Question about Nordic Track NordicTrack A2350 Pro Treadmill
Incline want leave level 10
Incline iS AT level 10 and will not change. stuck at level 10
My HEALTHRIDER H95T treadmill is stuck in the fully elevated (level 12) angle on the platform and will not move
The incline motor is jammed due to a faulty incline sensor or incline motor assy. This is somewhat hazardous if you do not know what you are doing to remove the incline motor. Sometimes you can repair it most of the time you replace the incline motor assy. Must be calibrated upon completion.
Feb 22, 2015 | HEALTHRIDER H95T Treadmill
My Nordictrack treadmill model T7si is stuck on the 10 incline position. How do I fix it?
Check that the incline plus switch is not jammed or likely there is a defect in the panel circuit causing plus incline to be repeated. This needs to be trouble-shooted by removing and testing the panel circuit.
Oct 07, 2014 | Nordic Track Exercise & Fitness
Hello, WE have the model 4100i treadmill and the elevation is stuck in the highest position and won't reset to zero. How do I fix this or who can I call for this repair? Thanks, Tom
Try the calibration procedure found in the troubleshooting section of your manual first. Here are the basic instructions.
With the key in the console, press one of the Incline buttons. While the incline is changing (or the numbers on the console) , remove the key. After a few seconds, re-insert the key. The treadmill will automatically rise to the maximum incline level and then return to the minimum level. This will recalibrate the incline.
If it still doesn't move, remove the cover. Find the incline motor. You will see a slot in the end of the motor. Using a drill with a standard slotted screwdriver bit, spin the motor counterclockwise (if it is having difficulties spinning, turn clockwise instead) for just a couple seconds. Now do the calibration procedure again.
I have had machines that got stuck before. Once released and recalibrated, the operation was OK.
The service number for your machine is found on the model number sticker on the frame of the treadmill.
Feb 26, 2011 | Nordic Track Nordictrack Apex 4100i...
Treadmill wont incline all the way
With the key in the console, press one of the incline buttons. While the incline is changing, remove the key. After a few seconds reinsert the key. The treadmill will automatically rise to the maximum incline level and then return to the minimum level. Thi will recalibrate the incline system.
Sep 30, 2009 | Reebok 8050 ES Treadmill
Buttons Froze during workout, now none of them work
It sounds like you just need some calibration. To calibrate incline, turn power on press press any incline buttons, as the incline try to change unplug the key. Now re-nsert key and incline will self calibrate,
Aug 23, 2009 | Nordic Track NordicTrack Treadmill, A2550
My health rider treadmill s300se is stuck in the highest incline position. How do i get it level again?
Try putting the key in while holding the down incline button in. This resets the height mechanism. Repeat with the up incline button.
Worked for me.
Aug 11, 2009 | HEALTHRIDER S300SE TREADMILL Drive Motor
Incline stuck @ 10 but reads as if it's on 0 incline. doesn't want to decline
I don't know what model you have, but on some treadmills in the front there is an adjustment by a t-bit screw for calibration. You may want to try and unplug it and have someone hold the incline button while you replug it. Sometimes the program gets a glitch and a fresh restart from being unplugged corrects it. If you could list your model and brand I could be more detail specific.
Apr 21, 2009 | Computers & Internet
Incline wont work
Check here for the user manual:
http://manualfox.com/link/reebok.htm
And maybe send them a manual request?
Mar 23, 2009 | Epic View 550 Treadmill
Nordic Track NordicTrack A2350 Pro Treadmill Logo
18 people viewed this question
Top Nordic Track Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Ross Metcalfe
Ross Metcalfe
Electro Med Services...
Are you a Nordic Track Exercise and Fitnes Expert? Answer questions, earn points and help others
