Question about Garmin nuvi 1350 Car GPS Receiver
Does not turn on with car charger
Car power does not work
  • Garmin Master
  • 2,130 Answers
Common problem with the 13xx & 14xx is a loose USB port.
1. Check fuse in tip of charger.
2. Make sure lighter outlet works - no blown fuses.
A loose USB port will prevent power reaching the unit from the charger and will prevent the internal battery from being able to be charged. More information can be found here:
SHARCNET USA Out of Warranty GPS Digital Camera Repair
Posted on Mar 31, 2014
Tomtom GPS does not turn on
HELLO!!
Charger gets very hot means the problem lies with charger which is not supplying the power to the system ... Try changing the charger ... and the charger wont cost u more than 15$
CLICK HERE TO BUY
GUD LUCK!!!
Dec 27, 2007 | Tomtom ONE GPS Receiver
I had to buy a new in car charger for my navman s30,but when i plug it in to the sat nav & cigerette socket it keeps showing a computer,usb & navman picture.
  • Turn the Navman off by holding the power button in the upper left corner of the device until the screen goes blank.
  • Plug the unit into its charger using the USB port on the bottom of the unit. The battery indicator light next to the power switch should turn orange, indicating that the device is charging. Once the light has turned green the charge is complete. If the light does not turn on, verify that the car charger is plugged into a working outlet.
Jun 19, 2012 | GPS
My Nextbook wont turn on
Although it is not recommended for normal operation, try turning it on with the charger plugged in. If this works, check the battery status indicator. If it shows a full charge, try disconnecting the charger. If the Nextbook quits working, the battery is bad.
If it does not turn on, try holding the power button for five seconds, then while holding the power button on, plug in the charger and continue holding for five seconds. If nothing happens, release and press the power button again with the charger still plugged in. (This may reset the internal power management chip.) Also, try the recessed reset switch (see your owner's manual).
If none of this works, verify that the charger unit is good. The simplest and safest method is to measure the output voltage on the output plug with a digital multi-meter while the charger is plugged into an AC outlet. It should be within 5% of the nominal output voltage on the charger label.
The most common power problems are battery failure, broken charger wire (usually next to the plug or the power conversion box), or broken charger jack in the unit.
Jan 10, 2012 | Office Equipment & Supplies
I brought it at a sale need to turn it on the power to see if it
a car charger? You can test it by plugging it in your car, then use a multimeter to meter the voltage from the connector pins.
Most car chargers also have a small let light that indicates when the product is on.
I'm giving this advice under the impression that you have purchased a car charger (that is what you have posted it under) So if this is not a car charger please let me know before rating my solution negatively.
Jul 29, 2009 | Palm Car Charger For V Vx
Doesn't turn on or charger is not working
this has happened to me before. the battery is probably dead. so you so buy a car charger and plug it in and the power should be restored since the car battery is powerful. i did it and it worked easily.
May 06, 2009 | SanDisk Sansa Fuze MP3 Player
Durabrand moddur1800 9V 2.2 Amp
There are 3 or 4 chargers listed on ebay.
Jul 29, 2008 | Durabrand DUR-1700 Portable DVD Player
My coby mp3 player only work while charging.
the power switch is fragile - if you break it then you cannot turn on the player. plugging in the charger will turn it on but only while the is power coming from the charger.
Dec 26, 2007 | Coby MP-C7085 MP3 Player
LG vx8300 phone will not turn on
dunno. try to have it on the charger, and at the same time try to push and hold the power button. try it a couple times. my v180 from motorola did that and it seemed to work.
Sep 18, 2007 | LG VX8300 Cellular Phone
Garmin nuvi 1350 Car GPS Receiver Logo
53 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
