Question about Brinkmann Grilling
Gril need instruction manual
8888 display
You need to test the electrical components did this happen during a thunderstorm?
Mar 24, 2014 | Whirlpool Ovens
I desperately need parts for my Ford Ranchero (1977-1978) bakkie, like the front gril and back indicator lights. Please help!!!
Register on e-bay and search for those parts. Keep narrowing your search until you find those ranchero parts.
Aug 13, 2013 | Vehicle Parts & Accessories
I just bought a Char-broil,BBQ&Gril..I need to know when smokeing where do I put the meat and do I put charcoal in the fire box with the wood chips AND charcoal in the grill side where the meat goes...
Here is a link to the owners manual for one of Char-broils grill smokers. It may not be the exact model you have (you failed to mention the model #), but they all basically work the same way.You will find how to use the smoker under the section entitled "Preparing & using Your Silver Smoker". You can download and print the manual for future reference.
http://www.charbroil.com/bps/char-broil/char-broil/knowledge/42804297%2007201560%20im%20english_9cec707e-1_.pdf
Enjoy your smoker and thanks for using FixYa.
Sep 09, 2011 | Grilling
Where do i find propane to natural gas conversion kit for weber spirit e310 gril
Apparently, Weber does not make a conversion kit to convert the grill from propane or from natural gas to propane. According to the Owners Manual - "Liquid propane gas is not natural gas. The conversion or attempted use of natural gas in a liquid propane unit or liquid propane
gas in a natural gas unit is dangerous and will void your warranty." (From Page # 3 of the Owners Manual)
See below link.
http://www.weber.com/help/manuals/pdf_files/2008_updated/89525_030308_2008.pdf
Feb 23, 2011 | Weber Spirit? E-310 Propane Grill
Projector turns on, bulb comes on and then turns off and led flashes green
this is often caused by the projector overheating. You will need to clean out your filters. They can often collect dust and if the projector overheats it will turn off like you suggest. Refer to your manual about cleaning filters as it changes with each model. Get some canned air ideally and give it a spray around the projector and the grils.
Good luck and any more help needed, just ask
Dec 03, 2009 | LG RD-JT91 Multimedia Projector
3 burner charmglow gas gril
I am replacing burners and I need to know if the burners if they go tightened or loose.
Oct 20, 2009 | Brinkmann Charmglow Stainless Steel LP...
My whirlpool fan assisted oven is not heating the fan is blowing cold air out, my gril and my hobs work fine
Sounds like you need a new fan element. You'll need to quote your model to ensure you get the correct element. A lot of Whirlpools can be done from the inside so the oven stays in the housing. Don't forget to power off first though! :)
Jun 21, 2009 | Ovens
Hotpoint EW81 Dual Oven Cooker
Installed the new Dual Regulated switch which operates the Gril, but have got the wires inserted incorrectly. Need help wiring it up.
Wires are 2x Red,Black,brown,gray,Yellow and a red link wire which came with the part
New switch is a Diamond H - 48ER101C1P.
Numbers on switch are S1,P2,2,P1,4,S2
At the moment I have no cooker - help.
Sep 08, 2007 | Ovens
Grilling Logo
Top Brinkmann Grilling Experts
Paul Carew
Dan Webster
Dan Webster
Gary Kenady
Gary Kenady
Are you a Brinkmann Grilling Expert? Answer questions, earn points and help others
