Question about Nordic Track Nordictrack CX 1050 Elliptical Console
Elliptical cx1050 tension won't release
The pedals won't move. the tension on the rear wheel is looser on level 10 than it is on level one. this can be seen when took off the cover. when it is on 10 I can force movement. on 1 I can't move it at all.
Emergency brake not working after changing rear brake shoes on a 1990 gmc pickup 1500 series? And how do I release the emergency pedal from the floor? It won't release when you step on it?
Was the brake shoes replacement a DIY or professional job. If DIY, are you certain that you reassembled the brakes properly? Does the truck move at all? Does it feel as though the e-brake is applied? With the e-brake pedal to the floor, the truck should not move freely when the accelerator pedal is depressed. The emergency brake assemblies on both rear wheels are connected to a cable assembly that ultimately leads to the e-brake pedal. The cable has an adjustment point and a spring tensioner to prevent slack in the cable. First, crawl under and physically check the cable tension. If it's loose, either the cables are not connected to the rear wheels' brake assemblies, not connected properly, or the cable and/or pedal is damaged/broken. If the cable is tight - overly tight, but the e-brake is not holding the truck from moving, the e-brake levers attached to the shoes inside the brake drums are likely not installed correctly. Double check your installation and consider replacing the e-brake cable (as a precaution). As for the pedal, you may have to remove it in order to get the ratchet-locking mechanism to release.
Of course, if this was a professional job, call the shop and have them make it right. Good luck.
Oct 07, 2013 | Cars & Trucks
My 390 E is locked up and I can't move the pedals. I checked the belt, it's still on and it's tight.
follow this steps and fix it. God bless you
Electronics Problem You control the tension of the pedals using the buttons on the console. When you assemble the A.C.T. elliptical, you have to thread a group of wires from the console through the upright down to the electronics board. These wires communicate the resistance settings to the electronics board. If the wires twist, disconnect or break, the resistance will not work. You will need to reconnect or replace the wires.
Read more: http://www.livestrong.com/article/406522-tension-problems-with-the-nordictrack-a-c-t-elliptical/#ixzz2Z4kLeLBm
Jul 14, 2013 | Proform PFTL79807 - 850 W/ Gamefit...
Belt tension won't release to zero
please follow the next steps. God bless you
Check your owner's manual for diagrams and definitions. You'll need this information when you put the elliptical back together. You'll also want definitions in case you need to call the customer support line for assistance.
  • 2 Be aware that the resistance is often the part that requires repair. Resistance is managed magnetically, so often if the machine is working, but the resistance isn't setting correctly or at all, check the bolts that secure the magnets. If they are loose, the resistance will slip. If the bolts are fine, check the magnets themselves by using a refrigerator magnet and see if it is attracted or repelled by the your fridge magnet. If not, the magnets have de-magnetized and need to be replaced.
  • 3 Consider that if the foot pedals are attached with bolts, any slipping can be fixed with a quick use of the wrench. But if the foot pedals are damaged or breaking, order new foot pedals (see Resources below) rather than run the risk of a pedal breaking while you're on the machine.
  • 4 Check the hand bars. While not all people use them, as they can elevate your heart rate by up to 20 percent, they can become worn, too. While loose hand bars typically need a simple tightening of the bolt, be sure not to overtighten as the bolts can break.
  • 5 Know that if the axis is bent, it's likely you need a new machine. The axis is the central alignment of the elliptical. If the machine was used by a person who is over the maximum weight limit, it can be bent or damaged. It's not an easy fix and a better idea is to upgrade to a sturdier machine.
  • Dec 04, 2012 | Bladez X350P Elliptical
    Resistance on elliptical acting weird
    1) tight the bolts tension for magnet and clean very well. and proof..if the fail
    2) go to test the magnet, use again the magnet from your refrigerator magnet, for attraction and repulsion. If do not pass the TEST replace the magnet in any Hardware such home depot, etc.
    God bless you
    Aug 27, 2012 | Proform Nordic Track Elliptical Resistance...
    NordicTrack CX 1055 Elliptical ramp pedal wheels
    Hi, You can find them easily on amazon, click here ant take a look: Amazon com Elliptical ramp pedal wheels. Wish you best of luck. Cheers
    Jun 22, 2012 | Exercise & Fitness
    Just put together the proform 500 le elliptical and can't pedal. It seems like its stuck.
    Dear Sir:
    Check is sliping, if do use the tool wrench for adjustmente the bolts.
    2( See is the axis is not bend, if do you must replace it the machine, because is the hear of the elliptical.
    sincerely. God bless you.
    ernesto cuadra
    managua, nicaragua. c.a
    Mar 14, 2012 | Exercise & Fitness
    My Pro-Form 490 LE has a resistance problem--it won't adjust and it seems to be set on a difficult resistance, I can't really pedal it. how do I fix this? I tried switching the levels, but it doesn't...
    Open the rear part where the "guts" are. The magnet will be stuck against the wheel that turns when you pedal because the cable that the resistance motor pulls to remove the tension will have too much slack in it. The cable probably came off of the pulley wheel that is used to providing the necessary tension to pull the magnet off of the wheel.
    To get the case off, simply unhook the right side pedal, remove the 4 bolts holding on the crank thing to remove it, then using a philips head screwdriver, remove the screws in the screw holes on the case cover. Be sure to remove the one screw on the other side near the front in order to allow the front part to "unsnap".
    Jan 16, 2011 | Proform PFTL79807 - 850 W/ Gamefit...
    How to use the Proform 515S EKG Elliptical?
    To mount the elliptical trainer, firmly hold the handlebars or the T-handle and carefully step onto the pedal that is in the lowest position. Next, step onto the other pedal. Push the pedals until they begin to move with a continuous motion. Note: The pedal disks can turn in either direction. It is recommended that you turn the pedal disks in the direction shown below; however, to give variety to your exercise, you may choose to turn the pedal disks in the opposite direction.
    To dismount the elliptical trainer, allow the pedals to come to a complete stop. CAUTION: The elliptical trainer does not have a free wheel; the pedals will continue to move until the flywheel stops. When the pedals are stationary, step off the highest pedal first. Then, step off the lowest pedal.
    As you exercise, you can adjust the resistance of the pedals with the resistance knob on the console. To increase the resistance, turn the knob clockwise; to decrease the resistance, turn the knob counterclockwise.
    Jun 02, 2010 | Proform Exercise & Fitness
    Adjusting Padking Brake with 4 wheel disc brakes.
    Hope this helps. This is out of the factory manual. Let me know if this works for you.
    PARKING BRAKE NOTE: Tensioner adjustment is only necessary when the tensioner, or a cable has been replaced or disconnected for service. When adjustment is necessary, perform adjustment only as described in the following procedure. This is necessary to avoid faulty park brake operation.
    1. Raise vehicle.
    2. Fully back off cable tensioner adjusting nut at equalizer to create slack in cables.
    3. Remove rear wheel/tire assemblies. Remove brake calipers and rotors.
    4. Verify park brakes are in good condition and operating properly.
    5. Verify park brake cables operate freely and are not binding, or seized.
    6. Check park brake shoe adjustment.
    7. Reinstall rotors and make sure rotors turn freely.
    8. Reinstall brake calipers. Tighten guide pin bolts to 41 n·m (30 ft.lbs.)
    9. Reinstall wheel/tire assemblies after brake shoe adjustment is complete.
    10. Lower vehicle enough for access to park brake foot pedal. Fully apply park brakes
    NOTE: Leave park brakes applied until adjustment is complete.
    1. Raise vehicle again.
    2. Mark tensioner rod 6.35 mm (1/4 in.) from edge of tensioner bracket Adjustment Mark On Cable Tensioner Rod
    3. Tighten adjusting nut at equalizer until mark on tensioner rod moves into alignment with tensioner bracket
    CAUTION: Do not loosen, or tighten the tensioner adjusting nut for any reason after completing adjustment.
    1. Lower vehicle until rear wheels are 15-20 cm (6-8 in.) off shop floor.
    2. Release park brake foot pedal and verify that rear wheels rotate freely without drag. Verify pedal returns to fully released position.
    3. Lower the vehicle
    Mar 09, 2009 | 1999 Chrysler 300M
    Releasing Parking Brake
    adjust the park brake cable first (3 pedal clicks and brake should start to engage the rear wheels) then lube the park brake ratchet release parts (under the dash) with WD40, this should take care of the problem.
    Jan 12, 2009 | 2000 Chevrolet S-10
    Nordic Track Nordictrack CX 1050 Elliptical Console Logo
    Top Nordic Track Exercise & Fitness Experts
    Matt Olenzek
    Matt Olenzek
    Ross Metcalfe
    Ross Metcalfe
     Atlanta Fitness
    Atlanta Fitness
    Level 1 Expert
    Are you a Nordic Track Exercise and Fitnes Expert? Answer questions, earn points and help others
