Question about Air Tools & Compressors
Inlet tap 3310250
Broken inlet tap part no.3310250
Diplomat ADP8342 won't fill with water
Assuming the water tap is open and the water pressure is correct, it is likely the inlet water valve in the dishwasher is faulty. If you hear a click at the time the cycle starts but still there is no water then the inlet valve needs to be replaced. Also check the inlet hose for any kinks or blockage of the filter attached to the tap inlet.
The inlet valve looks like this item
Diplomat ADP8342 Solenoid Valve
Aug 05, 2014 | Dishwashers
I have a new Bradford white 40 gallon gas hot water heater. There are no single handle faucets. The hot water fluctuates between hot and cold. When I close both inlet and outlet shut off for the hot water...
Sounds like water leak.
For example, broken pipe... or water running out of TP valve.
That would explain variable hot-and-cold water at tap.
Turn off all taps, and observe if water meter is registering water usage.
Jun 15, 2014 | Water Heaters
Red and orage lights are on - continuous beeping
It would be helpful if you are able to record the lights that are blinking.
Most likely the flood switch at the base of the diswasher under the bottom drawer has tripped. There is water leakage caused either by a broken hose or broken drawer lid seal.
The easiest way to confirm is to turn the power off at the power socket and shut off the water inlet tap. Pull open the bottom drawer and use towels to dry off the base. Use a hair dryer to fully dry the base. The flood switch is located on a small circuit board in the middle of the base. Wait for a couple of hours and then turn the power and water inlet back on. See if the beeps stop.
Dec 18, 2011 | Fisher and Paykel 23 in. DD-603SS Built-in...
Jobmate 3 gallon air compressor parts list/diagram
Good luck on this one. I own 2 jobmate compressors, one I bought and used very little before it blew apart and another a freind gave me to use for parts. Guess what the same part failed on both and I know of at ;east three more that also failed the same way.
I gave up trying to deal with Canadian Tire and Jobemate and junked them, as though they weren't junk to begin witn. You get what you pay for. I have a new Hausefield compressor and it is fantastic.
Feb 23, 2010 | Air Tools & Compressors
Washer code le ?
Possible Cause:
• Water supply is not adequate in area.
• Water supply taps are not completely open.
• Water inlet hose is bent.
• The filter of the inlet hose clogged.
Solution:
Check another tap in the house.
Fully open tap.
Straighten hose.
Check the filter of the inlet hose.
Jun 17, 2009 | LG WM-1832C Front Load Washer
Side inlets of pool heater are stripped, how do I replace the inlets where the bolts go?
The simplest solution is to tap the hole up to the next size bolt. You'll need a small tap & die set, a drill, and the drill bit recommended for that size bolt -- it'll be stamped on the tap.
To accommodate the larger bolt you may have to drill out the holes through which the new bolts are installed -- maybe not.
May 27, 2009 | Teledyne Laars Laars Lite 2 Pool Heater...
IE Err
In my LG Manual, They IE error is water inlet trouble.
Possible causes
  • water supply taps are not completely open
  • water inlet hose are kinked
  • the filter of the inlet hose are clogged
Solutions
  • Check another tap in the house
  • Fully open tap
  • Straigten hose
  • check the filter of the inlet hose
Not sure if this helps, it's what is says in my book.
Good luck.
May 27, 2008 | LG WM1815CS Front Load Washer
Error message: water tap closed .
check water inlet valve clean of rubbish from water inlet hose
otherwise water inlet valve maybe faulty
Dec 08, 2007 | Bosch Axxis WFL 2060 Front Load Washer
Air Tools & Compressors Logo
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
