Question about Vissani 5.8 cu. ft. Wine and Beverage Cooler MCBC58DST
Need wine shelves
Need shelves
New home with wine frig but I want to turn it into a beverage frig. Where can I buy glass shelves to replace the wine racks in my U-line?
there must be a glazier business in the town to repair windows etc so go there with the length and width measurements and the thickness should be no less than 1/4 " or 6 mm to carry the shelf load
as the shop for a recommended glass thickness but I would not go under 6 mm and make sure that the edges are sander to get rid of sharp edges
Nov 18, 2015 | U-Line Refrigerators
My dual zone wine cooler stopped cooling. Power is good and fan is working.
Fan is wired separately from the cooling unit. you may have a wire corrosion issue. take put the shelves, disassemble the back of the unit from the inside and observe the wiring to see if there are broken or corroded wires/connections. R/R if necessary.
Dec 14, 2014 | Magic Chef Dual Zone Wine and Beverage...
What causes Ice build up on inside back panel of kitchenAide KUWA244PBS?
normally that means yhe defrost thermstat is bad or the heating element that causes the defrost is bad.
Aug 31, 2014 | KitchenAid KUWA244PBS Wine Cooler
How should I clean my wine cooler?
You should follow my exact instructions in order to clean your wine cooler properly.
1. Unplug your cooler and remove all items from it.
2. Clean the inside surfaces with a mild cleaner (I recommend you to mix water and soda).
3. Clean the wire shelves.
4. Clean the wooden shelves.
5. Wash the outside of the cooler.
6. Dry any wet part with a soft cloth.
Aug 14, 2012 | Furniture
Should I get a wine wall rack or the traditional shelves rack?
I strongly recommend the shelves rack and thisis for the following reasons: First, the wall rack is more likely to fall fromthe wall where the shelves seem more firmly designed. Second, the wall rack Ihave seen have the bottles stuck in it in a way that they look like they areabout to fall - I personally does not like this type of design. I like my wineto be firmly held in the traditional way, but, hey, this is me.
May 29, 2012 | Furniture
I want to use my undercounter wine fridge as a real fridge. Wher can I get replacement shelves and baskets/drawers. U-line large model
This cannot be done. The doors are not designed to be as a refrigerator door. The controls are different. This model is designed to be 45 to 60 degrees. WILL NOT WORK FOR REF TEMPS!
The liner has racks that is screwed into them. Shelves are with liners that are molded so the shelves are resting on them.
Sorry
Jul 07, 2009 | Refrigerators
U-line 75WC wine cooler - rust on inside back wall
This happens when the racks get too close to the evaporator. Or bottles. You can try to use hot water but usually you will need to buy new racks for the unit.
Sep 17, 2008 | U-Line 75WC Wine Cooler
Vissani 5.8 cu. ft. Wine and Beverage Cooler MCBC58DST Logo
Top Vissani Furniture Experts
Jay Finke
Jay Finke
ray gallant
L Pfaff
L Pfaff
Are you a Vissani Furniture Expert? Answer questions, earn points and help others
