Question about Casio Exilim Card EX-S100 Digital Camera
Lens error on exilim casio camera
Tried to reset camera and changed the battery, but that did not work. I can look at the pictures I took but cannot take new pictures
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Casio Master
  • 102,366 Answers
SOURCE: Casio Exilim EX-Z850 Red Light Flashing
I have been having this same problem. It doesn't happen everytime, but there have been a number of occasions when my Exilim Z850 would display a blinking red light and refuse to take pictures. I thought it was a battery issue, so I tried buying a new battery, eventhough I observed this problem soon after the camera was newly purchased. The new battery didn't help resolve the issue. So I do hope someone out there has figured out what's wrong and will let us know.
Posted on Dec 27, 2007
  • 34 Answers
SOURCE: Casio EXILIM camera lens will not extend fully!!!
It's the focus lens gears. The often times get knocked out of alignment by an impact, or debris gets in there. This can be fixed, but Casio won't help. Hint...google my username. ;)
Posted on Jan 25, 2008
SOURCE: Casio lens stuck
YEA!!! We just tried using the palm of our hands and it worked! Needed some muscle power, but hey, whatever helps!
Posted on Feb 17, 2008
  • 104 Answers
SOURCE: Casio Exilim Z40 - Lens Error Message
You can try to "fix" this problem by holding down the shutter release button as soon as the camera power up.If this does not work you will need to replace the lens assembly. This should only be done by a qualified tech.
This is usually caused by one of two circumstances. (1) The user dropped the camera while the lens was extended causing a mechanical failure. (2) The lens attempts to extend while in a pouch or pocket without the user's knowledge. This usually happens when the user is carrying the camera with the battery in. When/if the REC button or power button is pressed accidentally, the lens will attempt to extend but can't. This causes the servo motors to "smoke".
Posted on Apr 25, 2009
al-sultan
  • 250 Answers
SOURCE: Casio Exilim lens stuck half out.
Do these step by step
1.Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on.
2.Remove the batteries, then remove the memory card. Then install the new batteries, when you turn it on it should come back to life. Error E30 means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
4.Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
5.Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum.Be careful
the following steps are littile bit dangerous.do it at your own risk
6.3Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
7.Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera. The following photo illustrates unseated guide pins that would cause a lens error.
Posted on Jul 26, 2009
I have a Casio Exilim EX-Z33 and i dropped it a while ago and it continued to work (kind of, the images were a bit blurry). i took a picture five minutes ago and then turned it off. the lens went in but...
Sounds like the focus motor came loose - you need to take it apart and repair the gear that drives the lens assembly for focusing. The noise you're hearing is the motor trying to focus but since the lens cannot focus it continues to run and signals an error.
Feb 03, 2011 | Cameras
Lens error and green light flashing
Greetings,
power related issue.
check your batteries - charge or new
fxnlogo_s.png Technical Support, Instructions & Repair Service
Jun 23, 2008 | Casio EXILIM ZOOM EX-Z60 Digital Camera
Is there a way to "restart" my Casio Exilim EX-Z700? While I was taking a picture it seemed to freeze while it was trying to display the picture I just took - then, with the lens still popped out the...
Normally changing the battery solves this.Make sure you replace it with a good quality new battery and make sure it goes in the right way around as when you get in a flap it often ends up in the wrong way!
Jun 11, 2009 | Casio Exilim Zoom EX-Z700 Digital Camera
It wont turn on and there is a red flashing light
first check your batteries ,whether they are charged or not?and also try the hard reset method ,that is,remove the batteries and keep it removed for half an hour and then insert the battery and try again,it will help you
Aug 04, 2008 | Cameras
Lens error
If you cannot find a solution to your problem you may want to email fixityourself@gmail.com. He has good advice and good used parts at a fair price.
May 12, 2008 | Casio Exilim EX-Z750 Digital Camera
Zoom lens and on/off
That is what Casio calls a "lens error" and can only be fixed by sending into repairs or taking to an authorized service center.
Mar 31, 2008 | Casio Exilim EX-S600 Digital Camera
Casio ex-s600 frozen
I just took the battery out and then put it back in.
hehehehe
Mar 06, 2008 | Casio Exilim EX-S600 Digital Camera
Turning off Automatically
Thanks for the response. I actually took some advice to send it back to Casio. it was a little over the one year warranty but they fixed it for me for free and it works great now! I just fibbed on what day I received it as a gift. Its was a lens problem caused by dropping it.
Oct 26, 2007 | Casio Exilim EX-Z57 Digital Camera
Blurry pictures, and zoom not working
yeah the same thing happened to my camera last month and I just went to the repair place yesterday. Apprently Casio products arent that sturdy so if they get hit the lens can become misalligned and you can't fix it yourself. A new lens is more than the camera itself so if you have to get a new camera I wouldnt suggest another casio one. Good luck.
Aug 13, 2007 | Casio Exilim EX-S600 Digital Camera
Casio lens stuck
I noticed that the lens was sticking out on center. After pushing it a little, it clicked and then everything worked fine again. I hope that's what happens for your camera, too.
Jun 03, 2007 | Casio EXILIM ZOOM EX-Z850 Digital Camera
Casio Exilim Card EX-S100 Digital Camera Logo
87 people viewed this question
Top Casio Cameras Experts
mohamed salim shaikh
pontelemon
pontelemon
Are you a Casio Camera Expert? Answer questions, earn points and help others
