions, could be a software not compatible. Try check the start up process to see.(use Start- Run: msconfig)
If this happen often, you should call the Samsung customer services to find out. Laptop i3 should still under warranty.
Hope this will help.
Thanks for reading
Jul 20, 2011 | Samsung R580 Notebook
I cannot shut down or restart my PC using the start menu prompts. The only way to shut her down is a hard shut down (manually turn her off).
There is a program that is failing to shut down in general, which is delaying the computers ability to shut down.
The next time you shut down, make sure you have no programs open. Then, while attempting to shut down, wait until Windows pops up window asking you to close a non-responsive program. When it does, take note of the program that it mentions, then close it and see if Windows shuts down. Note: sometimes this takes a really long time.
Try re-installing the non-responsive program and see if your computer can shut down normally again.
Aug 07, 2009 | Acer Computers & Internet
TV Turns Off Automatically While Watching
Stop trying to turn on the set. You are causing more damage. The hissing sound you are hearing is either a High Voltage Transformer on the SMPS (Switched Mode Power Supply) indicating a short somewhere in the set or some capicitors that have shorted out. Also there can be a CRT that is leaking cooling fluid onto the Main bd or the Power/Deflection bd or both bds. Have a trained Samsung tech troubleshoot the set.
Jul 15, 2009 | Samsung HCM4215W 42" Rear Projection...
On shutting down my laptop it gave the message, "installing 1 of 1" do not turn off your computer. It did not turn off all night. I turned it off by using the on/off button then shut it down...
When you start your laptop, press F8. You will get a menu (Normal boot, Reboot...). Choose Last good known configuration (something like that).
Aug 20, 2008 | Acer Computers & Internet
Shutting off
Try running it without the battery and see if it does the same. Sometimes a bad power supply will cause a short to develop in the battery. If it stops shutting down without the battery the you'll need a new battery.
Jul 03, 2008 | Gateway 6022GZ Notebook
Shutting off
i have the same problem...laptop randomly shuts down, but its even done it within a minute of turning it on so i don't think its a heat issue. Sometimes it'll run for over an hour with no problem and never shut down, but other times it randomly shuts down sometimes within a minute, sometimes maybe 10 mins, sometimes 30 mins or more ...its maddening! i'd love to find a solution if anyone's found one. Thanks.
Apr 22, 2008 | HP Pavilion dv1000 Notebook
Just shuts off when playing. Then restarts with BUILDING DATABASE message.
Just purchased this RCA MP3 player with 8 GB, and I can't seem to get it going.
Dec 26, 2007 | RCA OPAL M4001 MP3 Player
Computers & Internet Logo
21 people viewed this question
David Payne
David Payne
