Question about Ultima 3.35" Open Belt Primary Drive Street Style for Harley-Davidson
Remove rear pulley from ultima pulley
Remove rear pulley
Hi, I was wondering if anyone can tell me in detail how to remove the casing of a hotpoint wd860 ultima so I can access the belt pulleys to replace the belt. Totally stumped and have hurt my finger this...
jon you would have to remove the drum and you don't want to go to that hassle to fit a belt.
try this out
  1. remove lid
  2. remove back inspection panel
  3. from top of machine fit belt around motor pulley
  4. half fit belt to the drum pulley
  5. Here's the tip, get a cable tie and secure belt to drum pulley, may need to use 2 ties
  6. now slowley rotate drum and belt should slip straight on
when your not used doing this sometimes a good idea to remove the top weight, 3 13mm bolts. this will give you more room.
hope this helps
Mar 17, 2011 | Hotpoint Ultima WF860 Front Load Washer
Wot does code F-05 mean on a hotpoint ultima washer mean?
It means water level switch jammed on full.
You need to check and clean pump filter.
Remove lower rear panel of washer.
Locate and remove large black hose fastened to bottom of drum.
Remove and clean plastic filter inside the hose
Reassemble and water test..
Feb 15, 2011 | Hotpoint Ultima WF860 Front Load Washer
I want to replace the belt. how can i do it
Remove lower rear panel of washer,
Tilt washer away from you , and get someone to hold it for you.
Put belt on motor pulley first, and slowly feed it round drum pulley turning the pulley at the same time, it is quite hard to do, but persist and it will go on eventually.
Watch your fingers!!!!.
Dec 02, 2010 | Hotpoint Ultima WF860 Front Load Washer
I want to know how to fit a new belt to a hotpoint washer/dryer wd865
Remove the rear panel of washer, and tilt washer forward away from you with someone to hold it steady.
Fit the belt round the motor pulley first and slowly feed it round the drum pulley turning the drum pulley at the same time,
It will be very tight, so watch your fingers.
It may seem to be too small, but persist with it, and it will go on.
Nov 12, 2010 | Hotpoint Ultima WF865 Front Load Washer
Where is the filter on a hoitpoint ultima wf860
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} The filter is under the rear of the machine inside the sump hose. Remove the lower rear inspection panel and tilt the machine forward, keep it tilted by placing a tin of peas or something under it at the rear. Now put a shallow bowl or dish under the sump to catch any water that may still be it the drum and remove the retaining clip. Pull the hose free from the tub and the filter is inside. (Work safe and remove the power plug from the wall before commencing any repair) For more tips on repairs use this link selfix-uk
Mar 11, 2010 | Hotpoint Ultima WF860 Front Load Washer
Error code F-05 showing on my Hotpoint ultima
Error code F02 indicates pressure switch jammed on full.
Remove large black hose from bottom of drum.
Remove and clean filter inside hose.
Remove hose on to pump and check for blockage or obstruction here as well.
Pleas rate my solution.
Thankyou.
Jan 25, 2010 | Hotpoint Ultima WD72 Front Load...
Hotpoint ultima F-05 errorr appears on machine
Error F05 indicates pressure switch jammed on full.
Remove lower rear cover of washer.
Locate and remove large black hose fastened to drum.
Remove hose onto pump, and check for blockage or obstruction here as well.
This should solve the problem.
Jan 10, 2010 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint ultima
The filter is located in the sump hose at the rear bottom of the m/c.
You need to remove the large clip that holds the hose on
Access is gained by removing the lower rear panel.
Oct 25, 2008 | Hotpoint WMA76 Front Load Washer
How do I reattach/replace the belt that causes the Hotpoint Ultima WF860 to spin?
If you remove the back cover from the machine, you should see a big round pulley which attatches in the centre to the inner drum shaft. Below the drum you should see the motor. The belt goes around the big round pulley and onto the much smaller pulley on the end of the motor shaft.
Oct 28, 2007 | Hotpoint Ultima WF860 Front Load Washer
How do I replace the belt that makes the drum spin on a Hotpoint Ultima WF860 ?
The belt goes around the drum and onto the motor pulley. No need to loosen anything. Put tension on the belt and fit it onto the motor pulley by gently turning the motor and pushing the belt onto the pulley at the same time.
Ultima 3.35" Open Belt Primary Drive Street Style for Harley-Davidson Logo
70 people viewed this question
Top Ultima Clothing Accessories Experts
Da Doc
ray gallant
Are you an Ultima Clothing Accessory Expert? Answer questions, earn points and help others
