Question about Toro TRANSAXLE ASM Part 104-1760
We have a problem with the clutch plate and throw out bearing in my daewoo lanos 2000 model. We know how to remove and replace everything except for the removal of the axles hafts. would anyone be abl
Daewoo lanos 2000 1.5ltr manual
Clutch
Well, if you have a lift and the ability to remove a heavy trans, it is not too hard. Usually not a home job.
Also resurface the flywheel and replace release and pilot bearings.
Jul 28, 2010 | 2002 Daewoo Lanos
Clutch wont go in
You need to pull the transmission and do an inspection.
Most likely the throw out bearing is bad or the clutch is shot.
If it is new - you put the clutch in backwards or you have a bad throwout bearing set up.
The only thing other than this is the clutch peddle cable could be broken but if it is - the clutch peddle will flop around.
RICESKi
Apr 27, 2010 | 1999 Daewoo Lanos
The clutch pedal is rock hard won't go in too gear checked the clutch master cylinder and thats ok, so do you know what the problem is.
Possible solution! Daewoo Lanos 98-99
Had the same problem suddenly the clutch pedal went rock hard!
The clutch was around 3 months old.
Mechanic checked - Master, Slave, Clutch Components, and inside the box, all looked okay.
Turned out the top arm of the clutch pivot rod had twisted, replaced pivot rod around AU$100.
Fixed Problem!
68f141a6-6e26-4193-91d9-bdf12856e824.jpg 8ee95b47-7be0-4e27-81a1-a4ccf7bbc122.jpg
Apr 16, 2010 | 2004 Land Rover Discovery
Noisy throw out baring on a 2001 dawoo
Only option is to do a clutch job. it comes with all the parts and the throwout bearing. You could do just a throw out bearing but the labor cost will be the same as doing the whole clutch job.
Jan 14, 2010 | 2001 Daewoo Lanos
I need part number for the rear wheel bearings left and right , inner and outter for Daewoo lanos 2000 model
Daewoo rear wheel bearing parts numbers are
94535209 and 94535218....one each per side
Jan 06, 2010 | 2000 Daewoo Lanos
New slave and master for clutch still will not engage did bleed
If all the air is out of the clutch system than you probably have badly worn fingers on you clutch plate and it should be replaced as an assembly, clutch disk, clutch plate(pressure plate) and throwout bearing. Thank you, Dana
Sep 29, 2009 | 2000 Daewoo Lanos
2000 daewoo lanos gearbox
Try this site it is called manuals online, may have what you are looking for.
Jul 25, 2009 | 2000 Daewoo Lanos
How to replace front wheel bearings on 2000 Daewoo Lanos
they come as a whole assembly hub and all
Feb 15, 2009 | 2000 Daewoo Lanos
Car will not drive, is it clutch or cabel
my daewoo lanos wont shift into gear/s while running even when clutch is depressed all the way
Nov 12, 2008 | 2001 Daewoo Lanos
Toro TRANSAXLE ASM Part 104-1760 Logo
32 people viewed this question
Top Toro Heavy Machinery Experts
Bill Boyd
Tom Chichester
ray gallant
Are you a Toro Heavy Machinery Expert? Answer questions, earn points and help others
