Question about LeapFrog Leapster 2 Learning System
Pen not working on screen to use
My son has got leapstar 2 green he cant get on as the pen is not responding to the screen
Hi, have you tried to recalibrate the screen as in your instructions?
Make sure you have no game inserted
Press and hold down the 'on' button and 'hint' button (with questionmark on it) at same time until a menu appears on screen
Press A
Now touch all the little crosses with your pen that appear on the screen
switch leapster off and restart
if still not working, repeat above
Posted on Aug 04, 2009
  • a_morales_20 Dec 31, 2010
    helllo i had a question which button has the question mark all the letters are erased from the leapster and i have no idea which one is the ? mark
I have purchase a Leapster 2 for my granddaughter. the pen will not let me sign in.What do I do?
Posted on Jun 07, 2011
The pen on my sons leapfrog leapster won't work
Push the "A" button to enter the calibration.
There will be a little plus sign. Touch it with the stylus and continue to touch the plus signs with the stylus until you return to the calibration screen.
Turn the Leapster off and then back on again without a cartridge.
Sep 05, 2012 | LeapFrog Leapster 2 Learning System
I am trying to connect leapfrog leapstar to computer and follow application but when I connect usb with computer the leapstar says Please click "Eject button" Where is the eject button? I've...
The Eject button appears when a Leapster2 handheld is connected and turned on. When you have finished configuring the Leapster2 handheld and your child wants to play with it, you can click the Eject button to disconnect the device. Once ejected, a message will appear letting you know that it is safe to disconnect the Leapster2 handheld from the computer. It is not really a "button" but a picture of a green button which says "EJECT". It should be located on the upper right corner of your screen.
Sep 20, 2011 | LeapFrog Leapster 2 Learning System
Leapstar turns on but when you go to sleet name on screen it nor working it displays anmed but will no proceed when using pen to tap screen
Try to uninstall and re-install the LeapFrog Connect and wait until it finish configuring and updated the software both on the PC and the console, It may takes 10-20 mins for it to complete updating.
One more thing, you have to make sure that you get latest LeapFrog Connect software from LeapFrog website instead of installing it from supplied CD.
Instead of 1 starter game and a few demo game that you get from Leapfrog Connect, you can also get more downloadable games for your Leapster 2. You can get it here:
leapster-2.blogspot.com
Jun 26, 2011 | Leapster 2
After charging our green Leapster 2. We turned it on and it won't allow me to get past name selection. It wont select the specified name. Its like the pen isn't working anymore. Can this be replaced?...
You can try calibrating the stylus pen before trying to replace it. Hope this works :) Here are step by step instructions straight from the Leapster2 website:
If your Leapster2 does not respond to the stylus pen, it needs to be calibrated. Calibrating the Leapster2 is easy:
1) Ensure that a game cartridge is not inserted in the Leapster2
2) Hold down the Hint (?) button while turning the unit on. Continue to hold the Hint button down until the LEAPSTER2 menu appears. Remember that you need to hold the "Hint" button down the whole time while you are pressing the power button, and releasing it.
3) The LEAPSTER2 menu will show the options Base Info, Cart1 Info, Cart2 Info, Cart3 Info, and Touch Calib. If you do not see this menu after powering on the Leapster2, turn the Leapster2 off and repeat steps 1 & 2 until you see the menu.
4) When the LEAPSTER2 menu screen appears, press the A button on your handheld.
5) Using the stylus pen, touch each of the crosshairs that appear
6) Restart unit
Jan 13, 2011 | Leapster 2
Touch screen stopped responding
that is major problen you are going the expertman shop your laptop open and repair
Jun 06, 2009 | HP Pavilion TX2000Z Notebook
The pen is not working
I think this is the same problem I had as well as ramongough who has a previous posting. I saw the reply to his from nicksdad and I did what he said and it worked. I suggest you try it. Here is the reply:
Remove the game cartridge, while holding down the button with the "?" turn the unit on. Then the screen should tell you to press the "A" to calibrate the stylus. Finish the calibration by touching the crosshair when it appears. After I did this everything was fine. Good luck .
Worked for me too. Best of luck,
Jun 01, 2009 | LeapFrog Leapster 2 Learning System
Touch screen not working
Hpoe this helps, had the same problem with my son's leapster2, took it back got a replacement and the same thing happened within 5 minutes of turning it on!! Finally found this advice on the net.
1) Ensure that a cartridge is not inserted
2) Hold down the Hint button while turning the unit on
3) When the LEAPSTER menu screen appears, press the A button
4) Touch each of the crosshairs that appear with the stylus
5) Restart unit
Good luck, seemed to work for ours
Dec 17, 2008 | Toys
Leapfrog Leapster touch screen
Got my son's to work. Used these instructions.
Question Why doesn;t my Leapster2 respond to the stylus pen? trnsp.gif Answer If your Leapster2 does not respond to the stylus pen, it needs to be calibrated. Calibrating the Leapster2 is easy:
1) Ensure that a cartridge is not inserted 2) Hold down the Hint button while turning the unit on 3) When the LEAPSTER menu screen appears, press the A button 4) Touch each of the crosshairs that appear with the stylus 5) Restart unit
Feb 11, 2008 | Nintendo Game Boy Advance Console
LeapFrog Leapster 2 Learning System Logo
698 people viewed this question
Top LeapFrog Toys Experts
Nikki  Mclean
Nikki Mclean
relojmesa
Crystal Turner
Level 1 Expert
Are you a LeapFrog Toy Expert? Answer questions, earn points and help others
