Question about Pioneer DXT-2369UB Complete Car Audio
How to turn on radio
Need to know which buttons to press.
I tried to replace my "volume/power" button on my 2004 Chevy Suburban but now it won't turn on. Any ideas? I got the replacement button from the dealership but they don't know what to do. If I coul
did you disconnect the radio to fit the button. if so you will need the radio code.
the button is a press on button the by pressing it on, you switch of the power . press again and the power comes on .turning the button gives volume
Feb 11, 2015 | 2004 Chevrolet Suburban
How do i set my alarm and when do i know it is on or off....keeps coming on and i dont know how to shut off the alarm...thank you
This clock radio features a dual alarm system, with two separate alarms that can be operated independently. The alarms can be set to wake two people at different times, or to have a main alarm and a backup. One alarm features your choice of radio stations as an alarm wake sound, while the second features a buzzer wake sound. You can set the radio alarm, the buzzer alarm, or both alarms.
Setting Radio Alarm
1. Press the "Alarm Set" Button. The display will flash and the Radio Alarm Indicator will appear. If you do not begin setting the time within ten seconds of pressing the it, the display will stop flashing andd you will need to press the "alarm Set Button again. 2. While the display flashes, press the "Tuning/Set" Buttons to set the wake time. Hold a button for a few seconds to advance the time rapidly. Be sure to set the correct AM/PM time, as shown by the PM Indicator. 3. After setting the radio alarm time, you will need to select the station to wake up to. First, press the "AM/FM" Button to select a radio frequency. Next, select a station using the "Radio Preset Buttons". Rotate the Volume Thumbwheel to set a wake sound volume level. 4. After setting the radio alarm wake time and sound, you will need to select your 7-5-2 setting. The 7-5-2 setting lets you set the alarm for a full week, weekdays only, or the weekend. Before setting the alarm, be sure that the correct date is set. 5. After you have set the radio alarm wake time, wake sound, and 7-5-2 setting, press the "Alarm Set" Button twice so that the display shows the standard, non-flashing display.
Setting Buzzer Alarm
1. Press the "Alarm Set" Button twice. The display will flash and the Buzzer Alarm Indicator will appear. 2. While the display flashes, press the "Tuning/Set" Buttons to set the wake time, as described above. 3. After setting the buzzer wake time, use the "Date/7-5-2" Button to select the buzzer. 4. After you have set the buzzer wake time and 7-5-2 setting, press the "Alarm Set" Button once so that the display shows the standard, non- flashing display.
Activating the Alarms
1. To activate the radio alarm, press the "Radio Alarm" Button so that the Radio Alarm Indicator appears on the display. As long as this indicator appears, the alarm will sound at the set time and days. 2. To activate the buzzer alarm, press the "Buzzer Alarm" Button so that the Buzzer Alarm Indicator appears on the display. As long as this indicator appears, the alarm will sound at the set time and days. 3. When the alarm sounds, press the " Off/Reset" Button to turn off the alarm while still maintaining the programmed 7-5-2 alarm settings. To turn off an alarm and cancel its 7-5-2 settings, press its "Alarm Button" so that its Alarm Indicator no longer appears on the display. 4. To activate the snooze feature, press the "Snooze/Night-Light" Bar when the alarm sounds. The alarm will shut off for approximately nine minutes before sounding again. The feature can be repeated several times during the one-hour snooze cycle. 5. If it is not turned off, the alarm will sound for an hour before stopping. As long as an Alarm Indicator appears on the display, the alarm will sound at the set time, according to the 7-5-2 settings.
Mar 23, 2011 | Timex Auto-Set Dual Alarm Digital Clock...
I NEED TO KNOW HOW TO CLAER THE BEEPING SOUND WHEN YOU KEY THE BUTTON
The beeping sound when you key the button is called the roger beep. To turn it off, with the radio off, press and hold the "up" button and turn on the radio. More information about all the settings is in the user manual, available HERE.
Nov 13, 2010 | Uniden GMR1038-2 (7 Channels) 2-Way Radio
Clarion pu 1570 radio cassette not responding
If You know the code:
1. Turn radio On
2. Display say "Code in"
3. Enter the Code by memory station buttons (4 digits)
If You enter wrong code for the first time:
1. Turn radio off.
2. Turn radio on
3. Press and hold the band "~" button
4. Display shows ====
5. Wait till display say "code in"
6. Enter the code by mem. station buttons.(4 digits)
Important:
You mast wait by Radio ON in = = = = condition,
and not in - - - -!
The max. waiting time is 90 min.
TIP:
Tested by PU-1570A Eeprom 93C46
1. Radio Off
2. Press and hold the Band "~" Button.
3. Turn the radio ON
4. Enjoy!
Apr 22, 2010 | Car Audio & Video
Need to know purpose of 'mon' and other button on front of radio,  person who gave us 3 radios is not longer available.
You do not mention the type of radio you have, so our answer will be rather generic. The "MON" button is the monitor button. It is used to temporarily shut off your interference eliminator (aka private line, PL, tone code), so you can hear if anyone else is speaking on your frequency. This is to be used as a courtesy to other radios users in your area which are on the same frequency. (Sadly, people are usually not so polite.) If your radio does not have the PL turned on, this button will do nothing, as you will already be hearing the radio traffic on your frequency.
On some models the "MON" button has both a long and a short press function, typically the short press is the temporary monitoring of the freq., while the long press is "sticky monitor" which will hold you in the monitor mode until pressed again, or the radio is turned off and then back on.
As for the other buttons, they can be programmed to a variety of options including high/low power, tight/loose squelch, scan/nuisance channel delete, battery indicator, volume set, and a few others. The only way to know for sure what it is programmed to is to have the radio readout by a dealer. Or an educated guess, as some would be obvious by their function.
Regards.
Jul 21, 2009 | Radio Communications
I need the radio code to my 97 Del Sol please
Don't know if it will work on yours but turn the radio off, Press and hold the 1 and 6 button. Turn on the radio. press the #2 button and this will give you the serial# and you can contact the dealer to have the radio code sent to you from the Radio supplier. If you push the #2 again you can listen to your radio on a temp basis
Jul 18, 2009 | 1997 Honda Civic del Sol
How do you go to silent mode?
There are two different kinds of beeps you can control, the "roger" beep and the "button" beeps. Below is an excerpt from the owners manual explaining the simple procedure.
“Roger” Beeps/Talk Confirmation Tone
When you turn this feature On, your two-way radio transmits a unique tone when
you finish transmitting. It’s like saying “Roger” or “Over” and lets others know
you have finished talking. If the person you are talking to does not hear the talk
confirmation tone, you can enable it by pressing and holding + (plus) as you turn On
your radio. Now, whenever you release the PTT, you let your friends know you have
finished talking by transmitting a “Roger” Beep tone. “Roger” Beeps will be
disabled as the Default Setting.
Note: To toggle the Talk Confirmation Tone feature, turn your radio Off and then
back On while pressing and holding + (plus) .
Button Beeps
Every time you press a button on the front of your radio, it beeps unless you turn
Button Beeps Off. To turn Button Beeps Off, turn your radio On while you press - (minus) and
hold . To turn Button Beeps back On, turn the radio Off and then back On again
while you press and hold the - (minus) . On is the Default setting.
Here is a link to the manual: http://www.giantintl.com/RadioPDFs/Outdated%20Manuals/T7100_User_Manual_E.pdf
17
Nov 28, 2008 | Motorola T7100 2-Way Radio
02 VW GTI Radio says CHECK
This worked for me (radio in 2003 VW Golf):
Radio says "CHECK" but is otherwise unresponsive. Turning car or radio on/off doesn't help.
On the far right of the radio, there's a round TUNER button. Press it for 5 seconds. Your screen will then show some digits, but the unit is still unresponsive.
Press tuner button again for 5 seconds. Radio should now be 100% again. Let me know if this works for you.
Nov 21, 2008 | 2002 Volkswagen GTI
Muting the sound
The sound produced by a Motorola radio when the mike is keyed refers to the "Transmitting Call Tone" which is another feature other than the "Interference Eliminator" or the "Roger Beep" feature.
On most Motorola GMRS/FRS TalkAbout radios, setting the "Call Tone" to 0 disables the feature. This is done with the radio ON by pressing on the "Menu" button 3 times which will result in the display showing the current Call Tone setting (flashing) and the letters CA; pressing on the <- or +> buttons will change selection (you will also hear the different Tones), select 0 (it may be up to 5 or 10 depending on the version). Press on the "Menu" or "PTT" button to set, save and exit.
Hope that this be of some help/idea. Pls post back how things turned out or should you need additional information.
Good luck and kind regards.
Nov 25, 2007 | Motorola TalkAbout T5530 2-Way Radio
I NEED TO KNOW HOW SET THE CLOCK ON A DEH-1500 PIONEER
Found a posting on another site from 2005, and it worked!
Turn on the radio. Press and hold the "Source" button until the radio goes off. Press and hold the "Audio" button until the numbers flash. Use cursor/arrow buttons to adjust the time. Press and hold the "Audio" button to exit.
Oct 27, 2007 | Pioneer DEH-1500 CD Player
Pioneer DXT-2369UB Complete Car Audio Logo
23 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
