Question about Broan QS130WW Under Cabinet QS1 Series Allure I 30 Inch Range Hood, White, Quiet 1.5 Sones at normal speed, 220 CFM high setting, Fully enclosed design for easy cleaning, Standard large filters, dishwasher safe, Two-level light setting; dual halogen lamp d
Lights quit working on broad range hood
1 light sparked out of socket 1 light still worked now both quit
  • 3 Answers
The tiny metal tabs that contact the very end of the light bulb after it is screwed in making a circuit get pushed back too far when you tighten the bulb and with all the steam and muck eventually fail to make contact. shut down the power and use a tiny screwdriver to gently nudge the electrical contacts back up "a little cleaning wouldn't hurt either" look at the very bottom of your bulb, clean that too perhaps with a few strokes of a wire brush, gently put the bulb back in and you are good to go, mine did the same thing.
Posted on Jul 18, 2015
I have spagna vetro 36" stainless steel range hood 198B2-36 and I would like to replace the lights with LED - 120v my problem is; I can not find a vendor with this size lights.
!2VDc or 12VAc? If Dc check for a loose, corroded or greasy ground connection. Also check the center pin on the light sockets, they get flattened and coated, a good cleaning may solve your issues.
Sep 01, 2014 | Kitchen Ranges
We have sirius 900 built in. Lights (both) stopped working and apper fine upon inspetion. Fan works fine. I can also hear the light switch click every time switch is depressed. Help. Thanks.
You need to trace the path of the current (voltage) Start at the light and work backwards. Check for 110Vac at the socket. If its there you have a bad bulb, if not keep going backwards towards the switch until you find 110Vac. When you find it the problem will be in between the last 2 points you checked.
Aug 13, 2014 | Sirius Hoods SIU3 90 SS Island Range Hood
Hood lights not working
Faulty switch for the lights? Measure the voltage in the lamp sockets - if you don;t know how, find someone with electrical experience to check it out.
Nov 21, 2013 | KitchenAid KHTU165RSS Stainless Steel...
The lights and fan have quit working. Power to the hood has been confirmed.
Many times this is because the fuse is blown...the fuses are at many different places...to find it follow the wires after they enter the range hood till you find the fuse...replace with the same fuse amperage and type...
heatman101
Mar 18, 2011 | Kitchen Ranges
Viking 10 inch hood lights out
do the heat lamps work?? or is it the 4 bright lights you are having the problem with??
Apr 05, 2008 | Viking VWH3048 Kitchen Hood
Light doesn't work on Kenmore Model 55022 Range hood...
If you're getting 120V at the lampholders, yet it's not lighting lamps that still work perfectly well in other fittings, two possibilitiesspring to mind.
One is that the cap on the bulbs isn't quite compatible with the fitting. Assuming they're some variant of Edison Screw, make sure that the centre terminal in the lampholder is sticking out far enough to touch the terminal on the bulb. Also check whether the lampholder achieves it's outer connection just with a small tab, rather than with the whole of the threaded ring. If so, make sure that this is going to touch the appropriate part of the bulb.
The other possibility is that you've got a high resistance connection somewhere - not enough of an open circuit to drop the 120 V when feeding the Megohm load presented by a meter, but more than enough to kill the supply when you have a lamp load. Only way to chase this is to use the meter on ohms range to bell out all the wiring between the lampholders and bits of the system which do work properly.
A.
Apr 05, 2008 | Kitchen Ranges
If you have 120VAC on the center contact of the light socket, and a working fan, but the bulb won't light...the most likely cause would be a disconnected neutral wire (white) in the light wiring inside the hood....assuming everything else is wired correctly.
If you're comfortable with further electrical testing...let me know, and I can describe a detailed procedure to check the status of the neutral wire. Otherwise, you may need the assistance of someone familiar with electrical troubleshooting or appliance repair.
Jan 27, 2008 | Kenmore 51840 Kitchen Hood
Lighs
Saint...first...have a look at the bulbs. Make sure the bulbs are 'really' good and that the sockets are clean inside and undamaged. Second, the switch might be bad.
Nov 15, 2007 | Broan-NuTone Broan Range Hoods Deluxe...
Broan QS130WW Under Cabinet QS1 Series Allure I 30 Inch Range Hood, White, Quiet 1.5 Sones at normal speed, 220 CFM high setting, Fully enclosed design for easy cleaning, Standard large filters, dishwasher safe, Two-level light setting; dual halogen lamp d Logo
90 people viewed this question
Top Broan Dishwashers Experts
Owen Barnes
Are you a Broan Dishwasher Expert? Answer questions, earn points and help others
