Question about V-Twin Horizontal OHV Engine with Electric Start - 610cc, GX Series
I can not find the timing marks on a honda gx610??? Help!!!!
  • dennis73 Jun 16, 2009
    thanks for the help but not the problem. I have a 18 hp honda gx610 motor apaet and there is no timing marks on the crank gear, I need to no how to put it back together with out any timing mark to line up the cam shaft gear with thanks for any help!!
  • 53 Answers
Make your own timing marks with a piece of chalk. The important thing to remember is the timing mark should be in the same place (if using a timing light) and not bounce around.
Posted on Jun 15, 2009
  • Will Newnham Jun 15, 2009
    Make your own timing marks with a piece of chalk. The important thing to remember is the timing mark should be in the same place (if using a timing light) and not bounce around. Adjust timing
a 6ya Mechanic can help you resolve that issue over the phone in a minute or two.
click here to Talk to a Mechanic (only for users in the US for now) and get all the help you need.
Gx610 Honda v-twin small engine one side want fire
Hi, If you did the usual testing (comp,Carb cleaning, etc.) then I would go to the electronic ignition box if it has one. I've been fooled before. Checking for spark, wire off, or plug out, isn't the same as a plug under compression , Good luck.
Feb 05, 2017 | Honda Vehicle Parts & Accessories
I keep popping 25 amp fuse when trying to start honda GX610 18 hp gas engine on 3100 Stone Wolf pac roller
if the fuse pops when turning to crank position the problem lies within the small solenoid wire to the starter (this wire goes from the ign.switch to the starter solenoid and is powered up when in the start position) this wire is shorted to ground....or the starter solenoid is shorted....best way to tell is unhook wire from solenoid and turn key to start...if the fuse does not pop its the solenoid....do this several times to verify
Oct 05, 2014 | 18 HP V-TWIN GX610 V-Twin OHV Horizontal...
My honda gx610 in leaking oil out of the exhaust, any suggestions to why it is?
may have head gasket or centre manifold gasket leaking .. remove one spark plug at a x , check to see if it,s oily.. replace each one back so there,s no confusion after u checked all ..while ur doing each one, do a compression test to each cylinder to check if u have worn out piston rings .. gd luck ...
Jan 19, 2013 | 18 HP V-TWIN GX610 V-Twin OHV Horizontal...
V-Twin Horizontal OHV Engine with Electric Start - 610cc, GX Series Logo
651 people viewed this question
Top Honda Vehicle Parts & Accessories Experts
rlev_7
Level 1 Expert
Colin Stickland
Colin Stickland
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Honda Vehicle Part and Accessory Expert? Answer questions, earn points and help others
