Question about ASUS 32GB Google Nexus 7" Tablet with Wi-Fi
Nexus 7 turns on to the x will not open
Turn on to the x runing
Will not turn on
If the battery is too low, you will need to let it charge for a while before you can turn it on.
If it doesn't work after say 30 minutes of charging, here are some more troubleshooting steps from Google:
Nexus 7 won't charge or turn on
Jan 30, 2014 | Google Nexus 7
My Nexus 7 will not turn off and I have no picture.
press and hold the power button until it restarts it should reset
Jan 22, 2014 | Google Nexus 7
My nexus 7 tablet fails to turn on.
Plug it in to give it a full charge. Push the on/off button and hold it in until it turns on. It may take about a minute. I had the same problem with my Nexus 7 because I let the battery get too low and it would not turn on.
Jan 17, 2014 | Nexus Tablets & eReaders
Google nexus 7 will not power up
Press and hold Volume Down, and then press and hold Power simultaneously until the device turns on.
Hope that helps!
Sep 09, 2013 | Google Nexus 7
My nexus 7 will not turn on
You can try a hard reset. Hold down the power button and the volume buttons at the same time. The device should then power on and you can follow the on-screen prompts.
Hope that helps!
Mar 18, 2013 | ASUS Google Nexus 7 8GB Tablet Unlocked...
My nexus 7 is not turning on anymore. It's been charging for days. Any ideas?
The battery connector in the Nexus 7 (2012 model) is notoriously problematic. Sometimes dropping the device can cause issues that prevent the Nexus 7 from charging altogether. A hard reset may not work. Fortunately, it is quite easy to fix.
However this will void your warranty. Pop the back of the Nexus 7 case open by pushing a credit card or guitar pick or small screwdriver under the edge of the black plastic case. Start from the top and gently pry the case open, working your way around. The back of the case will come off quite easily. The battery occupies the bulk of the left-hand side of the unit, and a group of six wires come out of the top of the battery to a connector on the circuit board. Gently push the plug out of the socket connector, wait 15 seconds, and push it back in. Snap the case back on and plug in your charger. You should now see the battery charge image appear.
Mar 06, 2013 | Tablets & eReaders
Nexus 7 screen broken and back slightly popped
It sounds like the device is completely broken after dropping it. You may find a local repair shop or a shop online to fix the device, but it may be cheaper to replace it with a new one.
Hope that helps!
Feb 24, 2013 | ASUS Google Nexus 7 8GB Tablet Unlocked...
Nexus 7 will not completely turn on
Pop the back of the Nexus 7 case open by pushing a credit card or guitar pick or small screwdriver under the edge of the black plastic case. Start from the top and gently pry the case open, working your way around. The back of the case will come off quite easily. The battery occupies the bulk of the left-hand side of the unit, and a group of six wires come out of the top of the battery to a connector on the circuit board. Gently push the plug out of the socket connector, wait 15 seconds, and push it back in. Snap the case back on and plug in your charger. You should now see the battery charge image appear.17d253bb-4ba9-4ee2-99ca-91507603cc78.png
Dec 05, 2012 | ASUS Google Nexus 7 Tablet
ASUS 32GB Google Nexus 7" Tablet with Wi-Fi Logo
18 people viewed this question
Top ASUS Tablets & eReaders Experts
Are you an ASUS Tablet and eReader Expert? Answer questions, earn points and help others
