Question about Samsung 1.8 Cu. Ft. Over-the-Range Microwave
Stopped work while in use
Microw. just stopped working during use no power model no. SMH9151B
Powergard inverter 1000w nn-cd987w
Fixya does not sell replacement Powergard inverters.
Oct 19, 2016 | Panasonic Microwave Ovens
Microwave door doesn't close properly
The service manual for model SMH9151B is here.
You can order Samsung parts by part number from the Pros here.
<- Let me know if I can help further.
Jan 20, 2014 | Samsung SMH9151 Microwave Oven
SE ERROR
I am not sure, ask the dealer
Mar 12, 2013 | Microwave Ovens
JVM 1790sk01
Cook using microwaves or convection in this stylish microwave oven that allows your food to be flavorful beautifully browned and cooked quickly .now your microwive didn't work .you should take it to fix .
home light bulbs
May 03, 2012 | GE Profile Spacemaker Over-the-Range...
Microwive not heatin
Ufortunately the magnetron is the most likely problem, "heats food" and is the heart of the microwave oven. If the device is five years old or more cheaper to replace the item.
Mar 04, 2012 | Sharp Microwave Ovens
The display panel readout has a 5E or possibly a SE on the dislplay constantly
SE error means you have a shorted membrane keypad.
You have a shorting membrane keypad. If and when an oven is coming on or doing anything by itself, this is very dangerous and can result in a fire.
So until it is repaired, please leave it unplugged or leave the door open when it's not in use, and of course one should never leave a microwave unattended while cooking.
We would need the model number in order to provide you with free assistance.
It will be one of these:
SMH9151B
SMH9151B/XAA
SMH9151B/XAC
SMH9151BE
SMH9151BE/XAA
SMH9151S
SMH9151S/XAA
SMH9151ST
SMH9151ST/XAA
SMH9151ST/XAC
SMH9151STE
SMH9151STE/XAA
SMH9151W
SMH9151W/XAA
SMH9151W/XAC
It is usually found on a tag located inside the cooking cavity or around the door frame or controller frame.
Since FixYa is still not notifying us when you respond to clarification requests, you will have to post a new help request with your model number and symptoms / questions, or you may contact us here for this free assistance.
In some cases, it is a simple do it yourself repair.
Sep 18, 2011 | Samsung SMH9151 Microwave Oven
SE error on Samsung SMH9151B. Where so I find the assembly part to order?
"SE" error means you have a shorted membrane keypad.
The full model number from the tag on the oven should be one of these:
SMH9151B/XAA (service manual)
SMH9151B/XAC (service manual)
SMH9151BE/XAA (service manual)
I've included the service manual link for each one for your convenience. They'll help you with disassembly and in getting part numbers.
You can order parts by entering part numbers or your full model number from the tag on the oven here.
There are three ways you can fix this, with the last probably being the best:
1. Replace the membrane keypad ("switch membrane"). The cheapest way but the hardest. If you (or someone you know) might want to replace it yourself, I have uploaded a handy guide with pictures showing you what's typically involved. It's here.
2. Replace the control panel frame assembly ("assy control panel"), which comes with a new keypad on it already. Pretty easy, not expensive.
3. Replace the entire controller ("assy control box"). Very easy, and usually not much more than option 2.
No matter which option you prefer, at our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Some connectors on the relays may have a lock:
May 23, 2011 | Microwave Ovens
Do you have glass microwive model bmo 700 (17 lt)
That is not that hard to fix and you can easily buy the parts yourselfonline...
Here is a tip that will help you with the online buying...
How to Buy Appliance Parts Online
heatman101
Sep 15, 2010 | Microwave Ovens
Microwave keypad does not respond and screen reads SE
The exact part you need will depend on the model number, which will be one of these:
SMH9151B SMH9151B/XAA SMH9151B/XAC SMH9151BE SMH9151BE/XAA SMH9151S SMH9151S/XAA SMH9151ST SMH9151ST/XAA SMH9151ST/XAC SMH9151STE SMH9151STE/XAA SMH9151W SMH9151W/XAA SMH9151W/XAC SMH9151WE SMH9151WE/XAA.
On some models, you can just order a new membrane keypad and replace it. It's cheap, but a lot of work.
On other models,
the membrane keypad is not available as a separate part, so you would have to order the control panel frame assembly which comes with a new keypad.
In this case, you simply move your circuit board into the new frame. That is a simple do-it-yourself job, but it costs more.
Feel free to contact me directly (and please remind me of your full model number) for more information & help and a free estimate for us to do it for you.
Aug 20, 2010 | Samsung SMH9151 Microwave Oven
Microwes panasonic nn-t553w
hi, check that the cooling fan is operating and to sufficient speed to cool the magnetron or the thermal cutout mounted to the magnetron will cut power
Mar 06, 2009 | Panasonic NN-S753 Microwave Oven
Samsung 1.8 Cu. Ft. Over-the-Range Microwave Logo
23 people viewed this question
Top Samsung Microwave Ovens Experts
William Miller
William Miller
Henry  Thomas
Henry Thomas
Are you a Samsung Microwave Oven Expert? Answer questions, earn points and help others
