Question about Adidas ADH4019 Watch
Change time on watch
I need to move the time forward 1 hour
I have a Pulsar watch need to change to day light saving time
just put the hour hand forward or back 1 hour
Mar 15, 2016 | Pulsar Watches
How do I change time and date on timex indiglo
  • How to Set Dial Indiglo Watches
    • 1Pinch the winding knob on the right side of the watch between your thumb and forefinger.
    • 2 Pull the knob out from the watch slowly until it clicks into the first position.
    • 3Turn the knob to move the hour and minute hand to set the time. Move the knob clockwise to move the settings forward and counterclockwise to move them backwards.
    • 4 Pull the knob out further until it clicks into the second position. In the second position (the one furthest from the face), turn the knob to set the calendar, if your Indiglo has one. Turn the knob clockwise to move the settings forward and counterclockwise to move them backward. Push the knob back in to the watch face when you are done.
    How to Set Digital Indigo Watches
    • 1 Press the button on the lower right side of your Indiglo watch to unlock the mode function of the watch.
    • 2 Press the button on the lower left side to move through the modes. Each time you are in a mode, the digital display will flash. For example, when the time display begins to flash, you are in the correct mode to set the time.
    • 3 Change the time (or date) by pressing the button on the upper right side to advance the numbers or the button on the left side to move the numbers down. When you do this, you will be changing the first set of numbers (the hour or month, for instance); to change the minutes, press the button on the right side of the face until the second set of numbers is flashing and begin the process again.
    • 4 Press the button on the lower left side of the watch to save your settings. The button on the upper left side of the watch is not used in this process--it is the switch to turn on your Indiglo light.
  • Read more : http://www.ehow.com/how_5758168_set-timex-indiglo.html
    Mar 31, 2015 | Timex Indiglo Watches
    How to set led watch
    What make and model of watch is this?
    Sep 08, 2011 | Watches
    My analog Guess watch has a date display only (no day). I have re-set the date over and over, but it changes the date at noon instead of at midnight.
    Your problem is caused by the fact that the watch is 12 hours out of step.
    Wind your watch forward 12 hours, reset the date if you need to and you watch will then change around midnight.
    (if you need to change the date more than one day, when it has past the change time, wind it back and then forward to step the date forward. You may have to experiment to see how far past the change point (in both directions).
    Jun 04, 2011 | Guess G85675G WristwWatch
    I have a Aerospace model watch and am having difficulty in adjusting the digital time to be equal to the minute and hour hand time.
    Its best to change on the hour.Stop your watch so that the second hand is pointing to 12.
    Move the hands to the time i.e 10am then advance the minute hand 5 mins past the hour, then turn it back to 10am, when the time comes push set and your hands are set.
    I think you might have not moved the minute hand forward 5 mins and back.
    You can now set your digital time from your hands setting.
    Oct 22, 2009 | Breitling Aerospace Avantage E7936210/G606...
    Changing from 24 hr system to 12 hr system
    • Press "MODE" (lower left hand button) three times to get to the screen where the numbers are blinking, indicating that you can adjust the time
    • Make note of the hour if you don't have another clock handy
    • Press "LAP/RST" (lower right hand button) once to get the hour numbers to blink, indicating that you can change them
    • Press "ST/STP" (upper right hand button) to move the hour forward until you go past 24
    • At this point, you will notice a little "A" next to the time to indicate AM, and if you keep going past 12 hours, it will cycle back to 1, this time with a "P" next to it to indicate PM
    Apr 18, 2009 | Lucien Piccard 26024 Wrist Watch
    Date change on my Tag Aquaracer Calibre S
    Do as follows:1) At any time of the day pull the crown out and advance watch hands forward for EXACTLY 12 hours ( for example: if it's 6.35 on your watch, then after advancing hands it will be 6.35 again, just minute hand will be forwarded clockwise 12 full circles, while hour hand will be forwarded 1 full circle). Push the crown back in.
    2) Pull the crown out to the date setting position and change to the desired date. Pull the crown back in.
    Now your watch will be changing dates at midnight continuosly.
    Rate me, please.
    Apr 06, 2009 | Tag Heuer WAF2110.BA0806 Aquaracer...
    Date function notworking properly
    Do as follows:
    Rate me, please.
    Apr 04, 2009 | Tissot Le Locle T41.1.423.33 Watch for Men
    Kenneth Cole Reaction watch date set problem
    I just dug my watch out after not wearing for a few years and had the same problem. There is an easy way to adust this watch's time and alarm, basically one way to enter both.
    1) With the watch in the regular time display mode (doesn't matter if 12 hour or military time), depress and hold the lower left hand button (mode button). After a few seconds the watch appears to shift to alarm mode and it is blinking. This puts you into the mode for adjusting the alarm.
    2) If you want to adjust time, date, etc rather than alarm time, after you have done step one, simply press that same lower left button again, and then it will put you into the time mode, but this time the time mode is blinking and you can adjust the various components (seconds, minutes, hours). You can only move minutes, hours, etc forward, no way to move backward. You will start off with the second display blinking, probably skip that unless you need to adjust seconds. Depress the upper right button to shift to the next option (minutes) and you will see the minute display blinking. Adjust the minutes by depressing the lower right button. When finished depress upper right button to move to next option (hours) depress the lower right button to move the minutes/hours/month/date forward as necessary, when you finish just press the lower left button again and it pulls you out of adjust mode and you are back in regular time viewing.
    I had to post this because I've had this problem in the past and it killed me. Its kind of intuititve after you get into the adjusting mode by pressing the lower left button- remember, initially it will put you into adjust alarm mode, but press again and you will get into adjust time mode.
    Oct 30, 2008 | Kenneth Cole RK5034 REACTION
    Kenneth cole reaction
    Jul 16, 2008 | Kenneth Cole RK5034 REACTION
    Adidas ADH4019 Watch Logo
    12 people viewed this question
    Top Adidas Watches Experts
    Ansel Alberto
    Ansel Alberto
    Vuk B
    Are you an Adidas Watch Expert? Answer questions, earn points and help others
