Question about DeLonghi Coffee Makers & Espresso Machines
E380 manual Red flashing light still after end scaling
Delonghi EC850 coffe mashine red light are flashing
I have a Delonghi Figaro and the red led flashing means:
The unit has run enough times to likely be scaled, this is a reminder to run weak acid (vinegar or citric acid) through to descale. Then rinse twice with clean water.
Scale will slow the brewing process so if it's brewing slowly you should do this regardless of the LED.
The LED can be reset by pushing <Prog.> and <On.> at the same time.
Of course, none of this is in the manual.
Sep 14, 2012 | Coffee Makers & Espresso Machines
Flashing red light
This is the machine's way of indicating that it is time to de-scale. It simply counts the number of times that it has been used to brew coffee, and after a set number of cycles, the light begins to blink. It does not interfere with performance, but it can be a major pain to tell when it is on/off.
To de-scale, they recommend you run a solution of citric acid through the coffee maker (diluted vinegar would probably work just as well), followed by three cycles of plain water to clear any leftover solution.
To get the red light to stop flashing, you need to press the "prog" and "drip/auto" buttons at exactly the same time. You don't need to hold them down, just need to time the press at exactly the same time. This resets the counter.
Sep 26, 2010 | DeLonghi Caffe Figaro BCO110 Espresso &...
I have an Acer Aspire E380 desktop. Does it
It should not matter as long as the antenna is not surrounded by metal.
May 08, 2010 | Acer Aspire E380 - Athlon 64 X2 4200+ 2.2...
How do you turn it off
Around the back the flash has an on/off button that glows green to show power on, a ready light that glows orange when the ringflash is charged this doubles up as a test button. There’s also a 2.5mm sync socket for the flash sync cable and an exposure scale.
On the front is an auto manual switch. If you set to auto the sensor on the front of the flash cuts the power so it’s correct for the auto aperture that’s been selected. You determine which aperture to use via the scale on the back.
Apr 06, 2009 | Vivitar 5000 Ring Light Flash
Motherboard not recognizing usb Ports
chk in your device manager if they are blocked or not. control panel and then open system and hardware and then device manager scroll down and see if you have any USB marked in Red if its there then right click on it and enable it. if still fails try doing a system restore or you should need to install a new version of windows. that's the same issue i encountered and i end up in reinstalling a new version of windows. cheers !!! :)
Mar 26, 2009 | Acer Aspire E380 - Athlon 64 X2 4200+ 2.2...
Dont know what red light is flashing for because ive lost the ins
hello the red ligth is flashing, because to much coffee or u need to clean the machine cleane with sal and liqued soap thanks
Feb 24, 2009 | DeLonghi EAM3200 Espresso & Coffee Maker
Vivitar 283 flash
Please check the trigger voltage.
What, how do I do that, you said!!!!!!!!!?
Here they are:
1. Four fully charged or new batteries into 283.
2. You needs a DVM (Digital Volt Multimeter).
3. Set DVM: DC scale, higher than 10 scale.
4. Black Lead to black DVM and Red Lead to red DVM.
5. Turn ON the Vivitar 283 and wait until light turns Green.
6. Place Black Lead to Outside Silver Contact of the flash.
7. Place Red Lead to Center Silver Contact of the flash.
8. What is the voltage reading? Read the max. V.
9. Anything under 8VDC will be fine.
10. Some versions will be high.
Hope they are helpful to all photographers.
Truly,
Alexander
atdlee@netzero.com
Dec 10, 2007 | Vivitar 283 Flash
Coffee Makers & Espresso Machines Logo
13 people viewed this question
Top DeLonghi Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Shehu Pro
Shehu Pro
Are you a DeLonghi Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
