Question about Samsung WA422PRHDWR 4.2 Cu. Ft. VRT Top Load Washer
Water leaking under - Samsung WA422PRHDWR 4.2 Cu. Ft. VRT Top Load Washer
Much water under front carpet of 2002 Toyota Sienna. seems to coming from up under dash on firewall I think, what say you.
If the Water smells like Antifreeeze then it is your HEATER CORE
If the water smells like Water or Dirty Water, then you have a LEAK.
Here is a TRICK..
Get an Aresol Can of WINDOW CLEANER.... Spray completely around your Windshield on OUTSIDE EDGES... YOU WANT IT FOAMY.
Get an AIR HOSE and BLOW the Windshield from the INSIDE and see where the leak is coming from.....
It has ALWAYS worked for me
Apr 08, 2013 | 2002 Toyota Sienna
Water leaking under hood
yup check the radiator hoses upper & lower, when the water pump goes bad also leak out coolant or water ect and the final wiil be an internal head gasket leak i hope this work for you.
Jul 13, 2012 | 2000 Hyundai Sonata
Water leaking under car
You sure it isn't the condensate from the Air conditioner?
You should have antifreeze in the radiator,not just water.
If this is clear water,it's probably condensate and no problem.
BTW,if you weakened your antifreeze solution by adding water to it,you might want to check if the freeze point is still around 30-40 below zero Fahrenheit. don-ohio (:^)
Mar 26, 2017 | Ford Fiesta Cars & Trucks
Auto defrost works fine except for water accumlating in the bottom of unit under the bottom trays instead of in the water tray by the compressor. graywolf7499@yahoo.com
There is a leak or damage of the pipe leading from the evaporator downwards.The defrosted water is leaking out of the tubing to the bottom,replace this tubing or check the leak on the collecting tray under the evaporator.
Sep 30, 2010 | Whirlpool Refrigerators
Water leaking under floor when dishwasher runs
check the water to the unit it is locate under the door open the panel 2 -4 screw take flash light turn the unit on and see where the water come from ... it might be also from under your sink.
Jan 01, 2010 | Dishwashers
Water leak under truck, had oressure test could
Are you sure the water leak is coolant?
not the ac condensation?
if it is coolant and doesnt show up in a pressure test its probably a head gasket leak
Nov 15, 2009 | 2005 Dodge Ram 1500
Water leak but not able to find out what part is called
Where is the leak?
Passenger side under dashboard area? (heater core)?
Near front of car? (Radiator leak)
Under fanbelts and pulleys? (water pump)
Under middle of engine (water hose)
Please .. more info.
Oct 05, 2009 | Mitsubishi Passenger Cars & Trucks
Losing water no oil in water over heating
could have a hose leaking, heater hose, upper or lower radiator hose, coolant recovery tank leaking, radiator leaking, water pump leaking. You could put something under the car when you park it to get a general idea where to start looking for the leak. Make sure what ever it is you will be able to see the water when you get up in the morning. Might try a large piece of cardboard cut to fit under radiator and engine all the way up under fire wall just to have the whole engine bay area covered so you'll be able to find the leak
Sep 30, 2009 | 2002 Kia Sedona
Heavy water leak in basement under fridge
Has this fridge got an ice maker???
Because ice makers require a water supply to make ice.
This could be where your water is coming from.
Jan 19, 2009 | Sub-Zero 650 / O Bottom Freezer...
Samsung WA422PRHDWR 4.2 Cu. Ft. VRT Top Load Washer Logo
44 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
